e46 M3 non SMG transmission?
I meant skip 4th gear not pass on the car. I'm definetly goin for it.
For sure. I am going to get it fixed. I'm just sayin in the meantime she's driveable. It goes into fourth without grinding if you go a bit easy on it.
Man she ran out to about 100mph in 3rd anyway
No. Once its in 4th shes good
Just that disturbing griiinnnddd goin in
Thats what the owner is thinking also.
Just make sure the rest of the car is 100%, get a PPI done. An E46 M3 is one of the last cars you want to skimp out on, its not an E36 M3, which is really really easy to maintain. Mine is going in to have the cracked subframe fixed in a month $$$. I just had inspection 2 done, which is $1,200 on the cheap if you cant DIY ( a lot of people don't feel comfortable adjusting valve clearance on an 8,000 rpm motor). My alternator recently packed up, and at the end of the year the I will be replacing the rod bearings as well. I'm just saying you kind of really have to love these cars to put up with them. It like a girl on the hot / crazy scale. They are high maintenance and bitchy, but god are they great to drive the crap out of. Oh and this is also coming from a guy with an M3 that is currenlty deciding not to crank over
He had the subframe welded and the valves adjusted after he bought it. Rod bearing recall was done under warranty in 2004 and it had a new rear diff put in, in 2007.
Good to hear! Just remember, valves get adjusted every 20,000 miles, or less depending on how "enthusiastic" you are with the car. Also don't forget the diff fluid, the diffs are very picky. Change every 32,000 with the crazy expensive OEM fluid $140 :eek:My diff was starting to make some scary noises until I did a flush (only 60,00 on my diff).
But again, if you really love these cars, there is nothing else out there that would be better to walk out to every day. Get the car and have a blast! I know I do
Ok so I was able to sell my 530 after only 2 days on craigslist,so that freed up some extra cash. I spent a extra $2,500 and got a 2003 M3 fully loaded with no known issues. Drove het home from Minnesota last night no problems. It was hatd to see my beloved e39 go,but I'm loving the M3 even more. I would post pics but cant figure out how.
Yea. A little newer and way nicer. No transmission grind on this one.
