Does anyone give a crap about handling anymore?
Yes it is.
Raising the rear end with subframe spacers, coilover adjusters, or spring pads can help bring the camber closer to 0.
The weld-in camber adjustment kits are iffy since they can slip. I would personally only run the ones with a positive-lock design like IE has http://www.iemotorsport.com/bmw/Z3-suspension-steering/adjcmbkit-lock.html They advertise 1.1 degrees of total adjustment. call it 0.5 degrees each direction. So whatever your rear camber is now figure 0.5 degrees of camber change with the adjusters and use the camber curve chart to determine what kind of height needs to be added to the rear (whether height is added using subframe spacers, spring pads, coilovers etc.) to get 0 degrees camber. If you are looking for 0 degrees camber for drag racing grip or for reduced tire wear for drifting. it may be worth considering running slight positive camber depending on your spring rate and weight transfer so that you will have 0 camber while the car is under power. For a hyper-mileage or freeway cruiser, you would want 0 degrees camber at rest so that you would also have that at steady throttle while driving.
Personally I think the reason most people aren't asking about how to get better handling is that most of us(weather we care to admit it or not) can't come close to pushing our cars to the limits of their chassis/suspensions. to make matters worse living with a truly tractable car every day to work and back on Wisconsin roads is brutal. think about it, even the serious auto-x guys consider 650# rear springs in e36 about tops if you look at the same car in bmwcup or GT 1120# rears are common place. your back can deal with that and the shell would crack it self to pieces by the end of the summer.
just my OP
Rowleym said:
Well you know, I'm building my car to drift. Lol. So please go into depth. I would rather have a more narrow tire if I can maximize the grip. Most cost effective.
0 camber = more forward grip which in theory is going to make drifting a tad more difficult but to me it is worth not having to ditch a set of tires prematurely because of camber wear.
I am no drift king but I do know that in drifting, the car setup is custom tailored to how you prefer the car to handle rather than some set formula that another guy figured out. If I had a drift car I would probably prioritize keeping my tire wear even with less rear camber and balance out the extra rear grip with a slightly stiffer rear spring.
But yes, Brian is right about how negative rear camber in the rear helps with handling. Good handling for grip driving calls for some negative camber so that the contact patch is maximized when the tire deforms from the cornering force.
Here is a nice chart for basic beginner suspension tuning
Stance = Cancer. It was neat to look at when it first came about. Now it's just asinine. For this I have created a new word.
"Stancerous"
adjective
Definition:
An over-abundance of camber, low, and "mad tyte style, bro"
Examples:
"Man that E36 M3 is clean, but mother fuck is it stancerous."
"A stancerous horde approacheth! To thine battlements!"
"Yolo bro-mo, my teggy fixin' to get stancerous up in this muh fucka."
^^^ LAWLZ!
Theres no denying that a car with a certain ride height, wheel, and tire combination looks absolutely fantastic but unfortunately it is taken to extremes.
I just wonder if this car still would have lost control if it had a stock suspension and alignment setup.
You guys an your stance-nanigans. But you're both cool guys, so we let it slide. lol.
