Non-BMW Stuff on a BMW Forum
    I sense an autox in your future
    To be honest, I think this made me want to do autox less. Back country driving with the windows down is what I have always enjoyed most and this was the epitome of that. I cannot say enough how idyllic the driving experience was. Autox would just be a let down to me.
      get that BBK installed so you never miss a good 4-way stop at an intersection
      edit - everything I do is sarcastic, don’t take me seriously on here
        Sway bar upgrades reduce the amount of coffee spilled on your lap in a corner.
        edit - I'm friends with Kaiser
          I'm more concerned about the bikers and walkers after I turn the Ozaukee interurban trail into my personal rally course.
          That'd also help keep my donut holes from rolling out of my lap and onto the floor.
            I echo this sentiment.
              Since suspension is on the punch list for the winter - what are some of you running and how do you like it? I know there are some coilover options, but I will likely not be going that route due to the cost and that they're not a direct swap (and the ones that are a direct swap are even more money).
              I'm leaning towards Koni Yellows with Ireland Engineering springs. Something semi-comfortable enough to DD, but can take some punishment.
                 This might help offer some comparisons.
                  That would be a good combo.
                  Unless something has changes recently I prefer the ride height of the H&R race. The IE appeared to sit a bit taller in front. Even at that I was running E90 spring hats up front to lower it another 10mm, but that was an attempt to even out the proportions on a late model with the lower rear wheel arches. While aesthetics were secondary to driving enjoyment, the way the IE looked on a late model bothered me.
                  That spring rate with a Bilstein sport damper is slightly overdamped so I think the Konis are a great pick.
                  Top it off with a set of sway bars it will make the stock suspension feel like you were once driving a bobblehead doll
                    I have IE3 springs and Bilstein sport dampers and overall I like how they handle and ride. Compared to the vogtlands I had before that were way too soft for the bilsteins, the stiffer spring rates have eliminated hitting the front bump stops like I was before (though that was with drop hats) and arguably ride a lot better because of it. What I don't like is how the car sits. The back is right where I'd like it to be but the front feels like its a full inch too high. Its particularly worse on my car because I run fixed camber plates that add about 1/4" of height.
                      I'll have to look into how the IE springs sit more. While aesthetics are secondary, that would bother me to the point that I'd need to change them. I haven't had Konis in any of my cars yet, but I have had Bilsteins and they've always seemed kind of "crashy" to me.
                      The car has, what I believe are Bilstien HDs with IE springs. But the springs appear to be really old and the HDs are quite blown. The car failed the bumper bounce test when I got home from the Rally.
                      It currently has a front ebay sway bar. What's your thought on sways in front and back or just the front?
                        I'd have to compare the HR Race vs IE springs. They seems to have the same rates according to that table, but maybe their heights are a little different.
                          Yes, H&R race sit lower in front. Here is mine with E90 drop hats.
                          @KaiserRolls can comment on the suspension more since he now owns the car and did a few autocross with the H&R race setup. My only track day was on H&R SPORT + suspension techniques 22mm/19mm sway bars. I felt the car was really responsive, excellent turn-in and predictability. Changing the springs to H&R Race only made it better.
                          i’d recommend front and rear sways with reinforcements
                            If you really care, get the dampers valved to match the rates you want, or get rates that work with the stock valving.
                              Hey guys. So I’m going to keep the stock brakes but get a better pad. What’s your preferences? I’ve read a lot of back and forth between Stoptech and Hawk HPS but I always like to hear some first hand experience from people who have used various pads or something they’ve had good luck with.
                              I’ve always used cheaper factory equivalent pads on my cars so I don’t have any experiences with performance pads. I’ve pushed this e30 harder than I have my other cars and have had a couple oh shit moments coming up to a turn.
                                Are you concerned with noise/dust?
                                  Not really.
                                  I always go down these stupid rabbit holes of mundane things like what brake pads to get.
                                    gilber33 said:
                                    Not really.
                                    http://www.g-locbrakes.com/products/brake-compounds/
                                    gloc uses transfer layer pads, so they want you to have a clean (turned)/new rotor to start with
                                    could try out their GS-1 compound, that’s the most mild pad they offer
                                    I run hawk HP+ and will be switching to GLOC R8 next year. The hp+ makes some noise and has some heavy dust for what it is
                                    we run the R6 on the evo x and it’s awesome for autox/light HPDE use. Makes lots of noise for daily driving and a decent amount of dust. Have been nothing short of impressed with those pads though
                                    Gf currently runs hawk HPS on the turbo Miata and I’m not a fan of them at all, she will most likely make the jump to R6/R8
                                    FWIW, GLOC and Carbotech are basically the same thing, iirc they were started by the same dude or he left one to start the other.
                                      Here's a variety of things happening.
                                      The car has been parked since the rally. So far I have Bilstein Sport shocks/struts, HR Race Springs, Supersprint Catback (Black Friday sale from Turner), ST sway bar kit, new rotors and pads, and DSSR. On my list of things to get yet are coolant hoses, better short shift kit, new fuel pump and some other odds and ends. This last round should address all of the major systems that I haven't touched yet and hoping it will give me extended periods of driving with only minimal/routine maintenance.
                                      Our house addition is progressing. The inside is drywalled and I believe they will be starting on 1st floor floors next week. Our contractor is hoping to have the interior done around April. And my conversion of the garage into a shop continues. I put in cabinets to accommodate the fridge that was in the house that will now be in the garage. Painting some walls tonight so I can rotate things from unfished walls to finished walls to continue working.
                                      Winter projects in the garage include:
                                      • Building a garden shed so the existing garden shed can become a toy shed.
                                      • Building built-in cabinets and shelves in the house that we took on ourselves to save some money
                                      • Laying carpet and floating floors myself on the second floor of the house to save money
                                        So remember how I made a big stink about the workbenches and how unlevel they would be? Well, turns out they're completely fine. Will definitely leave it like this for a cleaner look. Plywood top has not been installed or trimmed down to fit, so ignore the crookedness.
                                        Almost done painting. Need to mud all the inside corners and then touch them up and then paint the ceiling.
                                        Also threw on the old front door from the house onto the garage. Fit perfect. Have some curtains to hang up so you can't see inside the garage.
                                          alternate idea below.  all the light, all the privacy, no ugly curtains.
                                          https://www.amazon.com/RABBITGOO-Privacy-Frosted-Adhesive-Bathroom/dp/B01MTA00AX/ref=sr_1_1_sspa?dchild=1&keywords=window+film+frosted&qid=1607452388&s=home-garden&sr=1-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEzR1VSM0NLQlgwWE9aJmVuY3J5cHRlZElkPUEwMzAxNDgzMks4TERLQUY1MzBGRyZlbmNyeXB0ZWRBZElkPUEwNDgxMzU4REE5MFRMVDg4Njcmd2lkZ2V0TmFtZT1zcF9hdGYmYWN0aW9uPWNsaWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl
                                          also a warning:  that door is just about the most insecure door you could have.  glass panes near the door handle are a target for thieves. someone can in that door in about 2 seconds. i installed sheet of lexan on the inside of a door like this in the past because it is nearly shatter/impact proof. the deadbolt is also in a very narrow piece of wood since the glass lite is right next to it. it could easily be kicked in without reinforcement.
