  4. my E30 story
my E30 story
205 Posts 14 Posters 0 Views 1 Watching
    That's crazy he sold it. Now what's he gunna use?!
    • johnprusinskiJ
      johnprusinskiJ
      johnprusinski
      He is done with his E30. He is parting it out. It's a very sad thing to hear but it's what he wants. R. I. P. jakes E30 drift car :(
        I doubt this. Jake loves his car.
        • StewCrewS
          StewCrewS
          StewCrew
          Tis true.
            StewCrew said:
            Tis true.
            Now what? S13?
              Texas.
              • johnprusinskiJ
                johnprusinskiJ
                johnprusinski
                where did we go wrong
                • johnprusinskiJ
                  johnprusinskiJ
                  johnprusinski
                  well i finally got my motor to my house. it came yesturday but the box truck we used was too tall for us to lift out with a normal engine jack. we ended up putting it on a car trailer and using a pallet jack to move it in today.
                  • andyhundleyA
                    andyhundleyA
                    andyhundley
                    the car looks great so far. on a side note, would you be willing to sell the intake and the valve cover? and also i bought the lip off of jakes drift car. R.I.P.
                    • johnprusinskiJ
                      johnprusinskiJ
                      johnprusinski
                      Are you talking about the m50?
                        Hey list the 2.7l for sale. Someone needs to build a stroker.
                        • johnprusinskiJ
                          johnprusinskiJ
                          johnprusinski
                          I plan to put it up on the parts forum once I find out what will all go with it.
                            i agree with the stroker.
                            would be sweet.
                            • johnprusinskiJ
                              johnprusinskiJ
                              johnprusinski
                              i got the motor out now. now its just sitting around waiting to be taken away.
                              and just cause merica
                                Ditch this BMW an work on that old C10.
                                • johnprusinskiJ
                                  johnprusinskiJ
                                  johnprusinski
                                  its not mine, and my dad doesnt have the money to put into it.
                                  • johnprusinskiJ
                                    johnprusinskiJ
                                    johnprusinski
                                    alright i just got done with the gas tank. i decided to try and fix the hole. why not if its out right? i tried to do it sort of right so here it is.
                                    here is the damage.
                                    i started by buying a bunch of that quick steel and rubber undercoat. i then used a wire wheel to remove the paint that was around the hole. i then put three layers of that quick steal on and all over the hole.
                                    this is all of the putty stuff i put on. i fully went over board but i dont know if this will actually work and why not.
                                    i then sprayed two cans of rubber undercoat on the whole tank. i obviously cleaned the whole thing in mineral spirits and also wire wheeled the rust on the seams so it wouldnt rust any more.
                                    id say it went very well and that the tank wont leak.
                                      Good job john;)
                                      • johnprusinskiJ
                                        johnprusinskiJ
                                        johnprusinski
                                        i decided to loop my heater core to get heat faster so it doesnt have to run through the engine first.
                                        i put the rear end back together kind of. i started making a list of what i have to put loctite on and torque it to N.G.A. spec.
                                        im starting a new trend guys.
                                        le first step. open trunk
                                        carefully disconnect any wiring from body to trunk.
                                        aaaaaaaaaaaaaaaaaaannnnnnnnnnnnnnnnnnnnnnddddddddddddddddddddd boom new trend. eehhh ehhh what do you guys think? maybe some facebook/instagram fame???
                                        i thought id show you guys the damage that was done by the PO or who ever owned this thing.
                                        ok now i put the new trunk lid on. i know i know the paint match is incredibly close. im thinking of a neat idea to keep it closed. i got it to sit flush so im not sure what i want to do here.
                                        got this bad boy on today.
                                        i got a little frustrated with the old control arm. it just started to cross the line and i couldnt take it.
                                         i will be attempting to put this thing in on friday and saturday.
                                        • johnprusinskiJ
                                          johnprusinskiJ
                                          johnprusinski
                                          im crossing my fingers for this weekend. the m50 is currently under the car.
