1.8k Posts 58 Posters 0 Views 1 Watching
    You're a pimp for owning a caddy. I'll always want one.
      Mine was a huge shitbox, but it was still way better than the mk3.
      More goodness. I just found out I can order my lips and they'll be ready in two weeks. Placing my order in the next few days.
      • StewCrewS
        StewCrewS
        StewCrew
        I miss the dirty thirty. I'll have t swing by some time this week!
          Yes you will;) Called in sick for work yesterday to work on the car. Update from it most likely Monday:P
            I called in sick on Friday to go in and work on the car. I now need it to get warm out so I can paint these parts and reassemble it all.
            I started off by slipping with a drill and hitting the trailing arms yet again. Somehow a tap followed.
            One of them is dead nuts in the center, the other is slightly off=( I don't believe it'll be much of an issue.
            I grabbed a new wire wheel and put it to good use.
            Do you think the paint should hold pretty well with that little bit of rust dust left? I can never seem to get it with a wire wheel=/
            I also decided to snap a few pictures of the rear brake lines. I am so glad that I decided to do the rear subframe now.
            I'm hoping I can find a way to paint some of these items on Wednesday. I also have a few lists of parts that I need to order.
            The wheels are in transit, and I will be ordering lips shortly. I also decided on a color for the centers=) I most likely won't make my June deadline, but I have not given up.
            TTFN
              Looking good earl, go with stainless braided brake lines! I want to eventually convert mine to that, but all my lines look good
                I will be using braid stainless lines for the rubber flex sections. I will just be using normal brake line for the rest. The car will not see winter under my ownership so they should be fine.
                  Gotcha gotcha. Should look good either way sir!
                    I went out to the shop yesterday, only to leave after an hour so that I didn't freeze to the floor.
                    I did come home in time to receive a pleasant gift:
                    Only two came. The other two are somehow in Ghana, Africa 0_o
                    Then I got to work and split them=)
                    Hopefully the other two show up within the next week or two.
                    I also was surprised to see the width of the lips. I initially read that they would be 1" lips. Upon measuring, I found out the lips are 1.5". This is excellent news. Now I'll be putting 3" lips up front; instead of 2.5", and 3.5" lips out back; instead of 3"=D
                    More updates Saturday.
                      Yussss, kinda look like AMG rims
                      • JeffJ
                        JeffJ
                        Jeff
                        From what I can tell, it is really straight forward=) You bought and OEM gasket right? I hear nothing but bad things about the Victor Reinz gasket.
                        Oem gasket was used. Tried the victor reinz 2 times and did not last very long at all on the ti.
                        1976 530i e12
                        1990 325ix e30
                        1992 325i e36
                        1995 740il e38
                        2001 330xi e46
                        ^More to come :)
                          AMG wheels were made by OZ as well. Hence the similarities. These wheels were build in November 1992. They have the production tag still on=)
                            nice, keep me posted on those one set of rims. I think I'd rock 'em well on the E28!
                              I was shooting to paint all of my rear subframe parts Saturday....but had too many shenanigans and just ended up cleaning things when I actually did work. Parts will be painted this Saturday....Hopefully=)
                              I did however finally finish my headlights. I wanted to mimic E30 Hella smoked headlights, but with an e36. I have never seen crosshairs in e36 lights so I figured I would give it a shot. Here are before and afters of the lights straight off the car to being finished.
                              Before:
                              After:
                              Before:
                              After:
                              Before:
                              After:
                              It was hard capturing the crosshair. I need to get white bulbs instead of the stupid blue ones that they come with.
                              I also got a fancy package Friday.
                              I now have all four disassembled and cleaned. The faces are being shipped today to get powdercoated=)
                              Splish Splash Breytons takin' a bath=)
                              That is all for now=)
                                That bathtub ring! Gunna make your bathtub look like this:
                                I'm kiddin. What color are you powder coating the faces?
                                  I bleached it all when I was done=) Now it looks good in there. lol I'm doing uh.........purple faces=D
                                  Just Keeding. You will see soon enough.
                                    Purple would look crazy. Aren't you going with a silver flake?
                                      Yes. lol No flashy colors for me.
                                      http://www.powderbuythepound.com/SPARKLE_SILVER/
                                      I just want everything to look nice and simple. The lips will speak for themselves. I just want a car that looks nice and cleanly done.
                                        Should look damn good man! =]
                                          I did some small things yesterday.
                                          First, I ordered my tires. I opted for Hankook HR2's. I see that they have a pretty soft sidewall so they should stretch easily. I'm going for 205/40's in the front and 215/40's out back. I got them for $350 shipped to my door.
                                          I also found out that the lips are in stock and I am placing my order asap. These wheels will be together way faster than I had thought.
                                          I've been contemplating making a set of all red tails. I then remembered that I am getting a NOS set of amber tails. I figured since my current tails have some minor spider cracking, why not hit them with some model paint? So I did. I used Testors 1605 Candy Apple Red paint with Testors clear. They turned out really well. I just need to wetsand and buff them.
                                          Started off by masking them off:
                                          I then layed a nice even coat of red. Somehow it only took me one coat to achieve the color that I needed, and I had no runs.
                                          I removed the tape on this one to ensure that it matched well. I also wanted to compare a before and after.
                                          It looks slightly off in the pictures due to it being a more matte finish at the moment, and I couldn't get a heads on shot.
                                          I then taped up the second light to be able to shoot color and clear right after one another.
                                          Then I just buried them in clear with a heavy coat. I wanted to put enough on to make a nice thick layer, but have no runs. It worked out really well.
                                          I'm going to let them dry for a day or two, and then do the wet sanding and buffing.
                                          Hopefully I'll get something done at the shop tonight too. I can't think of much to do without a wire wheels for the bay, and any of my rear subframe or paint. haha I'll update again tomorrow.
