561 Posts 19 Posters 6.3k Views 1 Watching
    Yes I do to an extent. It doesn't turn out the best! Why exactly? Also, the manifold I would do would be pretty easy, and almost like a log manifold. kind of like the cast spa manifold?
    [ATTACH]765[/ATTACH]
    Super rough sketch, but you knaw mean!
      That's for a 4 cylinder son. UEL (Unequal length headers) are so chincy man. Go for equal length (or close) which means you're gunna have to add bends and wrap pipes around others. But it'll be worth it in the end, if done properly.
      Also, the key to welding onto anything cast, is to heat it up, heat it up really good with a torch, then weld to it.
        Well duh I can count cylinders man! But yea. Unequal length. Who cares. I'm more into transient response of a log type manifold. Keep the runners short as possible, and the flow decent. Good enough for me! And yes I've heated up cast for welding before.
          word! I know what you're saying. as long as you keep the flow good, you should be golden.
            or if you wanted you can just buy an M50 exhaust manifold flange, and weld to that, instead of a cast piece. It'd look 10x better, and would make welding alot less painful.
            Posted Image
            if you're going with a simple set up like this:
            Posted Image
            Weld a piece of metal rod from the Exhaust manifold to the turbo manifold, if you don't, over time the heat from the exhaust combined with the weight of the turbo/exhaust pipe pulling against it, will eventually crack it. Might as well save yourself the trouble.
            Picture found.
            Disregard his honda retardation.(the hole in the manifold) But the support bracket is shown.
            Posted Image
            This little bracket (I suggest you put in two for safety's sake) will be a life saver. If you don't, that shit can warp, and crack or worse yet, completely warp and droop touch something else in the engine bay, and catch your car on fire. (little extreme, but it can happen)
              Yup yup! That manifold is exactly what I am going for. I just need to order up some stainless.. I'm probably going to go to the machine shop and have them cut me a flange for free ;) I just need the specs and then I can get it.
                There you go.
                  Take it from Roman
                    That video had zero useful information in it. LOL
                      Is it bad that I am not even boosted yet and I am already planning out what to add after?
                        I totally feel you.. It's hard to keep focused and not just buy everything
                          Ha, I am sitting here wanting to order all of the little bits but I know I need to order some of the bigger items first!
                            Gotta have the big items to use the little ones! Even to build stuff up to hold you over! ;D
                              But I have saved almost enough to order the manifold, which is 520 bucks which took a bit and I keep almost buying the 20-100 dollar parts that won't take me long at all to save for.
                              Know what I mean?
                                Know what I mean?
                                Just keep saving man! Gotta get the manifold. What mani you going with?
                                  I have that problem daily. Like why do
                                  I need to buy an oil feed line when I don't have a manifold yet?
                                    Mini update. Swapped in that Walbro, and found some janky wiring from the PO. Not quite sure what he was trying to do.. [ATTACH]766[/ATTACH]
                                    [ATTACH]767[/ATTACH]out with the old!
                                    [ATTACH]768[/ATTACH] in with the new!
                                      Doesn't that car have an inline fuel pump too? Or is that just E28's..
                                        Maybe? Where would it be? And could I replace all my fuel lines with like hard lines that bend?
                                          It'd be between your fuel tank, and the motor. Go figure right?
                                          Posted Image
                                          Located behind the passenger rear wheel. by the driveline. Can't miss it. (dunno if E30's have this)
                                          And yes, you can change fuel lines. not that you'd really need to, unless there all rusty/corroded.
