  4. e34 Touring
e34 Touring
269 Posts 26 Posters 4.5k Views 1 Watching
    got some good stuff in the works like official wibimmers stickers for +5 hp.
    and yeah the cargo capacity is great. a 5ft  x 2ft x 2ft  TV stand fit in the back. then add the roof rack capacity in and its perfect for long camping/fishing trips.
      Thing looks nice! Price is steep as hell though.. you could have snagged a nice E46 for that price.. or an E39. =\
      None the less. I can't wait for your OEM+ look to be added Dan!
        OR AN E46 M3, what the hell were you thinking!!!!!!!!
        http://www.autobidmaster.com/carfinder-online-auto-auctions/lot/14908702/COPART_2003_BMW_M3_NON-REPAIRABLE_VEHICLE_CERT_MARTINEZ_CA/
          Looking at the mileage and being rust free, that price is what I would pay=) Just wish they were available in manual=(
            dont be silly guys, re-read the first post. i payed 3,900 for it.  market value was probably more like 3,600 for this car, but it was the only one in the entire damn state so i talked them down best i could.
            the salesmen had a boner for the low miles, so he wouldnt budge lower.
            i could have gotten a similar e34 sedan for prob 1k less, but than i wouldn't be able to get groceries.
              That's a better price. now theres a 525iT on CL for like $1700. I'd totally get it. But I like the E30 touring a hair more..  =\
                I might be literally getting this
                  finished the bixenon retrofit today!
                  Hack up euro smoked headlights and fit new projector:
                  Seal up projector and get all the adapters/plugs in place: (high beam adapter, high beam splitter, HID ballast, and euro city light plug)
                  Tear down e34 front end and install wire harness (has to be wired across the front where the factory wiring crosses)
                  Install lights
                  All in all, easier the third time around but still time consuming and the v8 e34 makes it a pain in the ass. I'm about to throw the remote booster into lake michigan.
                  The output is great and 4 high beams is fantastic. With the 55w ballasts and philips 85122+ bulbs the output color is barely whiter than stock halogens, which i love.
                  also added are the smoked turn signals
                    Those smoked corners look perfect!
                      i have to report that my sealing/venting job worked much better this time.  no water in the headlights with them off and went through an automated carwash...awesome...only a little fogging inside while running the lights in some wet snow/light rain, which cleared up quickly after the lights were turned off. hopefully the seal will last.
                      also, i ordered some early model e34 side mirrors (they look like the e30 mirrors) to replace the ugly giant square mirrors that came on the later cars.
                        did my shadowline today with plati-dip:
                        rear plate filler, all red tails with lamin-x and debadged:
                          Looks so much better! I did the same with the tails on my e46 touring.
                            Loving it!
                              great improvements! A friend of mine used plasti-dip to shadowline his car. I know its the popular paint to use, but he ended up with bad results. It didnt stick very long. What did you do for prep on the trim? Just a de-grease and a scuff with some scotch brite?
                              • merlM
                                merlM
                                merl
                                How many coats did you do ? and did you razor blade the edge so you didn't tear the plasti-dip when removing the tape ?
                                I am doing this soon...
                                  we will see how long it lasts. i scuffed lightly with a scotch brite, yes.  i did in on my early e30 way back when, but only had it for a year (no problems in a year though).  out of the 3 choices i liked plastidip the best because real trim paint or tape are much harder to fix in the event that they go bad or get damaged. with plastidip you can just respray right over the old stuff or peel it off fast, no prep needed.
                                    5 coats, and yes you have to razor blade in areas where the tape comes close to the trim or you will peel it all away. its not like regular paint where you just tear the tape of in joy/aggression, you have to take your time. its easy to rub off after you first do it, but now that its cured i tried rubbing it and it was solid.
                                      replaced front thrust and control arms yesterday. pretty straight forward except i dont know how people fit the 22mm box wrench on the nut near the front crossmember. i refused to modify my snap on 22mm so i cut up an old generic 7/8 to make it fit, and it worked like a charm.
                                      i was in a hurry so i kept forgetting to take pictures.  heres the modified wrench:
                                      and heres the steering plate.  for the e34, its bolted to the bottom of the front strut assembly, then the control arms/tie rods are bolted to it. easiest procedure is remove tie rod, remove control arms from car, then remove steering plate.  bring the plate to your bench vise and hammer the ball joints out with your fork and reassemble.
                                        did a full detail today (wash, clay bar, polish, wax, trim restore) and was able to take some shots. wish i had finished my style 5s for this, but the stock wheels are clean, at least.
                                          Car looks great in person Dan;) On style 5's it'll look perfect.
