Non-BMW Stuff on a BMW Forum
    I would find a used replacement, or opt for a flaming river U joint.
    I have decided that I’m going to avoid used parts whenever possible. The seem to be too much of a gamble. Went with the Condor solid steering joint.
      Solid choice.
        Solid burn.
        Now that I read that back, solid joint is pretty contradictory.
        While I wait for the Rack Doctor to ship my rack that I ordered over a week ago, I swapped these in and they were plug and play, so that was neat.
          Looks good against the silver.
            I like them better than I thought I would.
            My rack still didn't go out today. "Hopefully tomorrow" is what I was told. After being told last week Friday that it was going out on Monday, then yesterday that "there's no reason it won't go out tomorrow (today)". Not only do I want to drive my car, but I need it out of the fucking garage so we can keep moving shit out of the house.
            /rant
              gilber33 said:
              Solid burn.
              No burn intended.  Only pun intended.  ;)
                Purple tag e46 rack in and the Condor steering thing.  It was a pretty significant PITA. The splines on the rack from the rack doctor weren’t great. They give them a coat of paint and I’m not sure they cleaned them before doing that so they were all goobered up. And then one side of the shaft between the two joints would not fit into the joint without some major assistance. But it’s in so hopefully I won’t have to worry about any of the steering stuff for a long time.
                  How bad is this?
                  IMG_0048.MOV
                  • IMG_0048.MOV
                    that's gonna eat belts
                      I tightened up the belt some and it got significantly better. It was a used eBay into and the seller is going to see if they have another. Otherwise I guess I’ll get a rebuilt one. Idk.
                        Gooder picture with the new headlights.
                        Ran great. Took it to Tom’s on Monday to align it in his garage and it turned out really good.
                        Today’s thing was I realized the aux fan wasn’t kicking on at all. I also turned on the ac (it’s not charged yet) just to see if the fan would come on as it should. While diagnosing that tonight I realized I wired in the temp sensor plug into the cars harness wrong. Basically flipped the low and high fan settings.
                        Once that was corrected, I could jump the plug and get high to work but not low. Started at the fuse box and traced it down to the fans wire harness. I have 12v at the body harness for the fan. But from the connector to the resistor it drops to .3 volts. Yes. Point three. The ohm readings was scattered all over but never got close to 0.
                        Once again, a used part bites me in the ass. Now to source a new fan. I am ordering an ac manifold and vacuum pump so I can try charging it myself.
                          Was the cut off I sold you causing problems?
                            Not at all! The color of the wires are different and I wasn’t paying close enough attention and swapped the low and high signal wires.
                              So you determined that the low speed resistor on the fan was bad?  I think I removed a failed resistor on an e30 once and just connected the wires.  Then when the temp sensor calls for low or high speed it will just run high speed.  Costs nothing and the fan runs on high speed right away.
                                I have read that as an alternative. Bypass the resistor and replace the 15a fuse in the fuse box with a 30a fuse. For me, I couldn't determine if the resistor was good because the resistor wasn't getting any power. I followed these steps:
                                If low speed does not come on:
                                With the aux fan low temp (green/black to black) switch jumped, check for voltage on both sides of fuse 3. If you have no voltage, the K1 relay is suspect. If there is any appreciable difference across the fuse, replace the fuse. Check for voltage at aux fan resistor on the black wire. Voltage dropped from 12v at the connector to less than 1 volt at the resistor. If you have no voltage, there is a wiring fault. If you have voltage, check for voltage on the aux fan red wire. It should be less than 12V. If you have voltage, the fan or ground is suspect.
                                  Alright, Was just checking. I dont like selling bad parts. If there was an issue caused by me. I would have refunded you 😛
                                    Got the new aux fan in and now it comes on with the ac button.
                                    I also got the r134a adapters and I’m wondering am I supposed to remove the valves from the original fittings and thread them into these?
                                      See how this goes.
                                        To make the R134A AC update, did you need to do anything additionally? I have not tried my A/C, but will be on the old stuff. Would be nice to have if I ever needed it.
                                        Are you no longer running the clutch fan? Can you turn the fan on without having the A/C on?
                                          You need to at least do a valve on the evaporator, new drier and pressure switch. I also did new evaporator and condenser and now a new fan.
                                          I still have the clutch fan. The auxiliary fan comes on automatically with the AC on and mine wasn’t, that’s why I replaced it.
                                          The tools worked as they should but I have a leak somewhere that all the Freon drained out. When I put in the first can I was hearing a hissing sound coming from the vents behind the hood. I thought it was the Freon filling the evaporator but now I believe it was a leak. The pag oil I put in has the uv dye in it but since the pressure never got high enough for the compressor to kick in, I’m not sure if the oil was cycled through all the lines to help me find a leak. I do have leak detector spray for gas lines in your house, so I may sacrifice a can of r134 to find the leak.
                                          I read it’s not super uncommon for a leak to be sealed when the system is under vacuum and appear when it’s under pressure.
