  3. BMW Discussion
  4. stuff e36 guys say
stuff e36 guys say
14 Posts 8 Posters 0 Views 1 Watching
    i lock my doors from the trunk.
    swap car!
    how much horsepower with 19lb injectors, a chip, and an m30 afm?
    16x9 wheels are teh shit!
    can I run 16x8 et0 wheels without rubbing?
    change the timing belt.
    i deleted my power steering by taking off the belt.
    rear camber is killing my tires.
    can I redrill style 5s?
    my fucking rear subframe is stuck!
    omg mtech car!
    its a volvo lip
    its a super eee-tee-ay
      rampelsauce said:
      I want a 410!
      hah! I've said these things in the last month
      adding to the list:
      check out my OBC
      check out my econogauge
      check out my check panel
      ditch the bottlecaps
      5-lug swap
      I did a valve adjustment and the valves are still noisy
      and my favorite :
      The factory airbox is best, you will lose power if you install an intake.
        Here's something every E36 guy says, "I'm low!" Lawl. ;3
          I don't lie when I say it though=) I'm trying to think of things I say about my car.
          This thing handles like it's on rails is probably my most common one=P
          or " ULTIMATE DRIVING MACHINE!!!!!!"
            Lol, Earl, yours is low, from what I've seen in photo's. Probably the only hella dumped one I've seen. that I know the owner of.
              battery box rust!
              I want a touring
              Turbo build
              OMG! Mint fuse box cover!
              Bent Z3 shifters are the shit!
              Gotta get some poly.
              Did you see Vlad's new car?
                someone said:
                -Just say no to Bronzit
                -push your diving boards in
                -change the timing belt.
                -i deleted my power steering by taking off the belt.
                -my fucking rear subframe is stuck!
                -check out my econogauge
                -check out my check panel
                -ditch the bottlecaps
                -I did a valve adjustment and the valves are still noisy
                -The factory airbox is best, you will lose power if you install an intake.
                -OMG! Mint fuse box cover!
                -Bent Z3 shifters are the shit!
                -Gotta get some poly.
                These also apply to E28's ;)
                • MorzadaM
                  MorzadaM
                  Morzada
                  Cuz racecar!
                  Why can't the Maples just be happy in their shade?
                    I lost it when I saw the vid! It's too true!
                      More then half Of those apply to me haha
