    Im still chasing the heat issue. Originally I replaced the cabin filter which had 10lbs of leaves and debris smashed into it. That somewhat fixed the heat, but I still have weak heat to the dash vents. I have a new heater valve in hopes that fixes my problem. The other thing it might be is the heater core which I plan to flush when I do the valve.
      Replaced the heater valve and flushed the heater core last night. It really needed it.
      It took a few buckets to finally get some clear water.
      70AEC4A3-D7B1-461D-82DA-2FC8288A2D4A.jpeg4F4F8D9A-E611-42F4-B9E2-E1D85A547F1F.jpeg428F0B57-7E79-4B48-8C41-8AEF425EF9C2.jpeg
      After all this work, it seems like the heat is much better, but the flap door for the dash vents must be the issue. I get strong defrost and floor air, but not mid level. It sounds like the air is hitting something rather than flowing through. Might have to pull the dash apart.
      One last thing is I painted the wheels. It’s been bothering me because they looked so trashy. I must say the black isn’t dirty enough yet, but it looks a lot better.
        The flaps are operated by stepper motors.  On my '93 I have had issues with intermittently the mid level ones won't open.  The sound changes to a sound like the fan is blocked and whistling.  I haven't tried fixing it though, but I imagine either the stepper has an issue or linkage is sticking.
          YUP that's exactly what's going on. Ive watched the linkage and it all seems to move as its intended to.  At this point im not sure what's the best (cheapest) option. I might just replace the steppers with manual levers or something stupid. I just want to fix it quick and easy.
            Welp I removed the steppers and just fixed the doors into my desired location. I officially have heat. I can still control the temp and all the vents so it might just stay this way.
            Driving it around nice and toasty.
              seeing that in a apartment basement garage makes me smile
                Please tell me this is the winter daily driver.
                i’d love to see some old-timer get utterly confused about what kind of car it is by the sensory overload they would receive.
                  The looks I get are hilarious. I will daily it as much as I can, although its kind a pain in the ass getting in and out of a fixed back race seat. Maneuvering around the target parking lot is also very obnoxious.
                    White knuckle riot in the snow. Traction is limited with these old mud tires, and a welded diff makes almost any throttle input spin the tires.
                    I will be sure to post here when I end up stuck in a ditch 🤣.
                    • N
                      N
                      Nick_08
                      This is a badass machine you've built here. It's gotta be fun to drive around. Can't imagine the looks/comments you get. 😆
                        With the hobbyist plates you aren't supposed to drive in January, although keep them covered with road slop and snow spray and you should be fine.  😛
                          No fear the government gives you a work around first hand.
                          https://wisconsindot.gov/Documents/formdocs/mv2750.pdf
                            Not exactly, that's only to operate for 5 days.
                            "6. If you need to use the vehicle for more than 5 days you will need to re-register the vehicle under the regular registration provisions"
                              They'd have to catch you more than 5 times in the month of January.  I guess it depends on how close the FBI guy following Jason around is paying attention to this end of days war wagon.
                                Most common is "COOL!....what the the hell is it?"
                                  Im aware of the DMV 5 day pass, but I'm a risk taker and snow slop seems easier. Besides I'm mostly driving back roads anyways with an occasional stop at the Starbucks for a white gurl frappe.
                                    triggered
                                      made the mistake of clicking on a suggested video; worst photoshop ever (amongst other things...)
                                      Found some nice contrast
                                        The red window tint really works with this car. Makes me think of those green translucent visors 😄
                                          :side note: The car heats up quick now with the coolant system and heater sorted. BUT, I have a few holes I need to plug to keep the air from coming in. Without interior panels it’s quite drafty.
