  4. The One That Didn't Get Away [100K Mile E30 325is]
257 Posts 19 Posters 4.4k Views 2 Watching
    With a car as clean and low mileage as yours I'd definitely be inclined to keep the original engine. There is absolutely no shame in liking an M20, they're pretty hard to hate! I'd love one to play around with again at some point.
    I totally agree that M20's (and the M30) are some of the best sounding BMW engines too, anything newer has absolutely nothing on them.
      This is the plan for the foreseeable future. My only plans for it are maintenance and an exhaust.
        I know most people would opt for a different motor than the M20, but I’ve really been enjoying it. Really great for the casual cruising and still comes alive above 5k. I also have the weird dichotomy of loving fast cars, but don't really have the need for speed much.
        That's exactly why I decided to spend money on refreshing the M20 rather than doing a swap. IMO, the amount of power is perfect. You can give it the beans and have a ton of fun on the backroads while not overly exceeding the speed limit. When I had my "stage 2" S60R it was too easy to go too fast. And at the end of the day, what was the point of it? In that second it was a lot of fun, but what I could have done to myself (with 3 kids) or someone else wasn't worth it. I sold it shortly after having that revelation.
        Rebuilding my m20 gave me a lot of respect for the engine and its place in the car.
          I'm going to be doing a lot of reviewing your thread down the road.
            What is needed for a 3.1? I've really only seen 2.7 and 2.9 examples.
            https://www.iemotorsport.com/product/ie-3-1l-stroker-kit-m20/
              Yellow text on a white background is horrid.
              That being said, this is very interesting. I see they suggest a WAR chip or running MS in addition to bigger injectors. If the WAR chip is an acceptable ECU tune, that would be prefer over going complete stand alone.
                WAR chip is acceptable on an OBD1 E36, but junk on an E30. The MAF conversion is very problematic. MS2 plug and play is just fine. Get it setup correctly and a dyno tune and you shouldnt have to touch it anymore and have a much better diagnostic and logging  ability. The drivability and throttle response improvement are worth it alone on a stock M20
                  The war chip is junk in general. Don't bother.
                    My vote is MS2 pnp. Not sure if they made an MS3 pnp for the m20?
                      MFW reading this thread and making a plan in my head. pls stop influencing me guys.
                      I think if I were to do this, I would buy a separate M20 and do it on the side. S52 was a good learning experience, M20 seems to be a little more straight forward.
                        Here is how it will play out: you grab a bimmerheads ported and polished rebuilt head with a cam, attach some ceramic coated headers while you are at it, Drop that in sometime in June.  then work on a stroker bottom end build and preparing for MS2 over the winter.
                        i kno, rite?
                          Orrrrrrrr, k24 swap it & add cams. Better weight balance, more power, wasn’t brought to the US on the mayflower, etc.
                          reading this for 245hp makes my wallet cry
                          /roastme
                            /roastme
                            245hp at the crank after playing with the smoothing and correction factors, deleting the lot of 237bhp plots that preceeded it and dry-icing the intake.
                              /roastme
                              I honestly wonder what the cost difference would really be between building the M20 already in your car vs swapping a K24. The adapter plate is like $1500 alone.
                                Oil pump location on the K motor is right in the middle of the subframe on an e21/e30. Not that it can't be done, but it's not pretty and there is some fabrication involved.
                                  I'd rather stay with the M20 platform at this point.
                                    Luckily kmiata exists and takes the headache out of the swap. The e30 k swap is much simpler than the Miata k swap.
                                      My original point was with the time/cost you’ll sink into a high strung 3.1L m20 would probably be close to putting a k in. Not to say the K is a cheap swap, but neither is building a motor.
                                      that being said my vote would still be do whatever you want because a high strung stroker m20 sounds sweet
                                        I vote m20 stroker because it is OEM + and I am all for OEM +
                                          Completely understand, it would definitely be a pricey build. I very much like the idea of retaining the M20, while being a modified variant, would adhere to the vast majority of maintenance, repairs, and trouble shooting sequences for a normal M20
                                          I agree.
