    @Jdesign in the future
    Image result for biff back to the future bmw
       I never realized Biff had euro bumpers
        Duh, it's the future!
        Also are you doing upper and lower ball joints on the trailing arms instead of the non M style with one ball joint and one bushing?  I did that on mine and I don't see any reason why not to.
          Yes, although I stupidly forgot that I have new bushings that I made from delrin for the lowers already on the car as seen here:
          https://www.wibimmers.com/board/index.php?/topic/4537-futuristicconcept-art-bmw-e36-with-a-v8-on-a-bottom-dollar-budget/page/18/
          Im also contemplating if I should just find a cheap fuel cell instead of replacing the fuel tank.... Thoughts?
            What's wrong with the fuel tank?  Maybe I missed it.  The stock tank seems like a good design, it's low and fits around the components of the car well.  Any fuel cell is going to be further back and higher up.  Also capacity might be an issue, it would be annoying to stop for fuel every 150 miles.  I would think tanks should be all over from junked cars, there isn't anything to go wrong on them unless it gets punctured.
              roof rack +
              Trailer-Parts-Unmarked-Wabash-13326633.j
                another idea: put a hole in top of the trunk lid and put that tank in the trunk so you can see it. maybe leave the filler hanging out a hole in the lid or the fender.
                  It has a hole in it. When the car bottoms out, it smushed the floor into the tank a poked a small hole in it. I patched it, but I have a new tank I got from TJ. But since the floor is all destroyed, its likely to happen again unless I smasheth everything with a BFH. Not that I dont mind doing that, but I thought it might be smarter to just get a fuel cell. IDK you are probably right about keeping the stock tank.
                  LOL. I plan on cutting the whole floor of the trunk out while im doing the subframe and all that stuff back there. I think its a smart move to relocate the battery between the strut towers vs. the stock quater-panel location in case I hit something. With that, I figured it might be easy to run a fuel cell but in the end it more messing around that I dont need to do right now. I just want to get this thing road worthy again.
                  This is similar to what I was thinking:
                  bmw-m3-e36
                    you'd never have to stop for gas with 45-50 gal.
                      IDK if I would even get moving with the weight and use of diesel in a gas engine. But seriously, that's obnoxious and  would require some extensive fabrication to make sure I don't explode when I hit something. (I really plan on hitting something)
                        they hang these off the sides of trucks and everything is hunky-dory.  i've never seen a semi truck on fire before.
                          https://www.youtube.com/watch?v=rpnCB2OwgVY
                            I’ve seen more cars burning on the side of the road then tractors but it does happen haha. It’s usually electrical issues.
                              Also for a truck it's filled with diesel which doesn't readily burst into flames like gasoline...
                                So, I finally took some time to work on this. Despite the parts being moved around the shop as I tended to other projects, I finally moved the crate for the last time and got this going last weekend. Up on the lift I pulled the old wheels off and found that one of my spacers became no longer hub centric..
                                Besides that I was able to get 6"s of lift out of the coilovers up front before the bottom of the uprights hit the control arms. I made a slight adjustment back down to prevent this. In the future I might need to add a spacer to the subframe and control arm bushings to get more lift and travel out of this set up. I also had to remove the brake lines from mounting locations as the flex section was maxed out and would have prevented me from turning. The PO deleted the ABS and its a mess, so I might find myself addressing the brakes again in the near future, but for now I will just weld tabs for new "lower" mounting locations to allow the lift.
                                I had to remove the front bumper due to the tires rubbing and I was unsure if I wanted to trim it and the filler panel with the kidneys. After I removed it I test fit the front wheels and kind of like the look with no bumper cover. I might need to attach some kidneys of some sort just because of the BMW factor but I will revisit this later.
                                I then started the rear last night which was a whole different situation. I started by removing the over fenders and exhaust. As mentioned earlier, I was upgrading to ///M Swing arms and axles. So with that, I have all new bushings, subframe, control arms, control arm supports, ETC. I am swapping out everything besides the shocks, brakes, and diff. I was able to remove everything without any major issues. Once everything was set aside, I started to trim the arches more to allow the bigger tires.
                                After this I gave up for the night and will return tonight.
                                ...... But obviously I had to see how it looked on the ground, so I set it all in place and lowered the car back on the ground. Needless to say I was pretty happy with the results.
                                  Excellent!
                                    Excellent!
                                      WhistlinDiesel would be proud
                                      next step:
                                        Mount the kidneys to a custom brush guard? Or make your own monster kidneys
                                          You mean use a set from a 2020 BMW?
