  4. The One That Didn't Get Away [100K Mile E30 325is]
257 Posts 19 Posters 4.4k Views 2 Watching
    I apologize for the wall of text, I start writing updates about this car and next thing I know it's an essay.
    Brought the car back over to Auto Clinic as I had noticed one of the sway bar bushing mount tabs had not been put back into the subframe when they had done the oil pan. I asked if he could do a "PPI" of the car while he was at it. Didn't have to pay for it, but he went over the whole car to essentially give me a break down of things that needed attention right away and things that could maybe wait. Things that needed attention right away, high and low pressure power steering lines from reservoir to pump. I purchased the parts and they did the labor. One reason for this, no space at the shop to do any work...two, car was already there, labor was cheap enough, why not. Also had them replace the reservoir cap and gasket as they were like $5 for both parts. Should take care of my usual drip spots in the garage as I guess these lines were on their last legs. Was trying to source this leak but had a hard time determining the source as they fluid would change colors as it dripped through the dirt and grime on the car.
    Things that can wait:
    Diff refresh. Needs new output and input shaft seals. Pretty gunky around each of these spots, but it's not anything serious. Asked what this would cost and figured it would be something I could do this winter on my own.
    Trans refresh. Input selector shaft seal seems to be the main culprit of this one by my estimation. Whenever it would get pulled, I'd have a complete reseal done in addition to a complete shifter refresh. As well as a rear main seal replacement and anything else that could be taken care of while doing this. I don't want to pay for this to be done, but I'm likely going to have storage unit, don't have a trans dolly, and pulling the trans in the car is just a bitch. Since I don't plan on pulling the motor soon, likely the route I'll have to go.
    Exhaust. After the resonator, there are two flanges on the stock exhaust where it meets the axle back portion, one of these is cracked in half. I have a slight exhaust leak, can't smell anything, no obvious leaking sounds, but it's kind of apparent when I drive past a wall or something where I can hear the echo. I'm fine leaving this for now as my plan is to replace the whole exhaust, maybe next spring. Ireland Engineering long tube headers, Vibrant resonator and muffler. Have the same guy that fabbed my S52 exhaust do this one for the M20.
    I think the guys at the shop like that I'm taking on ownership of this car because this was in my passenger seat when I picked the car today.
    I also got to grab a bunch of these PCA magazines from their lobby.
      Bicnic or pust!
        Bicnic or pust!
        I'd like to, but it's almost a 2 hour drive for me. Mostly on the highway, which this car doesn't seem particularly fond of.
        I might make the drive in the F30.
            I’ll consider making the haul in the E30. Would be nice to confirm that @B C hasn’t been cat fishing me this entire time.
            side note, this is screen shot is from like a year ago.
              The jig is up
                Literally have @B C labeled the same in my phone.
                  Really liked @gilber33's Coco mats when I saw them in person. My eBay ones are already getting matted and I usually have to pull them back after driving.
                  Thoughts on color? Obviously thinking red to go with the car, but maybe feel a little loud?
                  Otherwise thinking black and grey, or just all black.
                  Feel like all black maybe a little too subtle. Please make this decision for me.
                    I can grab some pictures of mine. They look different in person, IMO. The red isn't quite as in your face as those pics make it look.
                      Did you get the red ones to match your interior? I forget which color you had.
                          @gilber33 Yeah, definitely don’t look nearly as pronounced in this pictures. Think I’ll go with the red and black ones.
                          Have had a stumble or bogging if I quickly blip the throttle in neutral and sometimes when I’m blipping to rev match on a down shift. Figured I’d clean the throttle body and IAC. They weren’t really dirty or gummed up enough to make a difference in my estimation, but nice to have it done regardless. Throttle cable had a fair amount of slack in it. Adjusted it, response feels much better and tighter. Still get a little stumble or bog on a quick tap of the throttle, but it’s better.
                          Added a coat of black paint to the cowl vents as they were the last bit of trim that was faded.
                            Wanted to do an engine bay detail as it was pretty grimey and the rest of the car has been fairly sorted.
                             Materials:
                            Wanted to use Purple Power but they didn’t have it, bought whatever was the strongest. Spray bottle for mixing cleaner. Lug nut brush, wanted something small with a half way been fine and coarse bristles, this worked well. Leaf blower for drying. Not pictured, full can of Gunk engine degreaser.
                            Put a tarp down to avoid staining my parents driveway.
                            Before:
                            I bagged and taped a couple of electrical areas. I was not using a pressure washer, so this was mostly just a peace of mind thing.
                            Sprayed full bottle of degreaser and let sit for 10 minutes and rinsed the bay. Used a combination of the spray cleaner and the brush then to do a more thorough cleaning.
                            Blow dry off.
                            After:
                            Is it perfect? No. Am I satisfied? Yes.
                            Currently air drying with the hood open before starting. Car is going to need a wash to get the grime that splashed off during cleaning.
                              The crab and the valve cover need a nice bead blast. The cosmoline is always a jerk.
                                Indeed. My buddy has a sand blaster at his shop I’m gonna see if I can use before I give them the universal wrinkle black coat
                                  The last one you did looked stellar, I look forward to the same result on this one.
                                    Should be doing it rather soon, just ordered a replacement VCG among some other smaller maintenance bits.
                                    One of them being a clutch for my fan. Wether it be my engine bay cleaning(which seems unlikely), or just failing, the fan now spins constantly instead of engaging and disengaging based on engine temp. Sounds like a Jeep or something.
                                    On another note, was going through some of the invoices that Auto Clinic provided me from the previous owner. To my surprise, 5 years ago they had the cluster pulled and the speedo sent for a rebuild. Guessing this might be why my odometer is still working.
                                    As you can see, this car has not been driven much in the past couple of years. This invoice was dated 6/6/2014. Mileage was 98,453 then, and just about 6 years later, mileage is 106,XXX. Which I've probably added close to 1,000 at this point.
                                    There was also an invoice from September of 2013 for a timing belt kit replacement. Mileage was only a couple hundred less than the 98,452. If I remember correctly, timing belts are 50,000 mile or 5 year consumable? With this little of driving over that period of time, should I be too concerned about it? It was 7 years ago, but the amount of miles seems pretty negligible. I would replace with the Gates Racing if need be.
                                      Its so easy to replace the timing belt, I would just do it for peace of mind.
                                      Gates racing isn’t really a necessity. A fresh Conti-tech and new tensioner every 4 years is all she needs
                                        I second that. It’s not worth the risk of blowing the motor if it lets go. Also, might want to get to that fan clutch before it grenades, I’ve seen some gnarly pictures of ones where the fan let go, not pretty.
                                          I’ve already purchased, should be here in a couple of days.
                                          I’ll keep that in mind for the timing belt.
