  4. my E30 story
my E30 story
205 Posts 14 Posters 3.5k Views 1 Watching
  • johnprusinskiJ
    johnprusinskiJ
    johnprusinski
    I found a picture. There were no numbers on it I swear. I got it to work and the car seems back to normal.
      yay, so it runs?!
      • johnprusinskiJ
        johnprusinskiJ
        johnprusinski
        Yeah, it runs pretty well
        • johnprusinskiJ
          johnprusinskiJ
          johnprusinski
          Update, I tried getting the diff out today, but I don't feel like taking out the driveshaft right now, and my heat is running out. I'll try and tackle it tomorrow if I feel like it.
          • StewCrewS
            StewCrewS
            StewCrew
            And so it starts ;)
            • johnprusinskiJ
              johnprusinskiJ
              johnprusinski
              Hahaha jake you need to come motivate me with beer now.
              • StewCrewS
                StewCrewS
                StewCrew
                If only I could tag Joe somehow...
                  You arent taking the entire driveshaft out are you? no need to do that to drop the diff just in case thats what you were thinking.
                  • johnprusinskiJ
                    johnprusinskiJ
                    johnprusinski
                    I unbolted the drive shaft from the diff and then the part in the middle and it still wouldn't come out. Is there some trick? I couldn't get it out to save my life.
                      http://www.davelength.net/car/diff_swap.html
                      This little writeup does a fine job of explaining what needs to be done. The particular hangup you are having can be resolved with what he says here towards the bottom of the page:
                      "The bolts screw down through the bracket into the top of the differential. You can get to the lower two with either the ratchet or the combo wrench. The top two (towards the rear of the car) can only be accessed with the combo wrench, since there is not much room between the bracket and the bottom of the car. Make sure that the floor jack is positioned to hold the differential once you start to take the bolts out. Once the bolts are out, slowly let the jack down, balancing the differential with your hand. The back of the diff will need to drop down just far enough to get the mount below the mount bracket, then the diff will need to move towards the rear of the car, to separate it from the driveshaft. Once the driveshaft bolts are clear, slowly lower the differential all the way down. At this point you can pull the jack and diff out from under the car, and set the differential on the ground."
                      If that isnt working out too well then you will need to loosen the collar nut on the driveshaft. You can see it in the picture below, it is just behind the center support bearing. When you loosen the collar nut on the driveshaft you can collapse the driveshaft about 3" which is plenty enough to separate it from the diff input flange.  Getting to the driveshaft means possibly dropping the exhaust, and dropping the heat shields which can be a little tedious, but the fact that the PO of your car pad-locked the trunk means he may have done some other nutty things like removed the heat shields under the car which would make it easy to access that collar nut. It may be worth a quick look. Hopefully you dont have to deal with the driveshaft at all but loosening the collar nut is another option you have if the normal diff removal method just isnt working.
                      Just a note in general. The two-piece driveshaft is balanced as a unit. The last time I pulled my diff, the collar nut wasnt quite tight enough and the rear half of the driveshaft came out with the diff. Luckily my driveshaft is only a year old and the balancing alignment stickers are still on there and easily visible, but if you find yourself ever needing to remove the driveshaft, make sure to make a mark on each piece with paint so that you can re-align the shafts properly. Otherwise you will get some nasty vibrations at freeway speeds.
                        I didn't mark mine when I dropped my diff, pulled the 2nd drive shaft out with the diff, threw it back on. It's still fine. Just some insight.
                          Yo Brian, im really happy for you and imma let you finish, but that kind of behavior doesn't fly when you are a guy that measures things to the 4th decimal place on a daily basis.
                          (O__O  )
                          jk, glad you arent having driveline vibrations, consider yourself lucky.
                            You got lucky. Snap is right. It can cause some serious vibration if not assembled right. They balance driveshaft assemblies for a reason=)
                            • johnprusinskiJ
                              johnprusinskiJ
                              johnprusinski
                              ok i actually see now. ill try again today after school. you guys are a big help.
                              • StewCrewS
                                StewCrewS
                                StewCrew
                                (O__O  )
                                  Honestly, they balance just the drive shaft, its self. not mounted to the diff, or CSB. So that bitch SHOULd be able to go in on any spline variation. Not the one it came off of. Atleast, this was true for Chevy's. Oh well, my E28 runs just as she used to. :)
                                  • johnprusinskiJ
                                    johnprusinskiJ
                                    johnprusinski
                                    I e decided to go into an intense study today, and when I say study I mean I'm watching too gear.
                                      I have seen a Toyota Matrix with "CPT SLO" for a plate as well as a Jag XK8 with "STIG". I need to find a "JEZZA" and "HAMMOND" plate to complete the set.
                                      Whats next after the diff?
                                      • johnprusinskiJ
                                        johnprusinskiJ
                                        johnprusinski
                                        Haha I could get a custom plate when I register it :)
                                        • johnprusinskiJ
                                          johnprusinskiJ
                                          johnprusinski
                                          I got the old diff out. I'm getting the second diff all cleaned and buttoned up.
