  4. Nick's e90 build
Nick's e90 build
45 Posts 8 Posters 856 Views 1 Watching
  • N
    N
    Nick_F
    Bummer on the front bumper delay. How was the Car Max buying/shipping experience?
    The delay gives me a little more time to decide what route to go at least. It was surprisingly smooth and pressure free. If I buy another car from a dealer they are on my short list.  The nice thing with shipping the car with them was I wasnt obligated to buy the car but I did have to pay the shipping fee.
    • N
      N
      Nick_F
      A couple other things I did early on. The wood grain had to go. I wrapped it with some satin black vinyl and it has been holding up awesome. After that I ordered a wrapped flat bottom msport wheel from Latvia which I ended up liking a lot more than i thought i would
        The Lime Rock Park E92 M3 has that same steering wheel wrapped in Alcantara
          Nick_F said:
          stage 2+ e30
          Hell yeah
          Great looking e90! I'm biased but space gray is such an awesome color.
            Looks great. LCI E90 rears look so much better than pre-LCI. This is a 2011 N55, right?
            • N
              N
              Nick_F
              Yea rocking that n55 which has been extremely reliable minus the hpfp which might be going again. Thank goodness for fcpeuro's lifetime warranty! I cant wait for the mtech rear bumper, I think it makes the car look so much better
              • N
                N
                Nick_F
                Hell yeah
                space grey for now... looking at a few possible wrap colors right now
                  that steering wheel is OEM perfection 😍
                  • N
                    N
                    Nick_F
                    The stock one peeling was a good reason to upgrade
                    • N
                      N
                      Nick_F
                      Well got a few parts in the last couple weeks. As far as the trunk lip, not sure I'm crazy about it. Havent mounted it yet, just used tape to hold it down for a test fit so it might look a little off
                        I've always been a fan of paint matched spoilers on non-m cars.
                        • N
                          N
                          Nick_F
                          Well oil pan went extremely smooth and ended up doing a complete front end refresh. Should have taken more pictures but got into worker bee mode. Thankfully my friend has a lift or this wouldve sucked
                          But unfortunately now the clutch is slipping when wide open 😴 time to research. Anyone have advice on switching to a single mass flywheel and also with sticking to oem clutch or upgrade?
                            Do you have a  CDV/clutch delay valve/clutch destroyer valve?  I would remove that to help prevent slippage.
                            • N
                              N
                              Nick_F
                              I didnt even know that was a thing, ill have to take a look into that. The last thing I wanna do is have to do the clutch again in the near future. Ended up going with the 335is clutch and a new dual mass flywheel because I dont wanna deal with the chatter on the single mass since it is my daily
                                I dont know how much its slipping, but removing the CDV MIGHT help with the slipping.
                                Ever since the E36 there has been a CDV in manual cars. Its as simple as unbolting the CDV from the clutch line (near the clutch slave) and reconnecting the line, omitting the valve, then bleeding the clutch.
                                Static friction coefficients are much greater than dynamic friction coefficients, and while that isnt really an accurate analogy for the CDV or a clutch, the delay in full clamp pressure allows slipping to start which makes it easier to continue slipping.
                                Who knows, removing it MIGHT buy you a little additional time. I'd be curious to see if it reduces the slipping.  I have never known of anyone who prefers to drive a car with a CDV so you can feel comfortable about removing it. If you dont like it, pop it back in.
                                • N
                                  N
                                  Nick_F
                                  This has convinced me to at least give it a try. Is there really a downside to removing this? I did just watch a few videos on it and youre right, not many people are huge fans of it and are happy there removed it.
                                    Biggest downside is you no longer have something to blame crappy shifts on. You gotta own up to them yourself.
                                    Other than that, no.  There are some half-baked theories on why the CDV exists such as  "They put it in the E46 M3 as a bandaid for chassis cracking issues!!!" (wrong) or  "They put it in so new drivers dont stall the car!!!" (wrong)  Im fairly certain its just a simple means for reducing shift shock primarily for driver comfort with component wear reduction as a secondary benefit.
                                    LMK how it goes
                                    • N
                                      N
                                      Nick_F
                                      Well getting close to my witts end sadly with this car. Just noticed a whine a couple days ago while driving that sounds like the transfer case or front diff. Not sure what the future holds for this "build". Its pretty strange, it only happens while the car is rolling but doesnt matter if it's in gear or neutral. However if I'm rolling in neutral it goes away after the rpms drop to idle but if I tap the gas while still in neutral it comes back. Need to do some further digging.
                                      • N
                                        N
                                        Nick_F
                                        Here is that noise I'm trying to figure out. Any input in extremely appreciated
                                        20200529_192754.mp4
                                        • 20200529_192754.mp4
                                          My suggestion: Change your transfer case oil ASAP. Like, consider not even driving it if thats possible, otherwise keep driving and plan on throwing in a used t.case soon
