  4. 1990 e30
1990 e30
99 Posts 16 Posters 2.0k Views 1 Watching
  • need4speed1299N
    need4speed1299N
    need4speed1299
    Awesome setup!
      Impressive fab work 👍 can you link the cable crimper?
      • N
        N
        Nick_08
        Thank you sir. Here you go: https://www.amazon.com/Hydraulic-Battery-Terminal-Crimping-connectors/dp/B07ZFLVZ75/ref=sr_1_7?dchild=1&keywords=hydraulic+crimper&qid=1596976179&s=power-hand-tools&sr=1-7
          What's the expected power figure from this setup? Stock body E30 this thing is going to roast tires through 4th lol
          • N
            N
            Nick_08
            @SteelBlue I’ve got a SBE LS1, basically all the gen III LS have weak rods and pistons. I will keep the boost low (under 10 psi). Perhaps 600-700 level? I’m either building this LS1 or an iron block with forged internals.
            Updates: I added some heat shielding to the firewall and powder coated the brackets I made. The flat ones move the coil packs up about 30mm to make clearance for the wires. The down pipe is very close to the valve cover. I also made the mounting bracket for the brake reservoir.
            • N
              N
              Nick_08
              Still working on random parts of the car.
              1. Added a proper metro-pack connector for the fan and added the wiring for the pump.
              2. Added a bleeder to the intercooler and heat exchanger.
              3. Installed the reservoir in the trunk and yes I did leave that length of clear hose hanging like that....just to bug your OCD. Got one of them hose cutter tools, so nice...
              4. Finally got the last fitting in today for the fuel system. Finalized the fuel hoses in the engine bay area. Mounted the fuel filter.
              5. Turbo drain mocked up. Need to pull the oil pan to have the -10 male fitting welded in place. You can see the drain tube will also have a -10 fitting welded in place. I plan to use a coupler to attach.
              6. Took a picture of the coil relocation and LT1 boots I got to route the wires away from the exhaust. As long as they don't touch the exhaust they should be good to go. I have some fiberglass sleeve I'll use over the wires as well.
              7. Made a new ground cable for the battery. Still need to make a new engine ground.
              8. Hard line to AN fitting adapters installed.
                This is great!  What are you running for brakes?
                  As far as your pump goes I would test what gph you’re actually going to get thru your heat exchanger/tubing/etc. For what it’s worth my 500gph pump for my coolshirt setup ends up being like 11gph at the shirt through smaller tubing.
                  • N
                    N
                    Nick_08
                    I honestly don't have high hopes but I thought I would give it a try. I'm not exactly sure how I will set up the logic to run the pump. I was thinking to have it turn on when I hit 100 kpa and/or IAT above x. Thoughts? I think the intermittent cycling will keep the water cooler for a longer amount of time. I am also thinking about adding an override switch in the cabin to run the pump continuous if I wanted. Anyway, I think the pump will change how fast the IAT changes so I'll have to wait and see.
                    Thinking out loud, I think I could even leave this pump and add another in the tank or just outside to serve as a feed. It may or may not work but, likely just make the system more complicated. The best choice is probably to fork out the $$$ for a pump should I find the need.
                    Manual, Wilwood pedal box with factory calipers and HPS pads. I've been looking at options to upgrade the calipers and rotors. Any suggestions?
                    • N
                      N
                      Nick_08
                      1. Finished up the fuel system.
                      2. New fuel pump wiring (10 AWG TXL), I know the splice is weird but I wanted extra there in case I ditch the factory pump/hanger.
                      3. Final install on the water pump.
                      4. Not shown, I ran a 1 AWG ground cable from the battery to the engine compartment. This is to ground the engine block. Also ran the power wire for the terminator x (must be installed direct to the battery).
                      5. @patsbimmer1 brake system
                        For pumps like those, you could use a simple livewell timer to control how often it runs.
                        The ice in my cooler lasted way longer doing intermittent cycling, could’ve been placebo effect though too as I’d use it when I warmed up again.
