  4. My 1997 M3 (That I'm not going to part out anymore)
119 Posts 21 Posters 0 Views 1 Watching
    Looking good!  I like all of the little touches.
      Golfball gang!!
      • ChrisOC
        ChrisOC
        ChrisO
        Small update
        Old shift linkage is out, new dssr and RTD shifter are in! This shifter is absolutely worth the money and it feels great
        I also wanted to make sure everything lined up good so I put in the poly trans mounts first. Really pleased that they only took about 5 minutes to put in
        Crawling around under a car really takes a lot of energy 🥵
         last weekend I picked up the Max Velocity Evo front lip and will be messing around with that tomorrow
        • ChrisOC
          ChrisOC
          ChrisO
          The weather has been great the last few days, not ready to hit the roads but I was able to pull the car out and give it a wash
          Super happy with how the car looks
          Heres a shot of the black Bimmerworld pedals up close
          And a closer shot of the shifter set up
            Looks great. Did you use the boot trick when installing the RTD? People take the stock rubber boot that seals off the trans tunnel and they turn it upside down and install it with the RTD
              I think RTD is the same one that @suspenceful has? Maybe a different model, but the feel of his is like a bolt action shifter, feel was awesome.
                Yup, I have an RTD in the 135i and his looks almost identical. Great shifters, can't mistake which gear you're putting it, that's for sure!
                • ChrisOC
                  ChrisOC
                  ChrisO
                  Graduated college and moved back to Green Bay for a month, then Ill be moving down to the Madison area!
                  Went to the local pick and pull today to get some parts for my Passat, and found a 99 vert out in the yard. It was 100% rust free and I managed to snag the x-brace, the guy behind the counter let me have it for free
                  It had a bit of surface rust so I cleaned it up with the wire wheel and sanded it down for paint
                  Painted it with some high temp caliper paint
                  Nice that the M3's have the mounting threads in the subframe already, and thankfully all the holes lined up perfect. Took maybe 15 minutes to put it in, start to finish
                  Pretty happy that I now have an x-brace and it cost me nothing and took little effort to put in!! I was also looking to get a x brace soon because when I dropped my exhaust I found that the OEM cross bar had taken a nasty hit at some point and wasn't even close to straight anymore
                    Looks great! I hope to see the car when you move down to Madison!
                      Do you just screw those pedal covers into the existing pedals?
                      • ChrisOC
                        ChrisOC
                        ChrisO
                        Drilled and bolted in with lock nuts, the brake pedal is steel so it’s extremely solid. The gas pedal cover is just screwed in
                          @pynacl and I did a photoshoot before @ChrisO left town 😦
                          And by @pynacl and I, I mean just @pynacl because my dumb ass forgot my SD card at home.
                          Peep them here. A nice little addition to the thread.
                          https://flic.kr/s/aHsmNgsFY9
                          Images by pynacl
                          • PartiallypurpleP
                            PartiallypurpleP
                            Partiallypurple
                            hoping to see this car this summer sometime. If you are ever in the Milwaukee area with it let me know!
