Garage cleanout! E30, E36, E46 parts for sale
I will be continuously adding parts over the next few weeks as I come across them, so if you like dirty old car parts as much as I do, make sure to check this often.
Cleaning out my garage/basement/shed/etc. Prices are all OBO and do not include shipping if you need them shipped. I'd rather not ship larger items.
- E30 sedan doors. Drivers front (complete), passenger rear (complete), driver rear (gutted, but I have the glass). Some rust, but no dents. Driver front door window regulator worked when pulled, rear door did not but could've been a switch or something. Glass in good shape. All doors are FREE.
- E30 passenger side front frame horn/bumper shock mount. No rust, can be used for damage or rust repair. Was taken from a late model vert, though I believe they are all the same for all years (early and late model). $10
E30 318is exhaust rear section. I have since cut off the rear muffler right at the flange (it was not original and cracked). Use it to replace a rusty flange/resonator and weld on a new muffler. No rot, only minor surface rust. Or you can scrap it, doesn't matter to me. free
- E30 Vogtland lowering springs. Unknown mileage, but rode great. Sets the car at a nice ride height, not slammed. $100
- E36 M3 FX stage 2 chromoly lightweight flywheel and clutch. The clutch disk is pretty worn, can be used as-is or the flywheel can be resurfaced and paired with a new clutch/pressure plate. $50
- E36 coupe trunk lid in ok shape, Alpine White III. ~2" rust spot on the back but it is not through the metal as far as I can tell, came off my '99 e36 m3 (pictured). M3 badge, roundel, trim pieces, etc. not included, it is just the sheetmetal. Free
- E36 6cyl Zionsville 16" fan shroud and aluminum expansion tank. This is really well made and fits perfectly. You can mount any 16" SPAL puller fan. I had this on an M42 e30 (with e36 radiator), It will not fit a 24v swapped e30. It is missing the lower heater return hose tray piece. https://www.zionsvilleautosport.com/store/bmw-e36-add-on-aluminum-radiator-shroud-and-expansion-tank/ $200 obo (fan not included in this price, fan listed below).
- SPAL 16" curved blade puller fan (pictured above), 2024 cfm, part number 30102049. Dimensions are 16-5/16'' x 15-3/4'' x 3-7/16''. This is the deeper profile fan, definitely not enough room on a 24v e30, but can apparently be fit on an e36 6cyl (I had it on an m42 e30). I bought this new in 2017, only used for 1 summer. $100.
- BMW Style 4 wheels. 16x8 et23, 5x120, 72.56mm center bore. These are factory forged OEM wheels and were an option on the e38 7 series, not very common. Exact same fitment as the e38 style 5's. I do not have center caps. They have been poorly spray painted black but there is no curb rash or bends/cracks. $300 obo. (I will post more pictures this weekend).
Steering rack is a ZF? As in, from an E36? Or an E30 one?
E30
If no one else needs it, I'll take the e30 steering rack.
It's yours if you want it! I will PM you
I'll come by this weekend and pick up that old white car with the base model E39 engine in it. I can only do $2500 since it doesn't have airbags or traction control and I will be using it to transport my kids to and from daycare.
I think that's fair. I'll roll it out to the curb, just put the money in the mailbox. It's the perfect kid transporter, the lack of rear doors is a huge upgrade over your standard child locks.
Need two of these if you have any!! I put E30 sport seats in my E21 and the clips are too short on the early models for the buckle... Thanks!
I have a pair of coupe front seatbelts with the long buckles. One is locked but if you're just looking to use the buckle itself that would work perfectly. I may have a working pair of sedan buckles but couldn't find them in a quick look yesterday.
Any decent wheels in the pile?
I have a set of 5 e30 steelies with some old tires, a set of 4 5x120 et23 style 4s (no center caps or tires, need a refinish), and a set of 4 OZ wheels, dont know the model but they clear e36 m3 front brakes, 16x7.5 et35ish 5x120, mounted with a decent set of 205/55/16 general altimax arctic snow tires.
