  4. Cold start/idling concerns
17 Posts 4 Posters 0 Views 1 Watching
  • JeffJ
    JeffJ
    Jeff
    Whisteling sound should is the problem. Means vacuum leak. Problems that go with tht are hesitation rough idle hard starting simply find the hose and replace it.
    1976 530i e12
    1990 325ix e30
    1992 325i e36
    1995 740il e38
    2001 330xi e46
    ^More to come :)
    • N
      N
      norsairius
      Makes sense. I checked the car again just 10-15 mins ago after it sat all night and it did the same thing. The RPM variation while idling is very small, maybe just 50-100. What was odd this time is that it didn't sit at 1k-1.1k RPM for too long, it dropped back down to 800-900ish RPM fairly quickly whereas it normally idles at 1k-1.1k RPM for at least 30 seconds or so. It still made the whistling sound though, and it only seems to happen at right around 1-1.1k RPM, not below, and not too far above (my guess is the engine noise drowns it out when it gets above 1.1kish RPM).
      I'm going to try and record a video to show to the service adviser in case it helps.
      • JeffJ
        JeffJ
        Jeff
        Just find the vacuum hose and fix it
        1976 530i e12
        1990 325ix e30
        1992 325i e36
        1995 740il e38
        2001 330xi e46
        ^More to come :)
        • N
          N
          norsairius
          Is there a diagram I could look at to make sure I fix the right thing? I know a good amount about cars and how they work, but when it comes to working on them, I don't have much experience beyond swapping out wheels/tires for the winter and changing air filters.
          • N
            N
            norsairius
            The car seems to be behaving better in the mornings. It knows I scheduled an appointment!  :mad:  It still makes the whistling sound, but the RPMs settle from 1k RPM down to 900 faster than before.
            • JeffJ
              JeffJ
              Jeff
              I can get on mitchel some time and get you a vacumm diagram if you need it. Check the small hose on the egr valve tends to break. Also the intake boot
              1976 530i e12
              1990 325ix e30
              1992 325i e36
              1995 740il e38
              2001 330xi e46
              ^More to come :)
              • N
                N
                norsairius
                I might take some time after work tomorrow and check stuff out under the hood with the engine idling. But yeah, a diagram would help if you could get one and point out the items I should be looking at.
                The sound only seems to be present when it's idling at 1k-1.1k RPM though, so I dunno what I'll find if it's idling below that.
                I know the service department (and its people) at Concours is nice, but I'd rather avoid wasting anyone's time with a service appointment if I can figure this out on my own or if this isn't even a real issue.
                • JeffJ
                  JeffJ
                  Jeff
                  Well looked around and can not find a vacuum diagram at all only ccv.
                  So listen to the whistle and gind where it is coming from.
                  1976 530i e12
                  1990 325ix e30
                  1992 325i e36
                  1995 740il e38
                  2001 330xi e46
                  ^More to come :)
                  • N
                    N
                    norsairius
                    Thanks for looking in to it! I'll just have to see if I can find it. The way the car behaves when it starts cold doesn't give me much time to find the noise, so I wonder if the changing weather has something to do with it. It's getting more humid out, etc. It used to idle and whistle for at least maybe 40 seconds to a minute, but now the revs drop down to 900 where it doesn't whistle anymore in what feels like less than 15ish seconds.
                    • N
                      N
                      norsairius
                      I went ahead and brought the car in. It needed the brake fluid and cabin air filter taken care of anyway. I described the symptoms I've mentioned in this thread, so we'll see if anything is found! I'm overall not that concerned about it. Performance seems unaffected (as far as I can tell). I'm just a bit worried because there's new noises that I don't recognize.
                      Side note, I got a nice X1 as a loaner. Very nice! I'm not much of an SUV guy, but it's one I'd consider if I were in the market. 8 forward gears still boggles my mind a bit. It was weird when I tried going in manual mode with it. That turbo I4 is impressive. It really hauls!
                      • N
                        N
                        norsairius
                        Hey, so I got my car back from the dealer today and the issue seems to be fixed. They kept my car overnight to try out a cold start. Tomorrow morning will be when I get to test it out myself, but I'm confident it got fixed. Thanks Concours!
                        The invoice says the following:
                        "C REPORTS ROUGH IDLE UNTIL ENGINE IS AT OPERATING TEMP
                        25412 DME SOFTWARE PER SIB 12-21-12. INTERROGATED VEHICLE FAULT MEMORY BUT NO FAULTS STORED. FOUND SIB 12-21-12 RELATED TO CONCERN, UNFAVORABLE DME SOFTWARE. PROGRAMMED VEHICLE WITH ISTA/P VERSION 39.4, INCLUDING CAS MODULE, PER SIB 12-21-12. AFTER PROGRAMMING CLEARED FAULT MEMORY AND TEST DROVE VEHICLE."
                        Seems like there's a service bulletin for it. I couldn't find much about it online as I was hoping to find out more about it. Anyone have any connections that could get more detail on SIB 12-21-12? I'm just curious to know more, but no need to do anything to get info on it if it'll get anyone in trouble.
                        • JeffJ
                          JeffJ
                          Jeff
                          here you go::
                          Service Bulletin listed below.
                          SIB 12 15 12
                          INFORMATION
                          The Automatic Start/Stop (MSA) system is a further BMW Efficient Dynamics measure aimed at meeting BMW's commitment to reducing CO2 emissions and enhancing fuel economy.
                          BMW, always a leader in innovative technology, will be the first automobile manufacturer to bring MSA technology to all new models.
                          Automatic Start/Stop systems will become prevalent in the future, as manufacturers strive to meet increasingly stringent emissions and fuel economy requirements.
                          By automatically switching the engine off when the car is stationary, MSA can improve fuel economy and reduce emissions.
                          New F-vehicles now incorporate the second generation of MSA (MSA II), which has been further developed to operate in combination with an automatic transmission and the BN2020 electrical system.
                          A detailed description of the MSA Automatic Start/Stop function can be found in the ICP Technician library under Technical Training course ST1112.
                          SITUATION
                          Some drivers have expressed the desire to deactivate this function in certain situations. This can be done manually via the Automatic Start/Stop function button with the LED switched on, indicating that the start/stop function is deactivated.
                          However, by default, the Automatic Start/Stop function is reactivated each time the engine is started.
                          At the request of an owner, it is possible to modify this default logic to "Last user mode."
                          With this logic, the current MSA's activated or deactivated setting is stored and used on the next trip.
                          Note: All new BMW M models have the "Last user mode" as the default setting from production.
                          1976 530i e12
                          1990 325ix e30
                          1992 325i e36
                          1995 740il e38
                          2001 330xi e46
                          ^More to come :)
                          • N
                            N
                            norsairius
                            Jeff, thanks for looking in to it! I think you pulled 12-15-12 though. My car doesn't have auto start/stop (which still seemed weird to me with the loaner X1 I had, haha, but it was fine). SIB 12-21-12 was the one done on my car. No real rush to get the info, again, I'm just interested to know more about it.
