    It's classier than wheel gap;)
    Took 4 hours today to unbolt my driveshaft and remove my upper intake manifold. I did a lot of pacing in that time.
      Went to take another stab at removing the motor and no dice. I tried removing the harness from the engine. There is a box(located on the intake manifold) that sends the wires to sensors all over the motor. I removed about half of the plugs to it, and couldn't reach the others. Decided to try and remove the harness from the car side. I then noticed that the harness goes down under the fusebox. I don't think there is a quick disconnect there...so now jm stuck and can't find any writeups for harness removal. I just need to get that done, unbolt the trans crossbrace, and then pull it out. Absolutely everything else is out. If anyone wants to help me pull it next Saturday I would be very happy. Since I am always there alone, it makes it too easy for me to get mad and rage quit. I need to get this all done.
        On my E30 I disconnected the ECU and pushed the harness through the firewall. Disconnected the fuel lines, engine mounts, round connector by the fuse box, oil cooler, ground to the oil pan, coolant hoses, o2 sensor wire, and a handful of other small items. I didnt need to touch the intake manifold, anything under it. I cant speak for the time removing the engine since I was doing other things, but from the time the engine was seated on its mounts upon re-installation. It was less than an hour before everything was secured, connected, and ready to run.
        It was very painless. Hope you get it figured out
          Do you have a bentley?? I know the box your talking about under the intake manifold though but no idea how the removal process goes. I'd be able to help out on sunday if your available. I work until 5 on saturdays :(
            I don't have a bentley. Always meant to get one. It sure would help;)
              Merry Christmas! http://www.mediafire.com/?gldgnyynz4y
                Downloading that now. Thanks bud. Hopefully this will help me out a ton=D
                • StewCrewS
                  StewCrewS
                  StewCrew
                  Just read through this whole thread. Awesome ti :) Hopefully you get the harness situation figured out. Theres nothing I love more than a clean, shaved..... engine bay ;)
                    Thank you bud:) I went to the shop today and got the harness off. I found out that it just went to the relays on the side of the box. I removed them and now the harness is off. I couldn't get the exhaust off of the header, so I removed the header from the head. Now I just need to take off the trans crossmember and lift the motor out.
                      Are you "deleting" anything while you are in there for the sake of engine bay cleanup? such as ABS, PS?
                        Everything to do with windshield washers(shaving the nozzles off of the hood) charcoal canister, and a/c. I may delete the abs since I hate it oh so much. I'm also adding the COP kit to rid of the ugly ignition coil. I also need new plug wires amd its cheaper to buy the COP kit, than to replace them. It's easy enough to do. Either that or black it all out. I am relocating the dme, fusebox, power steering container, and the harness running behind/over the motor. The firewall will be bare besides the brake booster/master cylinder.
                          No exciting updates yet. I'm trying to get a hold of a fellow Ti buddy who I was going to buy some AC Schnitzer mirrors from. Those will be bought as soon as he gets back to me=D I also finished modifying one of my headlights. Now to put it all back together and do a side by side. I didn't even clean the other light, so it will be a straight off of the car before, and a tidy new after.
                            Do work Earl! Sell your rims yet???
                              Nope=/ Was getting them ready to ship and then the guy bailed as I was going to purchase the packaging...
                                Go figure.. I remember you saying that.. I wish I had the money to pick them up, I'd rock them temporarily...
                                  Got the drivetrain out today;) The only thing that gave me issues was the damn bitch clip for the shifter. I started shaving the bay as well.
                                    Ryan's GF Kayla and I know all too well about that bitch clip. It's Honestly not that bad, as long as you have a new one, you can destroy the old one.
                                      The bitch clip in my e36 parts car was actually a hell clip.
                                      The straight part that should have slid out had actually mushroomed so it couldn't come out at all. The die grinder came out and took care of that situation
                                        Here is how I hooked up the hoist:
                                        Posted Image
                                        It sucked trying to get the trans up enough to pull out. I had to be almost vertical. I also had to remove the brace before the frame rails.
                                        Posted Image
                                        Posted Image
                                        I also used my spot weld bit to drill off all the brackets. The battery tray will come out when I remove the seam sealer.
                                        Posted Image
                                        Posted Image
                                        The lighting was horrible in the shop, but I didn't care about fancy pictures at the time=) I'll need to get a nice camera instead of using my phone.
                                        More shaving and miscellaneous other things to come on Saturday.
                                          wow, thats going to be quite a project! Should be plenty worth it when its done though. When I cleaned and re-painted my engine bay I didnt want to take all the brake lines and ABS pump out, but I am so glad now that I did. Are you going to stick with the M42 for the long run?
