  • merlM
    merlM
    merl
    OEM up front (750i control arm bushings) and poly for the rear subframe bushings.
      What durometer bushings did you go with? 7 series control arms work for you? What's the advantage?
      • merlM
        merlM
        merl
        It's an Aluminum M5 control arm with the 750i bushing pressed in. It is a bigger and more rigid bushing. That connection on the e28 is what causes the dredded shimmies these cars get.
        I have no clue what durometer .... this is the bushing though - http://www.powerflex.co.uk/road-series/product-details/Rear+Beam+Bush/725.html
          Did that bushing completely solve the shimmy issues?
          • merlM
            merlM
            merl
            Yes ... but I did replace every part in the front along with those so it is probably a combination. These tend to last a lot longer than the oem e28 part.
              Merl, do tell (in PM if you'd like so we don't thread-jack Earl) about this shimmy thing and what not. I get shimmy's occasionally.
                I got more good progress yesterday=) I remembered that I would like to reapply undercoat before I put the subframe back in. I bought two cans of Rustoleum undercoat Wednesday night, and did the coating yesterday afternoon.
                I started off by removing the sway bar. It had definitely seen better days.
                I plan to either remove it completely or buy a beefier one depending on how the car handles with the stock one. I figured I might aswell just clean it up a bit. I hit it with sander to knock the flaking rust off, primed it, and then threw a coat of black on it.
                Now it won't look like crap with the cleaned up subframe.
                After that I wiped the wheel wells and underside down with lacquer thinner to remove any grease and dirt. I then applied two coats of the undercoat. It layed really nicely and it didn't drip. It was dark under the car so it was hard to get a good picture.
                I'm very happy with how it turned out, and I plan to do the front wheel wells and underside when I install my front struts. I need to get some loctite to finish putting the subframe together for good. I might do that today if I go to the shop, otherwise I will do it next Wednesday.
                  I didn't do anything Friday besides reinstall the swaybar.
                  My package from ECS Tuning arrived Saturday. Now to throw all of those parts at the car=)
                    I got basically nothing done yesterday. I was making the hole to route my headlight harness through, but I didn't have the right tool to get it big enough. I'm hoping to get that done Saturday. I also did not have the right loctite on hand to tighten everything down for good on the rear subframe. I also didn't have any RTV to use on installing the rear diff gasket. The great news is that Shaun finished powdercoating the Breyton faces and they will be enroute shortly=D
                      Slowly but surely getting the car together.
                      I started off by installing the new speed sensor, o-ring, and bracket. I don't remember there even being an o-ring on it before, which would explain why my diff used to leak down the face. The diff cover didn't have any sort of gasket before though either=/ I bought a new bracket because it would be a shame for everything to look new, and then have a rusty bracket.
                      I then applied Indian Head shellac to the new paper diff cover gasket and installed it.
                      While I waited for that to cure, I cleaned up my steering rack and installed my Condor Speed Shop power steering delete. I figured new crush washers would make sense here as well.
                      The rack still needs more scrubbing, but I don't have access to water at the shop.
                      After that the diff cover was ready to install. I had my handy dandy blue loctite on hand and dabbed a little on all of the bolts for the rear subframe. Everything is tigthened down now. I'm debating on installing it now, or waiting until I make the new hardlines. I also need to paint my calipers and rotor hats, as well as installing my stainless mid and rear brake hoses.
                      I would have continued to work on the car, but I had plans to fix the exhaust on my MK3, as well as give it a quick paintjob. We ended up not having time for the paintjob, but we got the exhaust done=) Time to cut some springs this week hopefully.
                      Updates to come on Wednesday, as always=)
                        sick innercooler on the golf. I love 1.8 turbos
                          lol
                          And to comment on the rainstorm comment you replaced. I tested it out by pissing in it after it was done. It blew a badass piss mist cloud. There was also beer mixed in there too. It also helped me find the only exhaust leak=D
                            lol
                            I think its time to install a flamethrower tip.
                              Already thought about it before we welded the tip on=) It may be coming in the future.
                                ohhh jesus. that exhaust :lol:
                                  That reaction is exactly why I did it=)
                                  • JeffJ
                                    JeffJ
                                    Jeff
                                    Earl! That exhaust is freakin awesome. The truck guys will be jealous.
                                    1976 530i e12
                                    1990 325ix e30
                                    1992 325i e36
                                    1995 740il e38
                                    2001 330xi e46
                                    ^More to come :)
                                      It is even more awesome when it is cold like this morning and it has a nice plume of air coming out of it=)
                                      Yesterday was fantastic=D
                                      Four of these showed up:
                                      Which led to this:
                                      That led to this:
                                      Front (17x9.5 et14 3" lip)
                                      Rear (17x10 et8 3.5" lip)
                                      Backside
                                      They are all hand tight right now because I couldn't find a 12 point 8mm socket for the life of me. I also need to pick up some silicone to seal them.
                                      Tonight I will be at the shop for a bit and then I will be doing some fiberglassing and shaving hopefully. I will also most likely put a teeny bit of work into the MK3. We will see.
                                      • H
                                        H
                                        Hammerdown
                                        The cat wants to be let out
                                          Looking good dude!
