  4. my E30 story
my E30 story
205 Posts 14 Posters 3.5k Views 1 Watching
    what's next?
    • johnprusinskiJ
      johnprusinskiJ
      johnprusinski
      slap oversteer said:
      what's next?
      i plan to get my steering column fixed. there is something bent or messed up so that why ive been having that turning issue.
      • johnprusinskiJ
        johnprusinskiJ
        johnprusinski
        ok well i havnt posted in a while since i have had to deal with not having any money and trying to get my new job and school set up. since i last posted i took out my steering column and linkage and found out that my linkage was in bad shape.
        i saw that people would replace the rivets with bolts, so i did the same
        i used some grade 8 bolts and nuts with loctite and lock washers.i haven't drove it far but so far it has held up pretty well.
        i also took my ABS out and ran all new brake lines.
        i got a new cheap seat for free from a friend and also a seat belt from my dads friend.
        i made my own seat bracket to hold the new seat and i welded the seat in the car.
        the seat belt is from R.J.S. racing. i got it because it is expired, according to SFI standards.
        i installed it but i will be getting or attempting to make a harness bar to attach the shoulder straps. for now i have them bolted them to the rear seat belt anchor.
        • johnprusinskiJ
          johnprusinskiJ
          johnprusinski
          i also made a new handle for the hydro brake. i will be buying a new master cylinder because the one i have now doesn't lock up the rear brakes on pavement.
          next thing on the list is coilovers.
            Looking good!
              I see you like to live dangerously.
              • johnprusinskiJ
                johnprusinskiJ
                johnprusinski
                  • johnprusinskiJ
                    johnprusinskiJ
                    johnprusinski
                    got an update, i bought an M50 from jake on friday.
                    i started pulling my motor from my E30 today.
                    it was going horrible and then it got even worse. i had the rear end of my car on jack stands and i had the front down trying to break loose a wheel bolt and then the rocking caused my car to roll back and fall off of the stands and one ruptured my gas tank. my stupidity was very great today, because i have no idea where my chocks were. im assuming i moved them because they were in the way or something.
                    i did however decide today that ill be putting in a fuel cell :P . i did get the motor dropped down today and the only thing left is picking the front of the car up and pulling the motor out.
                    im glad i went with dropping the subframe. i dont think i couldve done it by myself if i had to lift it out.
                      Jake sold you his M50? wtf
                      • johnprusinskiJ
                        johnprusinskiJ
                        johnprusinski
                        yes sir, for a very very very good price too.
                        • L
                          L
                          Laishes
                          Atleast you weren't under the car when it fell off the stands; christ.
                          • johnprusinskiJ
                            johnprusinskiJ
                            johnprusinski
                            yes, it was pretty scary having to jack the car back up and then 20 minutes later have to go under it again. im taking extra precautions to make sure the car is sturdy now.
                              That's crazy he sold it. Now what's he gunna use?!
                              • johnprusinskiJ
                                johnprusinskiJ
                                johnprusinski
                                He is done with his E30. He is parting it out. It's a very sad thing to hear but it's what he wants. R. I. P. jakes E30 drift car :(
                                  I doubt this. Jake loves his car.
                                  • StewCrewS
                                    StewCrewS
                                    StewCrew
                                    Tis true.
                                      StewCrew said:
                                      Tis true.
                                      Now what? S13?
                                        Texas.
                                        • johnprusinskiJ
                                          johnprusinskiJ
                                          johnprusinski
                                          where did we go wrong
