  4. DIY: Refinishing alloy wheels (polished lip)
wheels
12 Posts 7 Posters 131 Views 1 Watching
    After steel wool and cloth:
    Posted Image
    Now, relish in your mighty ability to turn rough metal into something worthy of Nelly's grill. To protect your awesome work, tape over your polished area with painters tape for the painting.
    Do the edge where the paint will meet first, and very carefully
    Posted Image
    Then do the rest
    Posted Image
    STEP 4: LET THE AEROSOL FLOW
    Now that you have your wheels stripped, and the lip polished, its time for paint.
    Start with your clean metal primer on the inside of the wheel. I chose white because silver will cover over white easily. You arent doing body work so you dont need high-contrast. Silver primer would make it hard to see your coverage.
    First coat do lightly, concentrating first on getting any hard-to-reach areas like in lug holes, side of spokes, etc.
    Second coat lay on heavy
    Primed:
    Posted Image
    Wait for the primer to dry enough to flip it and rest it on the primer. Mine was dry enough for this after a couple hours.
    Repeat the process on the front of the wheel.
    Face primed:
    Posted Image
    Make sure to wait the required time before applying your base/clear. The primer I used required 48 hours of dry time before applying any other paint. ITS VERY IMPORTANT AND NOT JUST A SUGGESTION. There are well-educated chemical engineers deciding on the instructions on your cans of paint. I was in no rush to finish my wheels so I used this schedule for painting each wheel:
    Day 1: primer back of wheel
    Day 2: prime front of wheel
    Day 3: base/clear back of wheel
    Day 4: base/clear front of wheel
    If you are trying to get the wheels done in a more reasonable amount of time so you can start pimping your wheels STAT, you could polish all the wheel lips first, then follow the above schedule but do all 4 wheels at once. You could probably do a set of wheels in a week properly that way.
    OK where was I? Oh yeah base/clear:
    Make sure there is no dust/debris that found its way onto the surface.
    I like to do two light coats followed by a heavy coat for the base. Follow it up immediately with your clear. You can apply many coats (4-7) within the 1 hour typically allotted for spray paint. If you let the base dry, you will have to wait for it to completely cure before doing the clear (7 days or some such crap). For the clear, I usually do one light coat, followed by a heavy coat. Make the heavy coat as heavy as you can without the paint running. That part takes practice, i still screw it up.
    Inside with base/clear:
    Posted Image
    Again, wait for the paint to be a little more than dry to the touch to flip it over. I waited overnight, but a couple hours should suffice.
    Face with base/clear:
    (IMAGE COMING SOON)
    IMPORTANT: Try and remove any masking tape which touches your new paint as soon as possible. You'll have to be super careful (much like playing the board game Operation. BZZZZZT!) to not touch the wet paint, but if you let it dry it may peel away your new paint if you remove it later.
    STEP 5: DRINK AND BE MERRY
    You've probably f*ed something up, but unlike committing a felony, you can have a do-over so dont sweat it. With this particular set of wheels, I did not follow the proper drying times on the first wheel, so I had to sand down and re-clear the first wheel.
    Have a victory beer anyways. (You should have been drinking beer from the get-go, but better late than never)
    VICTORY:
    Posted Image
    Posted Image
    • alexwA
      alexwA
      alexw
      Thanks for the DIY, I'm sure I'll be using it in the future!
      alexw
      332ti - Work in Progress
      • e92boostE
        e92boostE
        e92boost
        Great write up man!
        Ben H.
        • Ryan...R
          Ryan...R
          Ryan...
          Looks really nice! I'd never have the patience to do it myself lol
          • jmo69J
            jmo69J
            jmo69
            Did this last winter but wish I had them blasted. Did it with the tires on and had the bloody fingers to prove it. Stock paint is a bitch to get off, I used 3 different strippers and none took the primer off.
            Just the polished lip:
            Posted Image
            All done:
            Posted Image
            On the car:
            Posted Image
            After the drop with the Blizzaks:
            Posted Image
            1998 328is 5sp projectors w/HIDs and angel eyes, strut brace, x-brace, Prosport gauges, all lights smoked.
            2003 325xi auto nothing special but a beast in the snow
              yeah the oem paint/primer are especially tough to remove. its best to leave it on and just scuff it up before painting. i did my last set with tires on, also makes it more difficult (worth the remounting fee)
              • L
                L
                LaCrosseJake
                I love these threads! Looks like they turned out pretty good.
                There was a guy on bimmerforums that sanded his lip while the wheel was spinning on his car. Seems like an easier route if anyone else is thinking about doing this. Just watch your fingers!
                Posted Image
                  i'd have broken knuckles! the spokes hang out over the lip too much on DS1 wheels (mine) as well as the DS2 pictured spinning. wouldnt dare!
                  • L
                    L
                    LaCrosseJake
                    It's definately riskier than the old fashioned way!
                    • C
                      C
                      Celina325is
                      that was sick, very nice. You should shoot a little video come next time around. you can show off your technique!
                      • jmo69J
                        jmo69J
                        jmo69
                        Kinda tough to polish the lip with the primer still on. LOL
