    THIS is the kind of ridiculous I like :D Great job Earl!
      Thanks sir;)
        Well the compact got outside for the first time since November=)
        I got the airline ran for the front struts and then rolled it outside to sweep out my spot in the shop. Enjoy the picture dump=D
        The drivers rear somehow snaked the tire in more than usual and seemed like it was going to unbead. lol I need to pull the fenders within the next week or two.
        I then pulled the car in and cambered the fronts to get the fitment down. Then I realized that the struts need to be spun down because it doesn't air down as far as I want. Here is where the front is at now.
        I also just love the insane toe in the rear......not
        Definitely getting my trailing arms modified this winter to correct that.
        I also inspected the chain guides on my motor and they were all good except for the right hand side one. The plastic was separating from the metal. Now to order that, paint the timing covers, and get it all back together=)
        Updates after Saturday=P
        • johnprusinskiJ
          johnprusinskiJ
          johnprusinski
          this looks awesome earl!!!!!
            Thanks pudding;)
            • johnprusinskiJ
              johnprusinskiJ
              johnprusinski
              it doesnt really do justice seeing it on my little phone.
                You will see it Saturday. Looks much better in person.
                Two more pictures that look almost exactly the same (and close to picture one in my last post)
                  Just paid $3 for Photobucket to have more bandwidth (because I was over the limit and my pictures were blanked out verywhere). I did it to keep all of my old photos alive for you guys=)
                      Damn, that looks awesome. I'm usually not a fan of the stretch/poke look but those wheels on that car just work so well
                        Thank you sir:)
                          I decided to focus on the engine this Saturday.
                          I started off by cleaning up the timing covers.
                          I had bought a can of VHT Wrinkle Black to do my valve cover and intake manifold, so I decided it would work well here too.
                          I cannot believe how well it turns out being from a spray can. After two hours had passed, I removed the old front main seal and installed the new one.
                          Old:
                          New:
                          During the time that took to wrinkle, I completed some other quick tasks.
                          I cleaned up my head and installed new intake/exhaust manifold studs.
                          I also cleaned and painted the rear portion of my timing case. I was going to just clean it up and leave it raw, but it was stained and just didn't look good enough to me.
                          Before:
                          After:
                          I also installed the coolant passage. (You can see where I painted the front on this side as well.)
                          I then spent a ton of time cleaning up the oil pan and thermostat housing.
                          I painted the thermostat housing with the VHT Wrinkle Black as well. I left the shop before it cured so I do not have any pictures of it.
                          I then tackled the oil pan. The front was covered in oil and road grime. After I got it clean I was also going to leave it raw, but I was not satisfied with how it looked. I sprayed it with engine primer and then put on two coats of gloss black caliper paint. I didn't want to waste my VHT Wrinkle Black and the caliper paint can withstand up to 600 degrees so I am not worried.
                          I am working on ordering the timing chain guide that I need. I have part number 11311247483 on my engine. The plastic is separating from the metal. I noticed that part number 11311247470 is also listed. That seems to be an all plastic version which would be superior since it cannot separate. I posted a thread on R3V to see which one to order and I have been told that 11311247470 is the one to go with. I am hoping to find one at Concours BMW or somewhere local so I can get my engine back together within the next few weeks=)
                          I am hoping to work on the valve cover and intake manifold this Wednesday. The car will be going to have the bay welded after I sort a few things out. I am also going to be borrowing a fender roller to get my rear arches situated.
                          I am happy with how things are slowly coming together. Updates to come after Wednesday=)
                            Love the attention to detail, especially on parts most would consider not to matter.  I do the same things and people think I'm crazy.
                            How much are the guides?  Due to the age and one starting to fail, it may be prudent to replace them all.
                              Thank you sir. All the little things count for me=) You're not crazy at all.
                              The guide I need is about $50. I inspected the others and they look almost new. The PO replaced the timing chain and head so I believe he replaced those too. Those are all solid plastic pieces too. The one failing was a terrible design where a plastic strip is adhered to a metal mount. The plastic is peeling off the metal on mine.
                              • E
                                E
                                ethirtysix
                                daaaaaaammmmnnnnn
                                  Hopefully that is a good damn:)
                                  I got the chain guide ordered and it may arrive wednesday. Thanks TJ:P
                                  • E
                                    E
                                    ethirtysix
                                    Yes it is a good damn. what is your plan for paint? and I apologize as I forgot what engine you are putting back into this? m44? I know thats what you had prior
                                    With a good paint job, this deserves a stance feature, first Ti that I've seen done really right, stance wise
                                      Anything for you Earl!
                                        It is getting the m42 put back in. Refreshing it now. The only thing I didn't do is the bottom end. It will be resprayed black. I'm not looking for a feature. Just trying to make the car look how I picture in my head:) Thanks for the kind words.
                                        TJ, you're the best:P
                                          Got a smidge of work done yesterday.
                                          I got a picture of how the thermostat housing turned out.
                                          It is a tad wrinklier than the timing covers but it matches well=)
                                          Blasted my bottom end out with brake kleen and air to remove any debris from scrubbing the pistons.
                                          Pulled out my new pan gasket.
                                          I coated smeared permatex silicone on both sides, stuck it on the block, and snugged all of the bolts down.
                                          Hopefully it is leak free=)
                                          I also cleaned and sprayed my oil filter housing.
                                          I sat for a while while it cured to see how the wrinkle would turn out. It seems like it might not turn out as well as I would like so I may need to strip and redo it. We will see once I get there Saturday.
                                          My timing chain guide will be installed Saturday and I have a lot more brackets and such to paint. I am hoping to get all the painting done Saturday and get my rear arches sorted out.
