  4. 2011 328i Longroof - The Saga Continues
56 Posts 8 Posters 1.3k Views 1 Watching
    Congrats on the purchase! and on avoiding the knife fight of potential buyers for this car 🤣 this really is a perfect daily and looking forward to following it more.
      Congrats on the new ride!! I'm gonna miss this one big time but I'm glad it went to a good home. Looking forward to seeing what you do with it. Here's two of my favorite pics for motivation!
        Thanks Joe! I’m excited to see where it’ll take me, there’s already a few road trips planned for it this summer!
          First parts ordered. Taking care of the oil change, serpentine belt, and rear shocks (including the mount kit) with this batch of parts. Damping when the car is loaded is… not quite what I want to keep things from going flying, so I’m going to take care of the rear shocks sooner than I initially planned and then doing front struts this spring/summer when it’s warmer. Ordered the Continental kit for the serpentine and OE M Sport Sachs dampers for the rear.
          I’m going to need to pick up a good E-Torx set for maintenance on this car, any recommendations?
            https://www.homedepot.com/p/Husky-1-4-3-8-1-2-in-E-Torx-Socket-Set-HETX13PC/206031060#overlay
              First batch of parts has arrived!
              Hoping to find time this weekend or next to get the shocks installed, oil changed, and serpentine belt/pulley/tensioner replaced. It’ll go in fairly soon for the wheels to be re-balanced, and it’ll be aligned in the spring when I’m done replacing some other suspension bits. At this point, planning for:
              - Front shocks
              - Front upper and lower control arms (replacing with the TRW M3 parts)
              - Rear subframe bushing inserts. I know full bushing replacement is ideal but I don’t care to jump in that far just yet.
              - Any other rear bushings the shop notes as torched. Anyone who has done rear end work on an e90, are there any bushings or ball joints in particular that tend to go earlier than others? Ideally I’d like to not have to replace everything at oncoming the entire car, so if I can do a few things on the rear and the whole front this year, and other rear bushings later, that would be ideal.
                Oil change, Liqui-Moly 5W-30 and Mann filter. All looks good!
                  Swapped out rear shocks and mounts tonight with OE Lemforder sport shocks (white label). Much improved ride in the rear, rebound damping is much better and it doesn’t huck stuff into the air anymore. I could handle a little more stiffness though, so I may experiment with Bilstein HD’s if I get antsy. Should be more than OK for now, front struts and control arms are definitely a higher priority.
                  Very impressed with the ease of this job, the hardest part was removing the plastic caps by where the parcel cover attaches. Otherwise, really intuitive and simple. Everything goes back into place with minimal effort and fits nicely.
                  Replaced serpentine belt, idler, and tensioner as well on Sunday using the FCP Euro kit, continental belt and INA (?) idler and tensioner? Went in easy other than getting the belt back on the harmonic balancer, there’s a tight spot near the bottom that the belt doesn’t like to thread through. Took about 20 minutes total to get the belt back on, and checked with mirrors to make sure it was fully seated. It was, and it made the trip back to MKE tonight so I think we’re all good.
                    KONI shocks are a ton better then Bilsteins.
                      I’ve never had new versions of either; I have some older Bilstein sports on the E30 and they’re decent. Any specific E90 experience with that recommendation or just a general statement? I know that’s what’s recommended for E34’s, the e34 bilsteins are known to be rock-hard.
                      I probably won’t do it either way, we’ll see how I like the current stiffness with the 19s this summer. My guess is that OE sport is going to be just right, but hey, nothing wrong with dreaming.
                        Plates arrived!
                        Im already getting itchy on changing to the Ice Age Trail ones in March when they release, but we’ll see.
                        The black looks spectacular I think so it’ll be really hard to beat. Maybe I’ll get a set for the e28 to take off after I sell it and keep for decoration?
                          Drained and refilled transmission using Liqui-Moly Top Tec 1800 (Dexron 6), replaced the trans filter and gasket, and all new hardware. I forgot to take photos because I suck at forums.
