  3. BMW Discussion
  4. First venture into the world of BMW's, lots of E30 questions:
125 Posts 13 Posters 2.0k Views 1 Watching
    Oil and the m20 is a topic with everyone having their preferences. Bentley recs are 20-50 summer and lighter for winter 10/15-40 or lower bracket depending on how cold. Some folks argue that the Bentley was written before the modern synth oils so is out of date which leads to more recommendations.
    My SpecE30 track car likes 20-50 dino, nothing burned no leaks happy car. Too much syrup for winter though. Tried a lighter synth (5-30?) when I first got the car and even with replaced seals leaked all over the place. Cheap horsepower though for some front pack is to run a lighter weight and pour in the quarts between sessions as it burns off.
      I run 10w40 in the E28 in summer. she loves it.
        I'd like to do one at some point before spring - if nothing else just to better understand the engine. If I'm not in danger of harming anything, I won't do it before theirs snow on the ground.
        Paint shop on Monday, then try to get a week or two of driving it in before theirs snow on the ground..... Then the REAL fun begins!
          I wonder if I'll even be able to find 20-50 locally? This will be a garage kept summer only car - so If I can find a 20-50 I'll go that route, or I'm sure they'll have 10-40 anyplace.
            You can get 20w50 at oreilly's. you won't have a problem
              My suggestion for an M20 based on the temperature chart in the owners manual is
              20w-50 summer
              10w-40 winter
              I just buy the cheapest 10w-40 (just in case I absolutely HAVE to run the car) for storing my car over winter
              Valve lash that is too loose can increase the chances of a broken rocker.
              Too tight on the exhaust side can cause burnt valves
              I am wanting to try out 0.008" on the intake side for a bit more performance and a little less noise but just haven't yet. Maybe you could be the guinnea pig :D
                Valve adjustment isn't too tedious on the m20, I noticed mine ran a little smoother too.
                  ....well tonight did not go as I hoped....
                  Got everything back together, got it full of coolant, fired right up and idled perfect.... And instantly started leaking a small steady stream of coolant from around the waterpump. Pulled everything BACK apart, only to find we had missed a small piece of the old gasket left on the block.
                  Called it a night at that point. Good news is the pump box had a second gasket with it, so can redo it all tomorrow night.
                  Super.
                    Dont feel too bad, I had the same sort of problem. But it was more of the "just use the gasket itself with no RTV because thats what the Bently says"  for which it leaked even after a thorough cleaning and degreasing. Re-doing it the second time was annoying, but it went pretty fast.
                      We had the radiator/fan clutch/etc... All torn back out in less then a half hour, so we just need to reinstall everything. Should go pretty quick tonight, just more of an annoyance then anything.
                      Car idled perfectly tho (it was idling at alittle under 2k when I pulled it into garage), so ft great to have it running the way it should. My Bosch coppers will be here today too, so I can get those in tonight as well.
                      Taking out son trick-or-treating tonight, but after that it'll be time to get it together and take her for a spin!!!
                      When I parked it the brakes felt "spongy" (car was sitting in a shop for 2 years when I towed it home). The brake booster line looked "new" and didn't appear to be leaking - other then bleeding brakes any other easy things to check that would give a "mushy" pedal feel?!?
                        A bulging rubber line can cause a spongy feel, should be able to feel or see a messed up spot in the rubber line.
                          My buddy with the fender roller is coming up Saturday AM.... So gotta get the fender mounted tomorrow night - and it'll be ready for paint on Monday!!! Woot!!!
                            Do you have wheels already to gauge how much the fenders need to be rolled/pulled?
                              Nope..... You wanna bring one up for me? :P
                              I'll hunt around and find one - looking for a 16"x9" ET10 (ish). I'm just looking to roll then flat, should need much pull.
                                So if you spin an E30 fast enough... The fuel pump will cut out.
                                Just sayin.
                                  E28, E24, E32's are like that as well. Fuel pick up is at the front of the tank.. Stupid ass design.
                                    If you have low fuel then it may starve. Some of the dedicated racecars run baffles in their tanks. I have never experienced fuel starvation issues though.
                                      Car drives pretty well over all tho! I noticed one of the rear sway bar ends was not connected, and it's got a slight "wobble" from right front.... But could just be crappy tires or such.
                                      Car started it idle at about 2k after alite driving.... Any suggestions on a culprit? I didn't see anything I recognized as an ISV, anything I should check?
                                      Going to recheck for vac leaks and clean TB and MAF tonight.... Any other suggestions would be great.
                                      First gas stop:
                                      E7C16907-C794-4407-A818-FBEA9174DAC7-989
                                        very clean=-)
