  4. e34 Touring
e34 Touring
269 Posts 26 Posters 4.5k Views 1 Watching
    Looks so much better! I did the same with the tails on my e46 touring.
      Loving it!
        great improvements! A friend of mine used plasti-dip to shadowline his car. I know its the popular paint to use, but he ended up with bad results. It didnt stick very long. What did you do for prep on the trim? Just a de-grease and a scuff with some scotch brite?
        • merlM
          merlM
          merl
          How many coats did you do ? and did you razor blade the edge so you didn't tear the plasti-dip when removing the tape ?
          I am doing this soon...
            we will see how long it lasts. i scuffed lightly with a scotch brite, yes.  i did in on my early e30 way back when, but only had it for a year (no problems in a year though).  out of the 3 choices i liked plastidip the best because real trim paint or tape are much harder to fix in the event that they go bad or get damaged. with plastidip you can just respray right over the old stuff or peel it off fast, no prep needed.
              5 coats, and yes you have to razor blade in areas where the tape comes close to the trim or you will peel it all away. its not like regular paint where you just tear the tape of in joy/aggression, you have to take your time. its easy to rub off after you first do it, but now that its cured i tried rubbing it and it was solid.
                replaced front thrust and control arms yesterday. pretty straight forward except i dont know how people fit the 22mm box wrench on the nut near the front crossmember. i refused to modify my snap on 22mm so i cut up an old generic 7/8 to make it fit, and it worked like a charm.
                i was in a hurry so i kept forgetting to take pictures.  heres the modified wrench:
                and heres the steering plate.  for the e34, its bolted to the bottom of the front strut assembly, then the control arms/tie rods are bolted to it. easiest procedure is remove tie rod, remove control arms from car, then remove steering plate.  bring the plate to your bench vise and hammer the ball joints out with your fork and reassemble.
                  did a full detail today (wash, clay bar, polish, wax, trim restore) and was able to take some shots. wish i had finished my style 5s for this, but the stock wheels are clean, at least.
                    Car looks great in person Dan;) On style 5's it'll look perfect.
                    • alexwA
                      alexwA
                      alexw
                      I saw you in Kenosha the other day. I thought, who's that cool dude in a E34 touring... I'd like to be his pal. Little did I know it was you!
                      You should call me some time when you're in town. I can drool over your car and stuff.
                      alexw
                      332ti - Work in Progress
                        thanks guys.  will do alex, during the summer i get down there often enough.
                          lookin' good
                            Nice pictures! Cant wait to see it on style 5's
                            • The Full BananaT
                              The Full BananaT
                              The Full Banana
                              Looks awesome. Good work, Dan.
                                thanks guys.  finally got around to finishing the style 5s.  (5 months later)
                                they're not perfect, but they are going to be daily driven so that would be a pointless endeavor in the end.
                                will hopefully get them mounted this week.
                                  Good job Dan:) Those will look great on the touring.
                                    thanks. i decided to not use any fancy products on the lips, just waxed them and they kept the same shine.
                                      Good. Sharkhide is a pain to apply and it still doesn't go on absolutely flawlessly=\
                                        those are going to look great.
                                        in4morepics
                                          finally mounted.  was 10 min early to work so I stopped and snapped a shot or two:
