1.8k Posts 58 Posters 19.2k Views 5 Watching
    Yeah, you gotta have the propane tank sort of heated, if it's gunna be ran in a cold area for some time, use a shitty little electric heater to heat the tank, but don't put it RIGHT ON the tank. close to it works.
      I'll have to do that:) We have the shop heated, but it takes a long time.
        Yeah, just watch some King of the Hill, you'll know all about propane, and propane accessories.
          Posted Image
            Loved that show;) Maybe Hank could shave my bay:)
              CHyeah, too bad Bobby would ruin it for ya!
                I did some stuff, and want to do more stuff today. It may be too cold for me to do anymore today though:( Pictures to come later today, or tomorrow.
                  I did some stuff
                  I'm proud of you Earl :P. post up them pics!
                    I will when I get to a computer. Doing updates with pictures from my phone takes forever:) I did end up going to the shop today to get a bit done. I took a couple pictures too.
                      I only use my phone for forums because its easier and I can post pictures effortlessly. It's called tapatalk!
                        I'm too cheap to buy the app;) I use my phone because I don't have internet at my apartment. The only times I use a computer are at work, and sometimes when I run out to my parents house. I'll add pictures from my parents house later:P Otherwise I need to make a blank text to myself, paste each Photobucket link into it, exit out each time to save it as a draft, then once I have every picture i need, I copy the entire chunk of link, and paste it here.
                          I finally got some work done. Friday I went to the shop and removed the battery tray. I then had a go with removing some of the seam sealer.
                          Here it is:
                          Posted Image
                          Here is where it was:
                          Posted Image
                          Posted Image
                          You can see some seam sealer was removed there too. I only had an hour to spend at the shop so I didn't get much more done.
                          I then thought about how my Recaro Trophies would be great in the car, but they're not black=(
                          Posted Image
                          They're mint. Only one cigarette burn on the passenger side.
                          Posted Image
                          Back to the engine bay. I went back yesterday, and removed the rest of the sealer I could get with the drill and wire cup. I also got rid of the ABS.
                          Before:
                          Posted Image
                          After:
                          Posted Image
                          Passenger side tower:
                          Posted Image
                          Posted Image
                          Posted Image
                          Drivers side tower:
                          http://i830.photobucket.com/albums/zz230/earlcharlesmeyeriii/IMAG0764_zps95df782a.jpg
                          http://i830.photobucket.com/albums/zz230/earlcharlesmeyeriii/IMAG0765_zps7f21da3c.jpg
                          http://i830.photobucket.com/albums/zz230/earlcharlesmeyeriii/IMAG0767_zps33012514.jpg
                          Full bay so far:
                          http://i830.photobucket.com/albums/zz230/earlcharlesmeyeriii/IMAG0768_zps43962f02.jpg
                          Next weekend I should be able to get a majority of the rest of the seam sealer out. I really need to pick up the pace to get this all done by June.
                            Done by June? Must be a bigger project than im imagining
                              Shaving the bay, refreshing the motor, changing all rear bushings, full exhaust, changing the carpet, recovering the headliner, tucking the fusebox under the dash, full respray, shaving rear bumper, fitting new wheels, and some other suspension related work. I'm sure I'm missing some things. Lol But most of it has to get done on Saturdays only. If it was at my place I would get it done fast, but it is 45 minutes away:P
                                I'm trying to decide on the shade of silver for the faces on my next wheels. Which one of these do you think would be best?
                                http://www.powderbuythepound.com/SPACE_INVADER_SILVER/
                                http://www.powderbuythepound.com/BONDED_VIKING_STAINLESS_STEEL/
                                http://www.powderbuythepound.com/DARK-WHEEL-SILVER/
                                http://www.powderbuythepound.com/BONDED_STARDUST_SILVER_SPARKLE/
                                  Space Invader silver because of the name :cool: or the dark wheel silver. I like both.
                                    I like the dark wheels silver too. The viking SS has a champagne color to it that I'm not sure if I like, or dislike. I think the stardust has a little flake to it. The would be cool if it isn't too flaky. What I really want is a powder to match BMW Silver Grey.
                                    The color of these badboys:
                                    Posted Image
                                    Le CSL🆒
                                    • StewCrewS
                                      StewCrewS
                                      StewCrew
                                      I think bonded viking. 1, because of the name. 2, the other 3 look the same to me. Keep in mind this is coming from someone who is slightly colorblind, so take it for what it is :P
                                        I don't remember which one I said to go with, but I'm too lazy to reopen all those links. Go with the one I said. I'm also color blind, so take this post with a grain of salt.
                                          You guys are silly=P lol I'm thinking the dark wheel silver, unless I find something close to BMW A08🆒
