  4. E30 timing belt
E30 timing belt
13 Posts 7 Posters 0 Views 1 Watching
    Not a full rundown on what needs to be done, but perhaps a few pointers that the repair manual won't specify:
    -Remove the hood for ease of access to the timing belt area.
    -Ensure engine is at TDC as need4speed mentioned
    -Cooling fan has reverse threads. A thin bicycle headset wrench can be used to remove it, if you are having issues removing the fan and are certain you are aware of the reverse threads, then apply force with the palm of your hand on the v-belt and hit the wrench with a mallot to break it free.
    -Replace water pump while you are in there
    -Use a very small amount of gray RTV on the water pump gasket to prevent RTV from squeezing into the water passages and potentially clogging the radiator or heater core. The repair manuals I have seen do not mention RTV and many people will say you dont need it, but it doesn't hurt. I had to redo a timing belt job because it just didnt seal well enough without RTV.
    -Dont lose the tensioner spring when you remove the existing tensioner. It can shoot off to some dark abyss.
    -When fitting the belt, start on the cam gear and move clockwise. Keep the belt tight as you work it around back to the tensioner and make every effort to only have slack on the tensioner side of the belt. This will help ensure that the belt goes on easily and that the engine doesnt go out of time on its own.
    -Rotate the engine 2 revolutions and re-check the timing marks before putting everything back together.
    My first M20 timing belt job took 6 hours due to just taking my time and cleaning every part that I removed before re-installing it.
    The second time I did it, it was a 2.5 hour job.
    Replacing the cam seal and even the crank seal would be a good idea while you are in there also
      Feel free to invite me over! I have tools that are helpful!
      edit: I am in appleton
      • 6670charger6
        6670charger6
        6670charger
        May take you up on that GunMetal. Probably won't do anything with it for a couple of months yet, but nice to know a little more about the project before I start.
        Appleton, WI
          Where you located man?
            His location is above his post count :P
              Sorry I'm on tapatalk! I don't see sigs or other things. I'll check it out!
                its not a hard job, people just tend to be more pensive because of the whole 'if i do the belt wrong i will f*** up my motor' thing.
                nothing fancy to do, just lots of stuff to remove to get in there. the bentley covers everything involved.
                • 6670charger6
                  6670charger6
                  6670charger
                  Problem is that I don't have a Bentley for the E30, only the E34. Does anyone know of a good site or source to download one for the E30?
                  Appleton, WI
                  • 6670charger6
                    6670charger6
                    6670charger
                    Rowleym said:
                    It's dumb easy. Doesn't take much time at all either. I actually have a timing belt and tensioner if you would like to buy it. Where are you located?
                    Send me a PM with what you want for your timing belt and tensioner.
                    Appleton, WI
                      http://www.wibimmers.com/board/showthread.php?1175-PDF-Downloadable-Repair-Manuals
