    What's the status of the engine bay shaving? Make sure you have a helper and 2 jacks for re-installing the subframe. Or do like I did and lick some undercoating from under the car, mutate into some sort of beast, and install it by yourself (not recommended)
      I just remembered that I would like to redo the undercoating in the back before I put the subframe in....I can do that right quick hopefully. The bay is ready to be welded up, so I need the subframe in so this sucker can roll to a different location to be welded=)
        A rear diff swap is a 2 person job, I couldn't imagine trying to bolt up the entire rear subframe solo.
          I made a little progress yesterday.
          I started off at work by slimming up the headlight harness to make it easier and nicer to tuck around the back to hide them.
          Before:
          After:
          I am going to bend the connections to go at a 90 and then make a cap that covers the connection. I ended up breaking a connector from bending it too much, so I need to find a replacement.
          When I got to the shop I started installing the CV axles. It took me a bit to figure out how to get them in with the trailing arms bolted down, but I got it.
          You can see that the diff cover is missing. I was sick of how nasty it looked and I didn't want to take the time to polish it.
          Trololololo
          Sorry Brian, I had to=P
          It is the same color as the trailing arms and subframe main support. I also pressed in the diff mount while the cover was off.
          Then I reinstalled it on the diff. (two pictures that are at almost the same angle)
          Then I figured I might aswell finish it off with two of the final pieces.
          I need to loctite all of the bolts and torque everything down before it can go on. I am also adding a fresh coat of undercoat today after work.
          I brought the barrels home with me and decided to set them around my livingroom with the lips on top of them. Some crappy pictures to get the idea:
          Fronts (17x9.5 et14)
          Rears (17x10 et8)
          That is all for now=)
            I figured a before and after of the subframe would be a good idea (except I don't have the brake lines or calipers on yet)
              Looks fantastic!
              are you some sort of bat man?  bro, do you even sleep?
                Thank you sir. It look better in pictures, but it is way better than what it was.
                Also, I awake at 2:40am to start my day. I take a shower, eat breakfast, drive to a coworkers house to carpool, and then get to work to work at 5am=) However, this week I have not been driving with the coworker, hence why I have been at the shop more than usual. I will be going there again tonight and maybe even Friday=D
                • StewCrewS
                  StewCrewS
                  StewCrew
                  So much time for activities!   I love how that rear end looks with the bags bolted down too.  This thread is awesome.
                    wow. awesome progress Earl.
                      I like how it looks too. Just need to make my brakelines now. I also need to paint my calipers, but am unsure of what paint to use. Thank you for complimenting on the awesomness=D
                      Thank you sir. I am starting to feel motivated again=)
                      • merlM
                        merlM
                        merl
                        That looks amazing ... really wish i could have done all that with mine but that was just more than I was willing to do. Great work !!
                          Thanks bud=) I figured I would do it while the whole car was down. My subframe bushings were destroyed before. The car will feel completely new after all of this. I'm excited.
                          • merlM
                            merlM
                            merl
                            I did almost every bushing on my car last year (skipped trailing arm bushings) and was very very happy with the end result.
                              Did you replace them with OEM bushings, or did you end up going with poly bushings?
                              • merlM
                                merlM
                                merl
                                OEM up front (750i control arm bushings) and poly for the rear subframe bushings.
                                  What durometer bushings did you go with? 7 series control arms work for you? What's the advantage?
                                  • merlM
                                    merlM
                                    merl
                                    It's an Aluminum M5 control arm with the 750i bushing pressed in. It is a bigger and more rigid bushing. That connection on the e28 is what causes the dredded shimmies these cars get.
                                    I have no clue what durometer .... this is the bushing though - http://www.powerflex.co.uk/road-series/product-details/Rear+Beam+Bush/725.html
                                      Did that bushing completely solve the shimmy issues?
                                      • merlM
                                        merlM
                                        merl
                                        Yes ... but I did replace every part in the front along with those so it is probably a combination. These tend to last a lot longer than the oem e28 part.
                                          Merl, do tell (in PM if you'd like so we don't thread-jack Earl) about this shimmy thing and what not. I get shimmy's occasionally.
