    You know exactly who would have told me they wouldn't be a stretch. Lol Thou who hast not posted today. Also, those are just pictures from offline. My faces are still in Delaware and the lips are in California.
    • StewCrewS
      StewCrewS
      StewCrew
      "He who must not be named"
        Just got two pictures via Delaware
        I cannot wait to see how they look covered in powder and clear=)
        • JeffJ
          JeffJ
          Jeff
          wheels are cool looking. where are they getting dipped?
          1976 530i e12
          1990 325ix e30
          1992 325i e36
          1995 740il e38
          2001 330xi e46
          ^More to come :)
          • The Full BananaT
            The Full BananaT
            The Full Banana
            the wheels are cool, but the tires are unfortunate at best.
              The faces are being powdercoated in Delaware.
                I got a little done yesterday. The carbon was CAKED on. I had to let the alcohol soak in multiple times. I ran out of scotch brite pads so I will be finishing up Saturday.
                Before:
                After an Hour:
                I'm trying to think of an easy way how to get the rest of the carbon out of the reliefs.
                Here is how I had to leave off yesterday:
                It was way too cold and rainy to try and paint anything on my rear subframe too=/
                In excellent news, the wheels got their first coat of powder yesterday. They would be done, but Shaun ran out of clear. Not a problem. They should be all done next week.
                  what are you using to get the carbon build up off? I.e. using a scotch pad to get it off the face of the cylinders, use a screwdriver/plastic puddy knife as an edge to get it down in the reliefs.
                    All I've used so far is red scotch brite and alcohol.
                      use a plastic putty knife to get in the reliefs, put the scotch pad down, then use the edge of the putty knife to get the pad in the relief and scrub like a mofo. I'm sure using just the putty knife would work too
                        Thank you. Kyle will be out Saturday to check my head and my cylinder bores.
                        • JeffJ
                          JeffJ
                          Jeff
                          use some carb cleaner or what i used to clean all my engine parts was diesel. it works just like the chemical used in a parts washer. like brian said use a plastic putty knife of a screwdriver just don't dig really hard and gouge the piston.
                          1976 530i e12
                          1990 325ix e30
                          1992 325i e36
                          1995 740il e38
                          2001 330xi e46
                          ^More to come :)
                          • JeffJ
                            JeffJ
                            Jeff
                            ^ well that was a little late
                            1976 530i e12
                            1990 325ix e30
                            1992 325i e36
                            1995 740il e38
                            2001 330xi e46
                            ^More to come :)
                              I got some backed scotchbrite pads from work just now. I shiuld be able to get the remainder off well with them.
                                dang, those before and after pictures are something!
                                How long did it take you to get all that carbon off?
                                  Just getting the one almost done, the other half way, and the head surface took about an hour. lol
                                    dang. iron elbow award.
                                      I had to keep switching hands. lol
                                      • JeffJ
                                        JeffJ
                                        Jeff
                                        use diesel or carb cleaner it will come right off. an hour of scrubbing. that made my arms start hurting
                                        1976 530i e12
                                        1990 325ix e30
                                        1992 325i e36
                                        1995 740il e38
                                        2001 330xi e46
                                        ^More to come :)
                                          I was just looking through old pictures yesterday and found a few that I don't think I ever posted. I cannot wait for the car to have a fresh coat of black=) I should have also cut my bumpstops way back when. It definitely sat too high. Definitely needed spacers too. Oh well=)
