I guess I'll start one here. Squeaky vents
So my e39 has developed an intermittent squeak/squeal in the vents when the heat is on. Blower motor bearing? It increases/decreases in correlation with the fan speed. Any easy/cheap fixes without tearing the dash apart? It seems to happen only when it's really cold out.
sounds like the blower motor, as it coincides with your fan speed. looks like for the e39, the upper dash must come out. here is a DIY: it says youll need an afternoon to do this (3-5 hours) but it really doesnt look that bad.
Do you notice a relationship between the blower motor squeeking and the temperature outside?
Mine likes to squeek when it's -0. But when the blower motor went on my e34 it rattled like crazy until it finally died. That was a PITA to fix.
Not to thread jack, but I've experienced the same thing in my e30. It used to be only when it was freezing, but now its becoming more frequent. Blower motor then? Anyone know of / have a cheap hookup for a new one?
