  4. chit chat thread
chit chat thread
7.1k Posts 73 Posters 72.8k Views 4 Watching
  • Ryan...R
    Ryan...R
    Ryan...
    Those may be the most boring wheels I've ever seen for $1500.
      Huge fan of those.
        Huge fan of those.
        Posted Image
        actually my sarcasm detector is busted this fine evening so I laughed at your comment even thought I have no clue if you are actually a fan of them or not. It appears these are "uber rare JDM" but they are still heavy cast aluminum wheels with goofy text on them.
        http://www.ragefaces.com/i/become_a_fan_2/img
        For $1500 i'd rather buy your S52+everything else :D
          Price is a lot yes, but I really like the simplicity of them.
          I have always liked the five spoke wheels ;)
          Buy it already!!!
            I'm a big fan of five spoke wheels as well.
              And men, don't forget that your a huge fan of men...
                Anyone think I need to weld anything over 1/4" aluminum or steel when working on cars? Debating whether or not I got the wrong welder..
                  Can't imagine there's really anything over 1/4" that you'd be welding on your car.
                    That's what I'm thinking. Thanks man!
                      I mentioned that my kiddo broke my PS3 by pulling it off the shelf. I decided to take a gander at it and was able to fix it. The wifi antenna broke off of its circuit board and there was a broken solder joint on one of the diodes. It now works again. You should all be so proud of my soldering skills. kidding.
                      If I thought I could solder worth a darn I would be building my own MS2 ecu rather than buying it.
                        Any reason for ms2 vs ms3x?
                          e-fan control would be nice (but I dont have an e-fan), vvt control would be nice (but I have an M20 :P). MS3 would be great but MS2 should be keep me plenty busy fiddling around with it. MS3 would happen if I ever went 24v.
                            E-fan control? Man I have been swamping myself if ms3x the past two days and I have not read anything about that...
                            I suppose the m20 would be silly to apply ms3 to, and ms3x is what my 24v is getting!
                              Heres a nice chart to break down the differences
                              http://www.ms3efi.com/feature-xref.html
                                Oh, just purposing a medium current output as a fan.
                                I knew that much lol, just didn't think of running a fan on the output.
                                  Im imagining the output triggering a relay which switches the fan from off/low/high depending on coolant temp. I know that someone on r3v was using the inputs and outputs to create a traction control system.
                                    Fan triggering would be nice, and completely controllable!
                                    Traction control ;) I have been thinking of how to do that for a while now.
                                      I could see how it might work out. would be a fun little project
                                        go to local scene, comment an let me know if you guys are going to the madison area meet!
                                          In theory you could just take the rear wheel speed(Abs) sensor and the front wheel speed(Abs) sensor and make a table of their inputs and when they get beyond a threshold or percentage difference have it cut fuel or spark or what have you.
                                          Once again, in theory ;)
