I got out to the shop last night and worked on a few more things.
I got most of the spot welds roughly smoothed out. The 60 grit wheels wasn't ideal, but it took them down quick.
You're probably wondering about the plastic bag in the last picture (You probably aren't but I'm going to explain it anyways)
I managed to get the lower half of the box out. This left me with a mess of wires. I do not want these wires full of dust/debris.
I will hopefully be removing all of the fuses from the box, labelling them properly, pushing them through the firewall, and placing
them back into the box this weekend. It's not going to be fun. Here is the said mess of wires:
That makes it looks like less too. That ball of wire is massive....
I did this all while waiting for Jake to show up, and swap some tires with me. Once him and his friend Brian arrived, my neighbor arrived home. He went into the garage and grab a bag of chicken feed, spreading it across the driveway. I found it quite odd to do that in winter. He might have better luck in Spring. We did not see any chickens arrive.
After that we decided to test out the tires by putting the MK3 through a snowbank. We succeeded in the fact we had too much fun....but we got it stuck really good. I'm glad that I had a spare extension cord. It worked very well for pulling me out with Jakes e46=) We decided to do that only after about 15 minutes of trying to rock the car while pinning it to win it......it's a race car doe!
We wanted chickens... we got no chickens....
So I was not in the mood to do wiring today. I then decided to go pickup an engine stand, and tear the motor down.
I started off by picking up, and then assembling, this engine stand from Harbor Freight. $50=)
I then finished removing the wiring harness from the engine.
Once that was done I started removing the accessories (alternator, power steering pump, a/c compressor) This led me to find most of my oil leaks as well.
I noticed a wet spot by cylinder 4 under the head. I'm going to do a compression test Wednesday. I also went to take off the trans and realized that I do not own any e-torx sockets=/ My bushings are still stuck in Polish customs, and my COP kit first shipped yesterday.
More updates to follow after Wednesday.
My rear bushings arrived today from Silver Project. It takes a bit for a package to come from Poland.
I asked them if they could draw a picture of anything they want on the box, to see how down to earth they are. I like doing this when I order parts:) Here is what I was welcomed with.
My COP kit got ordered to my parents by accident. I should have it Thursday. Tomorrow I will be at the shop getting things done. Hopefully ill have another update.
I managed to get my transmission and flywheel off yesterday. I then went to mount the motor on the stand, and found out the top transmission bolts are too short to use to mount it=/ I picked some longer bolts on the way home. I won't be able to make it out until Sunday, since Saturday is my mums birthday.
I also have some other exciting news. I officially sealed the deal on the Breytons. Now I'm looking at lips to order. Hopefully I'll have everything to build them as soon as they hit stateside. I'm currently waiting on the purchaser to pay for the Style 5's still as well. Hopefully that gets cleared up by the end of the week=)
I got out to the shop yesterday=)
I started off the day mounting the motor on the stand.
I then removed the coolant lines and sensors from the intake side.
At this point I got a phonecall from a potential buyer for my wheels. I meet him and his grandfather in a grocery store parking lot, and arrived back to the shop with this.
I spent some on gas=) It was $1200. I just wanted them gone to fund building the Breytons. I also took that picture because it is obligatory when you have trap house money.
I then returned to the shop and Jake had arrived. He got to cleaning the block a bit more and I tackled removing the rear subframe.
Diff looks like it was leaking a little 0_o Jake also only took one picture of the motor. The other side is clean too...
I will hopefully be dropping the subframe on Wednesday. All that is left and the lower subframe mounts.
Tah Tah for now.
