  4. Build Thread?
Build Thread?
  • JeffJ
    JeffJ
    Jeff
    this is looking to be a pretty sweet build
    1976 530i e12
    1990 325ix e30
    1992 325i e36
    1995 740il e38
    2001 330xi e46
    ^More to come :)
      Doubt it Jeff.
      • JeffJ
        JeffJ
        Jeff
        Doubt it Jeff.
        good point
        1976 530i e12
        1990 325ix e30
        1992 325i e36
        1995 740il e38
        2001 330xi e46
        ^More to come :)
          Quick fun story. Went to stance with Tim in the m50'd e30. Had a blast, but on the way back the highway didn't agree with our oil pan....
          The car got taken via tow truck to a friends nearby college were it sat overnight while we arranged a way to get it back to Appleton (pan blew out about 5 minutes away from the stadium.)
          Got a race trailer from a friend and headed down with his dads truck to pick the car up. Got there and he went to get in the car to move it, he pulled the handle and it was locked, reached into his pocket for his keys and just gave me that look. He had forgotten the keys to the car... So the drive back to appleton started. Luckily a friend grabbed the keys and met us in Fondy so we could save some time. Drove back down and got her all loaded up.
          Brought her home safely!
          Update time!
          Finally got MegaSquirt to work, was having issues with getting the fuel pump to turn on. Turns out that I solder in r39 instead of r40. Duh. So that works now.
          Have been getting more little things done lately so there is no large visual differences. Got my injectors for a steal from a guy on r3v, got my front calipers rebuilt.
          Put in one of my last orders for parts before she should be on the street!
          And before it gets asked why there is another motor in the garage I will share!
          Tim (deadskittles) had my m50 swap in his car, and a friend had an s52 in his e30 and the s52 was burning a german ton of oil per hour. Tim jokingly asked if tyler would trade him. And he did. So tim obtained an s52 burning tons of oil. Time to tear it apart.
          Things were odd (other than the fact that oil seeped out from the intake gasket when we pulled off the intake manifold, everything was suuuuper clean on the inside. Like, oddly clean.
          Friend of ours eric notices something stamped in the cam, we take a peek.
          Well would you look at that, schrick cams! Thats insane, s52 is awesome, cams are even better.
          So we continue pulling it apart when we notice something else.
          Stamped into the head, hmm.
          Google led us to find out that Bavarian CNC does CNC port and polishing and oversized valves..... Holy hell, she was turning out to be a very interesting motor.
          Kept working and got ready to pull the head. Popped it off and sure shit she had more secrets inside of her. After meticulous cleaning...
          CNC'd pistons, custom of course.
          This thing had a history for sure.
          Started looking into the pistons and noticed that some were sitting oddly in the cylinder so they got taken out. The findings were less than desirable.
          All of the pistons were toast... Looks like someone never upgraded the stock injectors and just overheated the cylinder walls.
          After much deliberation he decided to drop the money and get the block bored out to 87mm and get new pistons (similar to what was in it) but raise the compression to 11.5:1 while in the process. Make the thing really rip!
          So that is the story on that for now!
          That's all for now!
            Nice find, the guy didn't know what was in the engine?  Also what's the purpose of the grooves above the rings on the pistons?
              Glad to see both cars are in progress!
                Get that thing on the road!! Looking great!
                Sent from my SCH-I535 using Tapatalk 2
                  Just scored a full 3" Stainless catback exhaust for an unreasonably low price!
                  Today's winner is me!
                    Small update, got spark working on megasquirt after realizing that I never plugged in the motor to body harness connector  <<
                    Have some pipes with a friend to get bungs and fittings welded into them for my sensors and ICV and BOV.
                    Got the 3" stainless exhaust, came with a 4.5" exhaust tip! I had planned on running that this year yet but I decided to just turn an elbow out of the turbo and run the exhaust right out of the hood, screw trying to make a full exhaust work for a few days!
                    Got the e36 M driveshaft in, quite a bit larger than the e30 driveshaft. And the input seal on the diff leaks.... magical. Looks like that will just slowly drip until I feel like taking the damn thing out again.
                    All is well, things are progressing, slowly but I am still planning on getting it broken in before snow.
                      progress!!
                      :cool:
                        Know whats cool? When you get your oil in, then start pouring in coolant and find that it is flowing out of the front timing cover! F*ck
                        Everything was ready to go, and then that happened. Tried to crank it to make sure it had rpm signal, didn't have that either so I guess it will be awhile again.
                        There went the though of getting it out before winter...
                          860915102020657215837691229291984ozp
                          Photo Credit to suspenceful
                          She will be going under the knife again tomorrow. I hope to not let this set me back too far. We shall see though.
                            w00t!
                              Your last update has me confused. Did you add the oil and then coolant, only to find oil pouring out of the timing cover? Or was it coolant pouring out, or both?
                                Coolant
                                  uh........that doesn't make sense=(
                                  • H
                                    H
                                    Hammerdown
                                    water pump mounts to the cover.
                                      But wouldn't it be leaking down the cover? Nothing should leak out of the cover unless a gasket was missed.
                                        Gasket must have been compromised. The diagram makes sense if you see it lol.
                                          How long do you think it will take to fix?
