    That would be rad. How much would you sell for it roughly? 9202847917. Have any pictures?
    • StewCrewS
      StewCrewS
      StewCrew
      I dont know, gotta see if you like it first hahah.  I'll throw some pictures your way tonight though.  I have to go to dinner for mi madre's birthday before I can work on my car.
      • JeffJ
        JeffJ
        Jeff
        rampelsauce said:
        SHOP PARTY!
        yes^!!!
        1976 530i e12
        1990 325ix e30
        1992 325i e36
        1995 740il e38
        2001 330xi e46
        ^More to come :)
        • StewCrewS
          StewCrewS
          StewCrew
          Also pointing out that I pretty much went full retard yesterday.  The reason the motor mount stud wasnt long enough was because the mount arm was upside down.  I forgot the motor sits so tilted and that the mount should be close to the headers.  Whoops
          • JeffJ
            JeffJ
            Jeff
            ha it happens after working on them for a while
            1976 530i e12
            1990 325ix e30
            1992 325i e36
            1995 740il e38
            2001 330xi e46
            ^More to come :)
            • StewCrewS
              StewCrewS
              StewCrew
              Worked on the motor late last night but ended up getting overwhelmed when I got to the harness/fuel rail. Hopefully having so better luck today.
                I drove past the shop on my little tune run, everything was locked up so I assume you werent there yet.
                • StewCrewS
                  StewCrewS
                  StewCrew
                  I'm on my way there right now. I ended up getting home at 2 this morning so I needed a good sleep
                    Shop Party  ever happen?? And how far did you get on the motor today?
                    • JeffJ
                      JeffJ
                      Jeff
                      any updates yet??
                      1976 530i e12
                      1990 325ix e30
                      1992 325i e36
                      1995 740il e38
                      2001 330xi e46
                      ^More to come :)
                        Jeff said:
                        any updates yet??
                        +0.21
                          There will be some great updates. Let's just say I got there at 2:30, and just got home now.
                            I know its going to be good so I will just get this over with:
                            • StewCrewS
                              StewCrewS
                              StewCrew
                              Saturday morning the motor looked like this
                              EE45561F-EBA6-4490-AAF6-963AC5FE507F-130
                              Spent a total of 12 hours yesterday with a lot of help from Jeff, Earl, John, and a couple of the Lower Standards guys, the motor is in! The harness is on and once I get some new clamps for the fuel lines and put the drive belt on, it should be ready to start!
                              47B9B140-CBFB-4602-BBE3-DBB79E1DB9D7-130
                              • JeffJ
                                JeffJ
                                Jeff
                                Sweet working on it today?
                                1976 530i e12
                                1990 325ix e30
                                1992 325i e36
                                1995 740il e38
                                2001 330xi e46
                                ^More to come :)
                                  Yesterday was a blast. I just woke up:P
                                    Question- how should I effectively take my radiator core support off? Hack it off? Mine is kind of bent, so I at least have to build the bottom part custom. Hopefully my front end comes together and lines up...
                                    • StewCrewS
                                      StewCrewS
                                      StewCrew
                                      I cut the middle section out first, leaving only the 4 corners. Then from there it's just drilling out tack welds. My lower part was so rusted that I couldn't even find the tack welds, so I just used an impact chisel on the seams. The tops where the fenders sit on was easy, but the lower parts were kind of a pain. I pretty much hacked the bottom ones off. Because drift car.
                                      When you pick up those motor mount arms you're welcome to swing by and check it out.
                                      • StewCrewS
                                        StewCrewS
                                        StewCrew
                                        The m50 runs, but it's leaking oil from the front of the head
                                          keep me in the napa know how of how it plays out, the pic was interesting