                          Old fluid was definitely very dark and this was definitely the factory fill, but better late than never I suppose. From some research, 130-150k is getting to the range of where it might not be worth it to risk, but the number of success stories with 120-130k gave me some confidence. I wasn’t getting trans slip before doing it but it was starting to shift a little jerkier when cold so I wanted to try to get ahead of any issues before it was too late. Magnet had metal on it but didn’t seem much worse than the magnets I’ve seen on cars with it changed at 60-80k; it seems that a lot of that debris is from initial break-in.
                          Don’t want to jump the gun, but it definitely seems to shift smoother now. We’ll see how it goes the next few days and I’ll report back.
                          Going to order power steering fluid to do a flush there, change out the diff oil, and probably replace the front tension arms with M3 parts as I’m sure they’re toasted by now. I also have a brake vibration that was worsened lately so diagnosing that with a temp gun to see if one is hanging or has some nasty deposits is also on the list.
                            Did this ice age trail plate ever come out? It looks pretty sweet
                              I don’t believe so. Last I heard it was originally supposed to release in March but got pushed back a month or two. I’d bet it’ll release in the next month.
                              I think I’m going to get one for the e91. I like the RA plate but the IAT one is just funky and different.
                                Summer mode engaged!
                                Installed the only aesthetic mod I had planned, LED angel eyes. I didn’t like how the original halogen ones didn’t match the xenon low beams or the license plate/under door courtesy lights, I’m liking the LED much better. Not perfect in terms of color but pretty close and for the price I’m happy.
                                Installed a new cupholder trim piece, only like $20 from FCP. Worth it.
                                Headlight 2K clear is on the way, that’s next on the list. I also have the M3 arms sitting in a box along with 3 cans of Pentosin, as well as the stuff for the diff service. Going to check the front left wheel bearing while I’m in there for the arms, that’s the only corner that is warmer than the others but it doesn’t behave quite like a dragging caliper.  Oil arrived as well. Just need to get the e34 VANOS buttoned up so I have something to drive if stuff goes sideways, then the e91 will get its attention.
                                Been loving this so far though! Utility is unbeatable, the n52 w/ M performance exhaust is a peach and sounds perfect, and the look speaks for itself. However, if anyone ever sees a n52 manual parts car, please let me know…
                                  I'm stoked to see this car getting the love it deserves!
                                  I like this.
                                    I like this.
                                    I need to not get too far ahead of myself and actually finish the e30 manual swap, but I feel like it’s a good prep for one on this. I was shocked at how well laid out everything was once the belly pan came off, I think mechanically the swap shouldn’t be bad at all. The DME coding looks like a challenge, but I’ll figure it out.
                                      Believe it or not, the coding changes shouldn't be that bad. Bimmergeeks protool can change the vehicle order and then appropriately code every subsequent module to match.
                                        Oil change, liqui-moly 5W-30 (satisfies BMW LL01)
                                        Working on the headlight sanding/respray, control arms, and possibly the PS flush this week. Really looking to get the braking vibration cleared up before a few long trips this summer. Fingers crossed!
                                          M3 control arms are installed! This car has been a joy to work on so far with how clean it is underneath. I really should fluid film it this year to keep it that way…
                                          Found that the drivers side was leaking fluid from the bushing (that’s an odd sentence, brought to you by none other than German engineers), and both driver and passenger side had some cracking/were soft. Ball joints still seemed tight.
                                          The first side took a little over an hour by the time I figured out where all the screws were on the fender liner and that the wheel had to be pointing straight ahead for the bushing side to install nicely. The second side took maybe 40 minutes tops. An easy job overall, and WELL worth the effort.
                                          Almost completely solved the shudder under braking (what’s left is barely noticeable and is likely actually from the brakes themselves, or maybe another bad bushing), quieted down the ride, smoothed out the ride, and made the thing handle like a go-kart. Seriously, a car like this has no right to feel as planted and flat as this does. Night and day in the corners, highly recommend doing it if your bushings are getting old. I’d guess it’s a combo of the stiffer m3 bushings and just not having roached ones, but hey, either way I’m not complaining.
                                          PS flush up next, along with that diff oil change and the headlight restoration. Beyond that, I found the drivers side strut is leaking so those are definitely due for replacement, along with the front upper control arms. I’d like to do rear subframe inserts before digging into rear bushings, there’s so many damned arms and linkages back there.
                                          I’m also planning on subtracting the e28 from the fleet as soon as it’s running, and adding this…
