  4. 87 535is - getting started
223 Posts 21 Posters 3.7k Views 2 Watching
  • merlM
    merlM
    merl
    Test fit
    Posted Image
    Posted Image
      Hmm, sweet. I guess I'll have to attend an event, see how you do! :)
      • merlM
        merlM
        merl
        Snap Understeer said:
        He already has, and it looked to move and handle real nicely
        yep!!!
        SWEET .... We will have to get together for the drive down and pits.
          I'd like to track my E28 once I get a better suspension set up. But that won't be for awhile sadly =\
            If you just want to attend the classroom sessions, hang out at the track, and take rides with instructors then its only $30 + helmet rental at Blackhawk.
              Rather just bring my own helmet, which I've yet to purchase... =\ Idk, i'd have to hit you guy's up. I'd love to get into some autocross/head pe events. ;)
                Hey, there you are!
                http://www.youtube.com/watch?v=PFtQSHh7NXo
                What tires + suspension were you running?
                  Hey, there you are!
                  Looks like fun! If I remember correctly he has spax springs and billy sports.
                  1986 528e/5Β Β | 1994 530i/5Β | 1995 540i/6Β | 2013 X5 35d | 1998 C1500 Suburban | 1995 K2500Β Suburban
                  • merlM
                    merlM
                    merl
                    you are correct.
                    Spax springs and sports. Poly rear subframe mounts, Aluminum lower control arms, 750 bushings in the thrust arms, heavy duty diff mount, 540i/740i brakes
                      merl said:
                      you are correct.
                      You a... you should post some pictures of all that. mainly the Aluminum LCA's, and the brake set up. Also, got a part # for that diffmount?
                      • merlM
                        merlM
                        merl
                        Sure... I will get some pics and post them.
                        Diff mount part # - 33171129786
                        **This part number will cross reference as a 528e part number. The later 528e uses the same diff mount as the m535i in Europe. This is a better mount that is stronger and it is less than half the price of the US 535i diff mount.
                          Awesome. Appreciate it.
                          $80 holy eff cakes. I remember when mounts were cheaper for the STi. SHIT.
                          • merlM
                            merlM
                            merl
                            This isn't a great pic for perspective but this is how it sits with the suspension
                            Posted Image
                            • merlM
                              merlM
                              merl
                              Okay Brian, Here are the control arms and brakes. Kinda hard to tell but the brake is considerably larger than stock.
                              Posted Image
                              Posted Image
                                Is that silver M3 the one you drove down to BFR with?
                                Those alum. control arms are great! are they an OE part on some other BMW like how the E30 M3 has alum. control arms?
                                • merlM
                                  merlM
                                  merl
                                  That is the M3 from BFR.
                                  Yes, they say that they are an M5 part but I am not positive. They are part of a kit sold here - http://blunttechclassic.com/?page_id=279
                                    Looks gorgeous, how much better does that brake swap stop the car? An how hard was it to swap those into the E28. Those control arms look slick too.
                                    • merlM
                                      merlM
                                      merl
                                      There is a lot more brake there so it is a significant improvement in stopping power. Front pads are the same as E36 M3 so it gives you a bunch of options as well. On the track, I used about half the brand new pads (Textar) and I expected to use a lot more. In a panic stop on the road, the car stops right now !!
                                      The swap is bolt on and there are quite a few options ... The list below is from www.m535i.org ... Mine is a Stage 5 and is very cost effective. I think I paid $200 for the calipers and an upgraded master cylinder (The master was messed up so it is not installed). I rebuilt all the calipers with new seals and bought new rotors and pads. The bias is really good and the package performed really well on the track.
                                      Stage 1: E32/540i fronts
                                      Minimum wheel size: 15” wheels
                                      Stage 2: E28 M5/ E24 M6 fronts
                                      Minimum wheel size: TRX, only *some* 15” wheels, 16” wheels
                                      Stage 3: E32/540i fronts, E34 solid rears
                                      Minimum wheel size: 15” wheels front and rear
                                      Stage 4: E28 M5/ E24 M6 fronts, E34 solid rears
                                      Minimum wheel size: TRX, only *some* 15”, 16” wheels front; 15” wheels rear
                                      Stage 5: E32/540i fronts, E34/E32 vented rears
                                      Stage 6: E28 M5/ E24 M6 fronts, E34/E32 vented rears
                                      Stage 7: E34 US M5/US 540i Sport front and rear
                                      Minimum wheel size: some 16” wheels front; 15” wheels rear
                                      Stage 8: E31 front, E34/E32 vented rears
                                      Stage 9: E34 Euro, E31 850CSi Euro (Nurburgring brakes)
                                      Minimum wheel size: 17” wheels front; 16” wheels rear
                                        Do you have ABS/does it work?
                                          I might look into that :) That looks awesome.
                                          With your input, this post could be even better πŸ’—
