Non-BMW Stuff on a BMW Forum
    That looks amazing! Those seats are perfect in an e30
    Thank you! This is what I was always envisioning. I also ordered a rear bench cover from zoomzoomzoom-ing on ebay and they're going to match the stitching of these seats. The rears won't have the houndstooth, but they'll at least compliment the fronts and will be an identical material.
    • TkuhnT
      TkuhnT
      Tkuhn
      @Tkuhn uses the Airlift brand. Harbor frieght has their own Pittsburgh tool as well.
      Sorry boys. Late to the party but here's a link. Pretty satisfied after only one use.
      https://www.amazon.com/dp/B078RJT13X/ref=cm_sw_r_cp_apa_glt_fabc_2EY7ZHJNV9EY3RCJCHPS?_encoding=UTF8&psc=1
        niiiiiice
        too bad with the reupholstery debacle. did they make any sort of recompense for the shit job?
          niiiiiice
          Thank you!
          They have yet to even acknowledge that they don't look good. I have brought up in my emails several times that this can't be the quality of work that you want to represent your business or as a professional upholsterer you feel this represents your business, etc. Nothing. I am not exaggerating when I say they have not once acknowledged that they don't look right.
          I said I wanted the cost of the front seats back. The rear bench came out fine - even though it will still need to be redone if I get the fronts redone since I'll use someone else and they won't have these materials. He offered $300. The interior all together was $2,700. The fronts were about $1,800 with labor and material. I filed a payment dispute with my bank and have given them pictures, emails, and a third-party opinion. I've been issued a temporary reimbursement for the full cost of the seats. They then take all of my "evidence" and make a final decision. Although I assume if they issued me a temporary refund that my chances are good of it getting approved.
          Once this is all done, I have a large review written up that I will put wherever I can for the business. The letter I have from the other business addresses how the craftsmanship is garbage and the seats are basically ruined (i.e. all foams will need to be made custom or purchased new and fitted to the frames).
          In other news - the new covers for the rear bench are on their way! Matching leather with stitching that matches the front seats.
            Good, they deserve every bit of your bad reviews. Such an obvious qaulity issue and then to offer a abysmal resolution 🤷‍♂️
              I've committed to the 2021 Overcrest Rally with the e30. Should be a blast, but it's a lot of seat time and time away from my family - but I think it will be good for me. My wife told me to just do it, so I did.
                What's the time frame to make that drive?
                  Driving out Wednesday and Thursday. Rally is Friday and Saturday (also Sunday but I'm not staying for that portion). Drive home Sunday and Monday. Google Maps says 3500 miles but will be more because of the rally portion.
                    Took the e30 out for a test run today. Everything seemed to be working great. I bed in the brakes and they are fantastic and then it died. The dead fuel pump issue again. Called my wife, while she was getting ready to leave the driveway, the car miraculously started up like nothing was wrong and I drove it home. This is the same issue when I first tried starting it this year. I put in a new DEM relay and fuel pump relay. I thought that cured it but apparently not. The other thing I did was a new Delphi fuel pump. I have heard very mixed reviews on them, so I wonder if the pump is just a piece of shit. I'm going to get a Bosch fuel pump to swap out the pump on the old assembly that was in there before.
                    Then while parked I noticed a little puddle under the car. Got home and the RMS is dripping really bad. Parked in the garage for 30 minutes had left a few inch spot with visible drips out the weep hole. I'm taking it somewhere to replace the RMS. I'm not doing it again. I have to get to the 850 which needs suspensions desperately.
                    That's where I'm at. 😒
                      I tossed in my old pump and took the car for another drive and I didn't have any issues. So I'm assuming it was the Delphi pump that was bad and working intermittently. I ordered a Bosch replacement pump and fitting it to the factory assembly took way more modification than I would have liked. It required cutting off the bottom tray, soldering on new power/ground wires to the assembly to accommodate the plug for the Bosch pump. I could not get worm clamp to fit through the opening in the tank so I used zip ties. The fuel level sender is such a snug fit that I didn't notice the placement of one of the zip tie ends was in its path and had to take everything back out just to rotate the zip tie. Then the sheer thickness of the zip tie made it difficult to the level sender in.
                      I'm going to remove it and use some stainless steel zip ties to clean it up, but I ended up ordering an OEM pump assembly last night.
                      Then I went to install the UUC skid plate I got. Turns out they don't fit if you have an e36/e46 steering rack. So I had to notch out the skid plate to clear that. Then the whole way they install in the front didn't make any sense or fit anywhere. Ended up tack welding the mounting bracket to the bottom side of the frame on the front of the car and will get shorter bolts with lock washers.
                      I remember when June 1 was my goal to start driving it. Then it became July 1. And now it's August. 😩
                        skid plate on an m20 car? that's a terrifying thought hitting something so tall you'd need a plate for that.
                          I'd rather toss on a skid plate than risk breaking an oil pan on gravel roads in Utah.
                            I've been driving it. And so far the Bosch fuel pump has been working. I returned the Delphi and OEM pump to FCP. I ended up using stainless steel "hobby wire" to secure the pump to the housing by wrapping the pump and the housing then tightly twisting the ends and folding that over. I felt the most confident in that.
                            After driving the car some it was getting hot with the AC on when in slow traffic and even then still running a bit warm. The aux fan was not turning on with the AC and traced it back to the fan to body harness connector not staying secure. Replaced that with a new connector.
                            Also swapped in a new engine fan clutch with an Behr clutch rather than the Uro one I put in there originally and realized that the fan that came with the car is from an early model. So I got the correct fan.
                            And then keeping with tradition of recycling parts between @The Full Banana and myself, I bought his MaxJax from him since he has decided he no longer wants a garage. I have that set up, waiting on some DeWalt Anchor Epoxy from Grainger to finish installing the anchors. And the only good place to put the lift was centered with the overhead door. But that meant the garage door opener robbed me of about 12" of lift. Out with that and in with a wall-mount unit.
                              Nice!  I've got a MaxJax on my wish list.  Eventually I need to just bite the bullet and buy one.  Was it difficult to convert from the ceiling mount to wall mount?
                                Not at all. There are some spacing requirements that you need to have but I think it’s all pretty standard for most of the garage doors. If you look up the opener they have a little checklist. The only fitment issue I had was a cable tension sensor. If you have a lower clearance door like mine, you’ll have a hard time fitting it because it goes between the top of the door and under the spring bar. But I’ve read they can be tricked with a 1k ohm resistor - which I just got tonight.
                                • The Full BananaT
                                  The Full BananaT
                                  The Full Banana
                                  Must be nice having a garage. Wonder what that’s like.
                                   Season 9 Waiting GIF by The Office
                                    It’s super nice. You should try it sometime.
                                      Good lord this is 41 pages long. Sorry for posting so much. BUT I got the MaxJax all set up and the garage cleaned up to do the suspension on the 850.
                                      The anchor epoxy that came with them was expired by several months. After a ton of needless research I ended up ordering this from Grainger:
                                      The manufacturer specs rate it at 46k lbs with allowable load of 11k lbs. Each post has 5 bolts. I'm pretty confident in it. It was also reviewed and recognized for short and long term loading. The epoxies I could find off the shelf were pretty clear they weren't for long term loading.
                                      With that said, I have an extra one of these and the fancy $120 double caulk gun for dispensing it if anyone is interested. lol.
                                      • swiperS
                                        swiperS
                                        swiper
                                        Just discovered this thread! I will also be making the trek to the OC rally this year! Maybe we can coordinate the drive.
                                          Oh nice! Where are you driving from?
