Non-BMW Stuff on a BMW Forum
    Yeah, the coupler portion was what I was trying to refer to as the most difficult part of the process. Couldn't think of what it was called.
      When I did the front suspension on the e30 last summer, I dropped the rack and resealed it while I was in there. I had to bend the tabs down to get the rack out, but otherwise it wasn't too bad. I used a big flathead screwdriver in the gap in the splined coupler and the rack came out without much issue. Definitely easier with two people, for both install and removal, one holding the rack and the other holding the coupler and prying it open.
      That's good to hear that it wasn't too bad. Just glancing at it it looks nearly impossible to do with the engine in the car. I'm going to pull it in the garage tonight and will hopefully be able to remove it pretty quickly.
      I'm also swapping out the Bosch/Behr AC compressor with a Seiko unit. My Behr compressor is on the do not fly list for r134 compatible compressors.
        Like the watch company? lol
          Exactly. It tells time and cools the cabin.
            With the car in the air, it was very notchy. With the car off it had the exact same feel. Took off the belt for the PS pump and it felt like it had some resistance when I spun it. With it having the same feeling with the car on or off I feel like I can rule out the pump. I spun the rack by hand on the steering knuckle and there was no visible binding on the joints, but it felt like the resistance was coming from the rack and not the universal joints. It felt like it would hit resistance below my hand before above it. So I’m pretty confident it’s the rack.
              So hopefully someone can give me some input here if this looks right. The top u joint has free motion back and forth in one direction and the other direction seems to be very limited and to get beyond that limited range of motion I have to give it some force.
              IMG_9971.MOV
              • IMG_9971.MOV
                input: that u-joint is f*in toasted.
                  Well, allllllrighty then. And the OEM coupler assembly seems to not be available anymore.
                    When the steering shaft is bolted to the rack, is the circled area fouling on one another when you turn the steering wheel?
                      It is not. I looked carefully for that because I know you have to grind out some material on there when you do the rack swap. The video might now be showing up (at least it's not for me) but I tested  both directions of motion for that joint and one direction was very smooth and seemed to have full motion and the other direction had very, very little free motion and anything outside of this small window of movement required a lot of force.
                        I would find a used replacement, or opt for a flaming river U joint.
                          I have decided that I’m going to avoid used parts whenever possible. The seem to be too much of a gamble. Went with the Condor solid steering joint.
                            Solid choice.
                              Solid burn.
                              Now that I read that back, solid joint is pretty contradictory.
                              While I wait for the Rack Doctor to ship my rack that I ordered over a week ago, I swapped these in and they were plug and play, so that was neat.
                                Looks good against the silver.
                                  I like them better than I thought I would.
                                  My rack still didn't go out today. "Hopefully tomorrow" is what I was told. After being told last week Friday that it was going out on Monday, then yesterday that "there's no reason it won't go out tomorrow (today)". Not only do I want to drive my car, but I need it out of the fucking garage so we can keep moving shit out of the house.
                                  /rant
                                    gilber33 said:
                                    Solid burn.
                                    No burn intended.  Only pun intended.  ;)
                                      Purple tag e46 rack in and the Condor steering thing.  It was a pretty significant PITA. The splines on the rack from the rack doctor weren’t great. They give them a coat of paint and I’m not sure they cleaned them before doing that so they were all goobered up. And then one side of the shaft between the two joints would not fit into the joint without some major assistance. But it’s in so hopefully I won’t have to worry about any of the steering stuff for a long time.
                                        How bad is this?
                                        IMG_0048.MOV
                                        • IMG_0048.MOV
                                          that's gonna eat belts
