    et0? You can't just throw out offsets. from what I recall E30's have a factory high offset, so you're going to mexipoke like a mexicano.
      XXR and ESM seem to be the best style+fitment per dollar wheels you can get new.
      I still need to sit down sometime and figure out the best size of wheel + tire that allows for best tire availability and cost/performance ratio for track tires. I will probably do something close to 16x8 or 17x8 with summer tires for daily use. Either way, the wheels need to be light and strong. The Kosei K1 and TRM C1 wheels seem to be budget lightweight track wheel if light weight is important to you.
        Like this? Posted Image
          US factory offset E30's came with lowest offset of +30. averaging +33/40 offset. So +0 offset will be a stretch. but go for it. Hell, I can't really talk, I'm looking for 16/17x10 +5 offset wheels...
            Stretch indeed! I would love to fit some 16x10's or something close to that, but I don't think I need that kind of grip for drifting yet.. Wheels are definitely reasonable now a days.
              wheels aren' reasonable. Maybe for you 4x100 guys. 5x120 is atrocious.
                Wheels like xxr's aren't expensive at all, and I honestly don't care about brand names. I just want an okay look and light.
                  http://www.tirerack.com/wheels/WheelCloseUpServlet?target=runWheelSearch&initialPartNumber=C157025400B&wheelMake=TRMotorsport&wheelModel=C1&wheelFinish=Black+Painted&showRear=no&autoMake=BMW&autoModel=325is&autoYear=1989&autoModClar=&filterFinish=All&filterSize=15&filterBrand=All&filterSpecial=false&filterNew=All&filterWeight=All&sort=Price
                  This!
                    Rotas
                    • StewCrewS
                      StewCrewS
                      StewCrew
                      Grip for drifting? Contradicting statement is contradicting. My spares are all 15x7 or 15x6 with whatever wheels up front. Sliding 10" wide wheels would be a bitch. Also the amount of understeer from such a wide wheel in back would be crazy. I'd stay away from wide rear wheels for drifting, but to each their own :) Unless you'll have boost. Then go for it lol
                        He's boosting. But ironically, drifting is all about grip. Grip is a huge factor.
                          I'm thinking 15x8 would be perfect for drifting around 400whp? I mean, I could stretch the tire on there, and you get less grip anyway.
                          • StewCrewS
                            StewCrewS
                            StewCrew
                            More so about throttle control that grippy tires.
                            That sounds perfect! 400hp is more than enough to slide these go-karts around. And will be fun just cruising the streets too!
                              That sounds perfect! 400hp will be more than enough to slide these go-karts around.
                              Wheels/Tyres: Weds Kranze 3-piece alloys — 18×11-inch front, 18×12-inch rear, Goodyear RS Sport 245/45R18 semi-slick front tyres, Goodyear Eagle F1 265/35R18 rear tyres
                              He makes serious power. obviously you won't run 18x12's. But either way, you need to balance grip with your power. you can't go drifting on 13x5" rims, you'll just spin out, So go look for build threads of E30's with the amount of power you're looking to push, and see/ask what they run for tires.
                              • StewCrewS
                                StewCrewS
                                StewCrew
                                Jesus, who's setup is that? And what kind of power? That sounds like a car that does real drift events. Yeah when you're going 90+ you're going to want to have a setup that grips. But I don't think that's what rowleym is going for. Not right away at least ;) I was more talking the drift days at the track I go to where the fastest you'll be hitting the turn is 60-65mph. Grip isn't as big of a factor compared to fully built drift cars on professional tracks. Formula D cars run 11-12" wide wheels all day. Besides, once you get on the track and try a couple different sets of wheels you'll find what you feel most comfortable with.
                                  Really nothing special...
                                  Fuck forum embedding. I'll relink you.
                                    N/a it makes 500hp on a 4 rotor. basically dual 13Bs mated together. a ton of one off parts.
                                    • StewCrewS
                                      StewCrewS
                                      StewCrew
                                      That's a 4 rotor build. That alone is crazy. The motor itself is famous lol.
                                        I lied. 670+ HP. N/a.
                                          With 400whp, there are a lot of guys running some seriously large tires.
