  4. Anyone know where to find out what model years used a certain part #? (Water pumps)
3 Posts 2 Posters 34 Views 1 Watching
  • N
    N
    norsairius
    I'm doing some research on the infamous water pump issue that E9x cars seem to have (which apparently plagued the  E46 too).
    I found information that non-turbo E9x cars used three different part #s for water pumps:
    #11517546994
    #11517563183
    #11517586925
    I didn't bother looking at water pumps for the N54/N55 becuase it's already been established that the water pump was definitely updated for those engines.
    My assumption is that the part # at the bottom is the newest one. I'm not sure though what model/year E9x vehicles used which water pump. I'm trying to figure this out because my assumption is the newest part # is a revised, more robust part that is less likely to fail and I just want to see if it's possible to determine when BMW started putting these in cars from the factory.
    All I know is that the bottom part # is what you find at places like getbmwparts.com or ECS Tuning, so I would hope it's the newest and most durable part.
    Does anyone know where or how someone can figure out what models/years used which part #? I've tried looking on Google and on Bimmerpost, but I've had no luck. I posted in this thread: http://www.e90post.com/forums/showthread.php?t=807187&page=9 but no one has replied with an answer (I understand it may be difficult to get one). Someone did list some models and years with the part numbers, but I have no idea where they got their information and my assumption is that the models and years they listed are simply cars that can use that part #.
    I know this is all just a theory, but I'm just trying to find anything that might give some people more clarity on the situation and hopefully some peace of mind for not only myself, but others. Many of these cars are used as everyday drivers and even for long distance trips. It could be dangerous for the engine to shut off with little or no warning due to a failing water pump.
      www.realoem.com
      www.penskeparts.com
      www.scientology.org
      one of those should have what you need
      • N
        N
        norsairius
        Gee, that third link you provided wasn't very helpful... didn't even seem BMW-related. ;)
        I think got my answer from Penske Parts and this is the breakdown of what I found:
        #11517546994 - No longer available since 2007-02, superceded by 11517563183
        #11517563183 - No longer available since 2008-04, superceded by 11517586925
        #11517586925 - Currently available
        My belief would be that if Penske Parts couldn't sell it to you, I would hope that BMW stopped using those part numbers in manufacturing by the dates they were no longer available, if not sooner.
        Thanks for the links!
