  4. 1990 e30
1990 e30
99 Posts 16 Posters 2.0k Views 1 Watching
  • N
    N
    Nick_08
    I did a test on the effectiveness of the venturi jet pump. It was able to pump 1 gallon of fuel to the other side of the tank in 36 seconds with fuel pressure holding solid at 43psi. There was a fu*king tornado in the tank lmao. Very impressed.
    I've added a turbine back pressure sensor and a 3 port boost control solenoid. All plumbed and wired in...
      What’s the idea with das loopinator?
        My guess is heat, helps protect the sensor probably
        • The Full BananaT
          The Full BananaT
          The Full Banana
          Throwing a guess in for vibration resistance given that it’s all hardline
          • N
            N
            Nick_08
            Correct, the loop serves to dissipate heat from the exhaust gasses passing through before reaching the pressure sensor. It also dampens the exhaust pulses as they pass through the tubing and absorbs vibrations. I also installed a 0.04" restrictor/damper just prior to the sensor just to make sure the readings are stable.
            • N
              N
              Nick_08
              Been awhile, here are some updates on the car.
              Finally got around to installing the remote brake bias adjuster.
              I got some new front wheels and tires. The tires rubbed on the factory wheel well liner so I made some new ones from hdpe. They clear with about a 1/4" to spare! Don't mind the socket spacer, I have some proper spacers on the way from McMaster along with some button head screws to replace those hex heads.
              Yes, transmission jack...the spring is removed.
                Clear when turning under load too? 😉
                • N
                  N
                  Nick_08
                  Well if having the spring removed and the shock completely compressed counts as “under load” then yes. Lol
                    Just wanted to check lol. Didn’t see any pics of the wheels turned 😁
                    • N
                      N
                      Nick_08
                      My bad, in the third picture, which is very close up; that is taken at full lock.
                        My eyes deceived me lol
                        • retoropakR
                          retoropakR
                          retoropak
                          Shit and I worried that 245s wont be enough for my m42t e21
                          Will 16s clear stock e36m3 or e46 330i brakes?
                            There are some 16's that will clear e36m brakes, but not the majority. As far as I know, no 16 will clear e46 330 brakes as they are slightly larger than e36m.
                              16" contour reps clear e46 330 brakes.  I have test fitted that combo.  Clearance is about 1/8"
                                I stand corrected! Always thought they were just too big, good to know
                                • N
                                  N
                                  Nick_08
                                  Plenty of room, just need the right offset!
                                  Good info. I didn't want to risk the wheels not fitting with the 330i brakes.
                                  For some reason I get no notifications of posts even though I have the notifications turned on. Is this a common issue with the forum?
                                  Finally got the car on the ground. I approve. NO POKE!
                                  • N
                                    N
                                    Nick_08
                                    Nope just a shit picture
                                      Dang, that fitment is great, way better than e36 parts.
                                      • N
                                        N
                                        Nick_08
                                        Thanks bud I wish I would have taken a picture from the side. Car is back on jack stands now...
                                          Any idea how much camber you're running in the front? I'm debating switching to this setup at some point for a number of reasons.
