  4. Diaries of a Daily Driver
199 Posts 23 Posters 2.4k Views 1 Watching
    Calypso Jeep
    I'm going to counter with Burgundrot jeep. I'd say that looks like a sweet deal for $300!
      XJ's are great rigs! Does it have the 4.0L?
        4.0 with a 5 spd
        Burgundrot jeep it is!
        Played with the clutch stuff for a bit to see what I could find. I ordered a new master cylinder to see if the seal in that is weak.
        I hope it's not the slave cylinder, as they use a "Tilton" style slave.
        Getting access to that means pulling the trans and transfer case, which doesn't sound like too much fun!
        They also use a plastic clutch hydraulic line that seals to the master with an o-ring, and is held in place with a roll pin through it. A genuinely wild setup.
          an XJ was my first car (parents car). nice buy!
            it's a jeep thing, you wouldn't understand
              Much stoke
              Got the new clutch master cylinder in in about 30 min and didn't even need to bleed it.
              Clutch is fully functional now. $30 fix for the win.
              Kind of makes sense that it was worn out. The cluster (speedo doesn't work) shows about 284k miles, so the clutch has been done once or twice and you replace the hydraulic throw-out bearing when you do the clutch. The master was likely original and that's many times of pressing the clutch!
              Now to drive it and find what else is broken / needing repair!
                  ^speaking of which!
                  Now that it drives it was time to turn to other things.
                  The front had almost 6.5" of lift due to the 4.5" lift spring and a 2" rubber spacer. It looked stupid, especially on 33's with fenders that are trimmed up.
                  Took the front axle almost all the way out in order to remove the rubber spacer on top of the spring. Realized the axle had been sitting about 2" toward the driver side because whomever put the spring spacers in never adjusted the trac bar. This style suspension is so much different than anything I've worked on, and luckily my roommate has been playing with jeeps for quite some time (his jeep in the back) so he can lend a hand when I get confused!
                  Also realized it has very f*ing beefy steering, and is a good system that allows you to adjust ride height and such without needing to adjust toe again. Stock steering has the drag link and tie rod end going as one part.
                  Now to clean up the rear shock mtg points and get some shocks back there!
                    I absolutely hated aligning Jeeps or anything with this drag link style set up.  It's nice because you can ONLY adjust total toe and steer ahead but steer ahead can be a PITA if your steering lock is shit or you don't have a human holding the wheel straight while adjusting it.  That and rusted out sleeves/threads.  So many painful memories.
                      Haha love it. I miss my old 5-speed 4.0L Cherokee. Thing was so fun.
                        I recall rolling down college Ave with the sub in the back just bumping away.
                        Good times.
                          Good times.
                          Same time your wheel went for a stroll down College on its own? Or a different time?
                            Same time your wheel went for stroll down College on its own? Or a different time?
                            That was much earlier than the Jeep!
                            This was a deserved jab after my previous one.
                              Sadly my shocks didn't show up in time for a shakedown run on a friends property, but we took the roommates jeep on its first voyage with locking diffs.
                              These videos well showcase why I got rid of the diesel in lieu of something that can actually go off-road.... or at least that's my excuse!
                              35" tires a stock intake
                              https://youtu.be/F4F4OYodLrM
                              https://youtu.be/byCik8Uzmug
                                What kind of lockers?  I recently put a Spartan auto locker in the rear of my Land Cruiser.  Major upgrade for not much money.
                                  Detroit auto locker in the rear and electric locker in the front.
                                  I anticipate running Lokka lunchboxes front and rear in mine once I settle on a pair of axles.
                                    That looks fun!
                                      I an amusing turn of events where the mill I was going to had an issue and delayed their outage by one day I was able to go snag a Chrysler 8.25 and Dana 30 with 4.10's in them for $400.
                                      The stock 3.07's with 33's is a brutal combo, so this will be a welcome change! This is the exact same set of axles in my Jeep currently which is amusing, but this is just like swapping a diff in an E30! with more weight and parts...
                                        Turns out this speed was super accurate.
                                        45mph she really came alive, this wasn't too surprising as I have determined most ball joints are bad in the current axles. New axles seem to have better ball joints so that should help.
                                        Did my first off-road adventure with it and holy crap driving manual in demanding off-road terrain is a wild time. I should be good at dancing after this!
                                        Slipped a front wheel into a pond, whoops.
                                          I forgot,  I ran this into a tree lol
                                          Bought another XJ that night for $250 non running, pulled the front clip, cluster, and various driveline parts.
                                          Also got a CB in the deal
                                          Breaker 1-9
                                          Picked up lockers for the new axles, will get those in process soon.