                        for brakes if you think you need larger, just make sure you match the master cyl size with whatever you go with. I have stock brakes and just upgraded pads (hp+) and fluid with a 7 series master. (EDIT: just saw your post and realize you have a aftermarket pedal box.)So far so good and it preformed well enough for me in autox/mountains. I have a hpde scheduled in sep and Can get you some more feedback. I have a strong feeling they will be ok. If anything I might jump to a different pad (GLOC r6/r8)
                        • N
                          N
                          Nick_08
                          Couldn't agree more, intermittent cycling makes the most sense, saving that cool water for when it is needed rather than heat soaking right away. I added a drain right through the bottom of the car so it would be easy to dump and replace if need be.
                          I've honestly never needed more brake in my experience either, then again, I don't know the difference. Good to hear your feedback. Keep me posted.
                            I have zero experience with brakes on a modified e30 so i'd be no help at all.  I was just curious if they needed to be upgraded with the massive amount of power being added to the chassis but if @KaiserRolls says stock brakes with upgraded pads is good enough i'd trust him!
                            • N
                              N
                              Nick_08
                              Update...
                              1. Got the last tee fitting to run my pass side brake line. Added a grommet to the wheel well for the brake line.
                              2. Oil pressure sender installed for the terminator ecu and AN -4 oil line ran for the turbo.
                              3. Catch can mounted, PCV lines are getting run over to the driver side wheel well. I decided to run a provent 100, it has 3/4" inlet/outlet and a return back to the oil pan with a check valve. This will be practically maintenance free. The outlet will be plumbed into the turbochargers intake. More to come on this set up. I also added a tee with a filler for the water setup, this was needed in order to fill the intercooler and bleed all air from the system. I mounted this with zip ties cuz no build is done right-proper without zip ties holding shit together.
                              4. Downpipe/exhaust. I was able to get an 80 degree 3.5" mandrel bend, fits the car perfect. Put the one end in the press and made it into a round to oval adapter, worked better than anticipated.
                              5. Oil pan, charge pipe, intake, and turbo drain is all off getting welded. Once I have that back the car will need to be put together and I should be close to start up.
                              • N
                                N
                                Nick_08
                                Minor update:
                                1. Got the oil pan back on the car yesterday. As I was getting ready to do so I had to take a pic it was pretty cool to see the flywheel "made in texas".  Since the pan is back on now is really time for final assembly and soon a start up!
                                2. Intake mock-up completed. I think I am going to powdercoat all of the intake pipes that will fit in my oven. I have a real cold air intake setup now, I have the wheel well liner to put in place to protect the filter. I'm not sure if I will be doing any more boxing in on that filter space.
                                • N
                                  N
                                  Nick_08
                                  Updates:
                                  1. Its amazing how forgiving powder coating can be and how good it looks. Check it out, I literally took this piece threw it in the oven for outgassing and preheat and put some powder on it.
                                  2. Got heat shielding? Perhaps overboard? No chances. Exhaust has been installed for the last time. There are 3 v-bands and 2 collector flanges, the shit lined up perfectly...no worries on blowing out a flex pipe.
                                  • N
                                    N
                                    Nick_08
                                    Basically wrapped up the engine bay today. I have to figure out where I'm going to mount the remote oil filter. Bleed the brakes and clutch. Exhaust is "temporary", I intent to install an electric cutout for the side exit and run a bmw aftermarket cat back exhaust/muffler. We'll see....its all 3.5" round/oval.
                                    I do need someone's help or ideas, I forgot to check clearance for the headlight and the turbocharger intake tube. The headlight (euro smiley) will fit without the cap in place. Is there anyone who has needed to modify the cap or came up with an idea to gain clearance?
                                      nice packaging, attention to detail is awesome! (tbolt thread caps)
                                      also this is going to be reeeeeeally loud lol
                                      • N
                                        N
                                        Nick_08
                                        Yeah I'm excited to see what it hears like through that turbo, the cam is just nasty. Hoping to get an exhaust on there that makes it as quiet as stock. Thanks @KaiserRolls
                                        On another note, I think I've got the solution to any future fueling problems...this thing is good for 535LPH at 40psi. The pump barely fits in the hole of the e30 tank. I've got to get creative with the hangar assembly, the line needs to be bigger (3/8"/10mm). I'm looking at aftermarket options. If anyone has experience modifying the fuel pump assembly please chime in.
                                        • PartiallypurpleP
                                          PartiallypurpleP
                                          Partiallypurple
                                          Just went through the whole thread! Looks like its turning out awesome. Will need post some driving clips once its all said and done!
