  4. Finally Joined the Longroof Club
156 Posts 22 Posters 0 Views 1 Watching
    99.9k
    Changed the oil over the weekend. It really needs a good detail after functioning as a moving truck and contractor van for the last few months...
      101.5k
      Lame.
      One of the rear wheels cracked bad enough to give me a flat tire yesterday. Apparently 19" style 225M and 313's have a reputation for fatigue cracks on the barrels. It cracked right alongside a previous repair (you can sort of see the weld just to the right), so it was probably only a matter of time. I'm having a very hard time trying to find a not cracked replacement so it might be time to start looking for some new wheels...
      Good news: A rear contour fits perfectly on the rear of an e91. The tires are different heights so I'm going to avoid driving it like that, but at least I can move it around not on a flat.
        I just picked up these wheels off a doppleganger of yours. Minus the performance kit + the manual transmission.
        Works for visualizing a wheel suggestion.
          Thats very helpful because I am leaning towards some 19" ARC-8's (or maybe EC-7's) if I do end up needing new wheels
            Bummer! Those 225M's are neat wheels
              101.5k
              Lame.
              If you ARE looking to get the crack fixed, I know a guy who does awesome work. He fixed a crack/gouge on the set of ZHP wheels I bought for my touring. Just a thought if you were thinking of going that route.
                My first choice would be to have it welded (depending on cost), I reached out to one place but would love a recommendation! I'll text you!
                  I've used Milwaukee Alloy Wheel Repair in the past with good results. Also, there's a shop in west allis that welded a few wheels for me at my old job, somewhere off Lincoln in west allis. I'd have to do some digging since it was basically someone doing side jobs out of their work place.
                    I did reach out to them, they said the crack might be too bad to repair unfortunately. Once I get the tire taken off they can make a final judgement but they did say it's usually worse on the inside so I'm not too optimistic. I was planning to get it pulled off this week and follow up with them.
                      104k
                      It wouldn't start in the sub-zero temps we had for a few weeks which was annoying. The battery was replaced at the dealer not long before I bought it but I think it is a low cold cranking amp version as the car was previously in CA/NM. Now that the weather has warmed up it starts the car and holds a charge perfectly fine, which means I can ignore it till next winter lol.
                      Way back in October I swapped my winter setup to a set of 17x7.5 MSW wheels with Continental Wintercontact SI tires in 205/50/17 somewhere around 102k. The bigger wheels will clear the 335 brakes I have sitting in boxes waiting to be installed in the spring. Pretty happy overall with the new combo, road noise is definitely higher and the grip in the snow isn't quite as good the altimax's, but they're a bit less squirmy (maybe from shorter sidewalls) and I put together the whole setup for pretty cheap.
                        Are those 10' boards?
                          It's 8 2x8x8' boards, they stopped right at the back of the front seats. I just noticed it looks like they went to the dash because I had 5 more 1x2x8' that I didn't need to have hanging out the back haha. I DID however bring home a couple 16 foot baseboards a couple months ago but forgot to take a picture. Those went on the dash and then out the hatch window another 8 feet haha.
                            Okay. That makes way more sense. lol. I can have 8' boards sit right between the front seats and be completely in the car. And I was thinking there's NO way that my car is that much longer than yours.
                            On a side note - how much have all of your DIY projects gone up in price with the price of wood being fucked? I started on our basement and have bought somewhere around 50 2x4x10, 20 8'ers, and then a variety of green treated stuff and what I paid now is SO much more than what I priced out 9 months ago.
                              thats how you ger er done!
                              i have not noticed a price increase in lumber, only because i have only bought in small quantities.
                                Lumber prices have gotten absolutely ridiculous! The 2x8's pictured there were the cheapest I could find and it was still over $100 just for those. The pressure treated stuff is even worse. I've gotten good at recycling what I tear out from elsewhere in the house haha
                                  Yeah, my dad is in residential construction and he said the other night prices have gone up around 70% for framing lumber for him compared to pre-pandemic cost. It's obviously factored into bids now, but the price increase when he had houses in progress sure sucked.
                                    I grabbed 6 2x4x8's yesterday and they were $40. wtf.
                                    That's exactly what happened to us. We signed our contract before the prices went up and we ended up using our total framing/exterior budget on basically the rough framing. We still had to buy all the siding and all the carport material. It was awful and sent us quite a ways over budget very quickly.
                                      104.1k
                                      Summer mode! After about 4 months of searching and not finding any good alternatives, I finally sourced a 225m rear wheel. It is the rear wheel from an X1 m-sport so the size is 19x9 et41 vs. 19x9 et39 for the e9x rear wheel. The new wheel has a date stamp from 2014 whereas the old wheel is 2009, and appears to be a revised casting so we will see if the barrel holds up any better than the very crack-prone e90 variant. Its not necessarily ideal, but I solved the offset issue with a 5mm spacer on the X1 wheel, and a 3mm spacer on the e90 wheel. The concavity of each is exactly the same, so there is no way to tell the difference once they're mounted. I also added a pair of 10mm spacers to the front that I had sitting around. It is a very small change with the spacers but I think it makes a big difference!
                                        Interesting that the offset is different since the x1 is e90 based. Can you still get those wheels new?
                                          Interesting. Any reason (cost?) to not just go with a pair of replacements and run sans spacers/equal spacers? Looks great though, I’ve always though that e90’s and wagons in particular seem to have really sunken wheels from the factory.
