  4. E46 Things
E46 Things
    Inner Monologue A: “you should spend a few minutes today working on the new shifter install”
    Inner Monologue B: “Hey, that’s a good idea!”
    Inner Monologue B: “Before I do that I better take the headlights out and delete the headlight sprayer system and install the new trim pieces I got from my Secret Santa”
    I removed the headlights and found out the new trim I have is for an early non-M E46 and they are just so subtly different so I cannot use them. Darn
    While removing one headlight the solder joint on the halo wiring broke. So I mended that...
    Then I removed the headlight sprayer nozzles, hose, and disconnected the pump for it on the reservoir. No more washer fluid splashed all over the hood!
    I noticed some less than stellar turn signal wiring.
    so I fixed it.
    So I made 0 progress today on the shifter but it was nice to take care of those small items
      Image result for E46 M3 front endImage result for E46 325i vsd. M3 headlights
      Its sooo subtle. Ughh WHY, JUST WHY?!?!
          Date: 2/29/20
          Mileage: 157,429
          Fresh oil change for driving season 2020
          I went to Pegasus Racing to pick up the Redline oil. The guy at the counter was a bit of a space cadet.
          Pegasus: “What can I do for you”
          BC: “ I need 6 quarts of Redline 15w-50”
          Pegasus: “what is that?”
          BC: “That’s motor oil”
          Pegasus: *clicking away on the computer for a while*.....”Is that shockproof?”
          BC: “IT’S MOTOR OIL.”
          I replaced the broken PS hose mount as it had broken and was resting on the belly pan (shown dangling circled in red). RealOEM didn’t show the part separate from the PS hose but it turns out to be the same part as the secondary air pump mount. Dorman makes them and a box of them can be had on the cheap.
          I started on the shifter rebuild and tallied a list of other small parts to order. If tomorrow is as warm as it looks like it will be I expect to get some more work on the shifter done.
            Re PS fix. Well I'll be. Beats the zip tie fix on mine.  Dorman part#?
                Shoutout to my Harbor Freight “ 8” Universal Radiator Hose Pick” for being a bro and removing yet another bitch clip with ease
                The UUC components were loaded onto the shift carrier. I still need to determine how to remove the rear rubber mount for the shift carrier from the chassis to install a new one and get the selector rod joint off to install the new one.
                After getting the shifter install buttoned up , most likely this next weekend, this is what is left on the list before I drive it:
                -Bleed clutch/brakes
                -unmount/rotate tires
                -Mount electric fan with different mounting brackets to make it more easily removable. (Was mounted with zip strips that were not accessible without removing the radiator or condenser)
                -Replace CPV o-ring (oil leak)
                -Replace Dipstick tube o-ring (oil leak)
                -Replace crankcase vent return line (oil leak) it should be 100% leak free after this???
                  I remember having to torch my old rubber bushing out of the carrier that bolts to the car
                    just pry it off the chassis.
                    look at the new one, it should have two slots in the sides. the bracket on the body just tabs into those.
                      I was totally in the e30 mindset with this. Dans photos have enlightened me.
                        i only remembered the e36/e46 part because the dingleberry that did the swap in my car couldnt wrap his dinglebrain around the different styles and I ended up having to fix his hack, which included the e36 bushing:
                          So the PO just sort of jammed the E36 bushing between the E30 bracket and chassis? Did the shifter have freeplay as a result?
                            So the PO just sort of jammed the E36 bushing between a random scrap metal bracket and chassis? Did the shifter have freeplay as a result?
                            fixed, and yes my shifter be like
                              Progress this week:
                              -Asked @Jdesign which shop near me wont scratch my wheels during a rotate/balance, he suggested Midcoast Auto in West Allis so I dropped them off there. They seem like a nice operation. Should be picking them up tomorrow.
                              -Removed shift carrier bushing (thanks to @straight6pwr for the image)
                              -Removed the selector rod joint. This is much more challenging with the transmission in the car and the driveshaft installed. Who could have imagined!?!?
                              -Installed new selector rod joint with pre-installed DSSR. This seemed like a good way to go and I think it was an easier way to hold onto the joint with the limited visibility and access.
                              The compression set of the foam on the old joint vs the new joint:
                              The stock rear carrier bushing shows no cracks or obvious signs of wear but it is so flimsy and has a ton of radial movement by design. The Turner Motorsports bushing is gon b’ gud.
                              I need to drop the trans crossmember 1/2” again to get the rest of the shifter installed (for bitch clip clearance) so I will save that for later.
                              ....plugging away 15 minutes at a time
                                What did you get charged at Midcoast? And do they mount used tires?
                                  ***Updated:$111. and yes.
                                  I need to ask them if they do emissions testing. I’m not sure why I am required to have an emissions test for a second consecutive year but would prefer not to watch someone stall and slip the clutch as they pull it in and out of the shop
                                    $75 and yes.
                                    Where do you go for emissions testing? I've gone to two places and both I drove into the bay, they plugged it in, and I drove out when they were done.
                                      The first place I tried last year was Fast Track oil but the pipes that surround the inspection pit combined with the entrance ramp were just too aggressive for my stants.
                                      The second place was an indy shop similar to a Car-X but they wouldn't let me pull it in.
                                        E46 was also back to back years (first when I bought it and then the year after). I used Wilde Toyota since it was close and fast and they had worked on the Tundra. They drove the car.... came back clean with no mileage run up so I guess all good.
                                        F150 last year was at a shop just west of Moorland on National Ave (north side of street). I think it used to be a Firestone or MIdas? No inspection pit, the bay they drove into was just a slab.
                                          the Lakeshore Mobil station in Shorewood just has you pull up to the service door in the lot.  They didnt even move the car, just plugged in the device and  boom goes the dynamite.
