  4. Z3M Coupe
Z3M Coupe
30 Posts 15 Posters 593 Views 1 Watching
    Just causally jumps into machining his own wheels 😂 Gonna be even more rewarding to look at once done.
      Setback after setback....this is the final result! 295 rear tires and 245 fronts, fitment is great but I plan to lower it just a bit more.
        Oh my goodness, that’s incredible looking. The style fits it so well, I’m really excited to see it in person eventually! Glad you were able to get them all figured out!
          Turned out fantastic. All it took was me begging you to buy that full M3 for the wheels 😛
            KW coilovers, Ground Control camber/caster plates, lower control arms,  TC Kline rear shock mounts, sway bar links and bushings all installed the past week or two. Had some time to do a paint correction yesterday as well as install a paint matched rear wiper delete. Getting closer to being satisfied...for now.
            • damnboy037D
              damnboy037D
              damnboy037
              LSB looks so good 🤤
              99 M3 320rwhp @ 6psi
              95 M3 s50b32
                Excellent
                  This car fucks.
                  I'm not familiar with these cars, is like an E36 underneath and it's just a different body on top? Or is this car engineered on its own?
                    This car fucks.
                    +1
                    The z3m roadster and coupe are mechanically the same, basically a beefed up version of the 318ti. Front suspension is e36m, rear suspension is similar to an e30 but with e36m rear brakes, much stronger axles, and everything reinforced everywhere.
