  4. E46 radio won't turn on in cold
11 Posts 5 Posters 0 Views 1 Watching
    Radio won't turn on in cold. Gotta heat car up. Turn off, then back on. Ideas?
    I tried googling my symptoms, but couldn't find much... And the little bit I did find, wasn't helpful
      Factory radio or aftermarket?
        Factory. It worked flawlessly in the 40's and 50's. But once it started to drop in the 30's and lower, it once in a while did this, now with this cold snap it always does it. It's semi annoying, because turning the car on an off doesn't always work. And that uses more gas then it's worth.
          have you tried turning it off and on
            I would have, but can't turn the radio off, if it' isn't on! ;)
            Although, I haven't tried a battery pull yet. So I guess that's next? lol.
            • RamRod E28R
              RamRod E28R
              RamRod E28
              Do you have a business class cd with the Harmon kardon sound system?
              1988 BMW 528e - Need parts?
              1996 Mazda Miata (SOLD!!!)
              1996 BMW 325i (Donor car)
                yes and yes.
                  I would recommend turning it off and on again.
                    Do a stomp test, then you'll know what the problem is
                    • RamRod E28R
                      RamRod E28R
                      RamRod E28
                      Then buy mine off me it's collecting dust in my shop...
                        Lol. If I'm gunna replace this radio it won't be for a factory replacement. I'll drop a good amount on a touch screen/sat nav
