1.8k Posts 58 Posters 19.2k Views 5 Watching
    Things actually happened since last update.
    Friday I went to the shop after work and smoothed out all of the welds I could get with a flap disc.
    I need to find something small to fit into the remaining areas to grind.
    I spent Saturday morning at the meet and then came back to the shop with Andy.
    We removed the tie rods from my rack and cleaned it up a bit.
    I found where it was leaking right away. One of the lines rotted through.
    I removed them and will be capping them off since I deleted power steering.
    My lovely girlfriend then stopped by to drop off my package from ECS Tuning.
    There was a ton of harware and my tie rods, but two other things stood out.
    I have always wanted the raised BMW front rubstrip. It seems that the area it mounts on my rep bumper is a little off from OEM, so I will need to do some light sanding of the bumper for the rubstrip to sit flush.
    I have also really wanted the euro M3 radiator cover since I saw one and it wasn't too bad of a price. Only $35 and ECS carries them.
    After that I took my old oil sensor and replaced it.
    Around this time I actually felt like working on the car more and just started tearing into it. This was around 6pm and I needed to stay at the shop until 8:30 because my girlfriend and I were going out to see Andy for his birthday. I figured since the bay is getting rewelded shortly, the undercoat needs to come off as soon as possible. I also want to get my knuckles,calipers, and front subframe painted before putting the new control arms on.
    Off with her head
    This week I will be picking up a wire wheel and getting all of the undercoat off. I am glad I actually got something productive done and I hope it continues.
      Thanks....... I've been at work for an hour and half now and have nothing to show for it because of this thread.
        Earl has been at work on this thing for a year and a half now and has nothing to show for it   (*_*)
        (post will be deleted when the car is up and running.)
          You're welcome=)
          Hey, it hasn't even been a full year yet=) I parked it in November of last year
            Looks good!  Be careful taking the front end on and off so much.  You might wear out the fasteners and mounting holes.  ;)
              I was thinking about that. Hopefully I won't have to do it much more.
                Friday I split my old control arms from my knuckles and compared them to my new ones.
                The front end will feel a million times better with the new ones. It is odd because my car felt super solid before. I cannot imagine how nice it will ride whenever I finally finish the car.....
                I had to leave the shop shortly after that because I got something in my eye and it was really bothering me. When I got home it ended up just being dust in my contact making my eye dry out.
                Saturday I spent all day getting the undercoat out of my wheel wells. I thought at first I should go down to bare metal, but then figured I will need to primer/paint it before undercoat again anyways so I just focused on getting the undercoat itself off. I am very happy with the end results.
                Right now my buddy is able to do the welding this weekend. Hopefully that doesn't change over the next few days.
                I have also been honing my drift skillz on Forza 4 with Kaiser so come and play with us=)
                  So the bay got some much needed attention this weekend.
                  Saturday and Sunday my friend Greaser Kyle started working his fabrication magic on the bay.
                  I should have gone to him in the first place. Whate neded up happening is the guy I had weld before layed really tall tacks and when I ground them out, it ended up making some thin spots. This lead to Kyle having to fix blow through as well as patch a section that got really thin from his grinding. He is working out out so there won't be any issues after he is done.
                  I started saturday morning by removing one of the last brackets.
                  I didn't get many pictures of what Kyle got done.
                  Here is the hole he cut to patch where it got thin.
                  You can see it all patched up here.
                  That mount of weld up top was to add some thickness where a little hole was. He wants to use as much weld as possible so that I really don't need much filler at all later.
                  He is gone up north this coming weekend and then gone hunting the next, as well as Thanksgiving. I won't see him for about three weeks so that means I will be working on routing the airlines for the front through the inside of the car as well as finally putting my motor together a bit more=)
                    Looking good, maybe i missed this but is the welding for strength, looks, etc?  Just curious because I will be doing a bunch of work over the winter.
                      Pretty sure he's welding to make everything smooth.  Some just use filler, but then it cracks after awhile.  Welding is the better way with only filler to make it perfect.
                        Exactly what Robert said=) It is for filling the seam where the strut tower meets the wheel well. Otherwise people stick a bunch of filler in there and it cracks when stress is added. This will strengthen the seam and filler will only be needed for minor waves or imperfections in the metal.
                          OK, so mostly for looks.  Very cool, I can't imagine how anyone would think only filler would stay in the area around the shock towers, they flex when you drive hard.  That welding looks good, it is mig, not flux core correct?  I need to get a gas bottle so I can do things besides rusty frames and exhaust.
                            Yeah it is MIG. He was getting very frustrated with blow throughs so just started piling it on. haha
                              Trying to decide if I want to run m3 front brakes. Once I do I will be placing my rotor order with Adams Rotors. I am having a hard time choosing a pattern.
                              http://www.adamsrotors.com/gallery/gallery_detail.aspx?gallery_cat_id=1&gallery_id=2
                                Maybe cheaper to find e46 330 front brakes, I got rotors, pads, calipers, and brackets for 150 from Teds part out.  325mm vs 315mm for the e36 m3.  I just test fit them and they bolt right up, my 16" contours clear them barely.  I will have pics on my thread tomorrow.
                                  The thing is that those rotors would cost a fortune from Adams Rotors. Sizing up to m3 fronts already adds an extra $100 to the quote for 318ti rotors. Not to mention my front to rear proportioning would be way off due to zero upgrades for my rear brakes.
                                    Their site lists 300 for m3 front rotors and 250 for 330 fronts.  M3 parts are always more, becauses M...  Biasing stays good with e46 328 rears.  I have a link saved on my work computer about the biasing I will link to it tomorrow.
                                      I have a compact though. The only way I can upgrade is swapping in an entire z3m subframe.
                                        Are you keeping ABS?
                                          Nope
