  4. E46 Things
E46 Things
    VANOS installed.
    Cams are timed perfectly.
    It took a few hours and some patience and a little bit of experimentation to make the timing perfect. I had it set within the acceptable range but it needs to be perfect because quite simply it’s an S54 and the S54 deserves it.
    What I believe prevents some people from getting it perfect is a slight advancement of the cams while tightening the sprocket hub bolts and the slightest bit of timing chain slack.  You can follow all the directions to the T but it can still be slightly off. There are plenty of forum threads where people had incorrect timing and error codes simply from using a non-BMW timing tool or by wrongly assuming they had it close enough. It is a fairly involved process and do not want to revisit this at a later time. It is as perfect as it can be. If by some chance it throws a code or is off, I will write myself off and quit working on cars.
    Later today I should get around to the valve adjustment and get it all put back together.
      That engine bay is marvelous. Great work.
        4 valves adjusted.  Only 1 was out of spec, the other 3 were borderline. I like these adjustment shims more than the adjustable eccentrics that the M20 has.
        The allowable range is
        .007”-.009” intake
        .011”-.013” exhaust
          Fired right up, smoother and quieter than before!
          On to the next project!
            Damn that's an ugly airbox.  It ruins the whole engine bay.  Absolutely unacceptable.  If only a solution existed...
            • damnboy037D
              damnboy037D
              damnboy037
              Brian I gothcu boo- this for the low low price of $8200!
              https://www.ecstuning.com/b-genuine-european-bmw-parts/euro-csl-intake/11617833496kt/
              Would this fit a s50b32? BTW it’s $8554 now
              99 M3 320rwhp @ 6psi
              95 M3 s50b32
                From what I can tell it does not fit a euro s50 and the price did go up but not to $8554 when you've got a wholesale account.
                  https://youtu.be/ZjFVV5HXU0Q
                    My fingers are frozen from installing these spinnybois tonight.
                    Replaced the hardware because oxidized hardware does not belong on sexy new underdrive pulleys
                      Next on the list.
                      I dont foresee much time in February for wrenching but my goal is to get the shifter in, oil changed, and other items finished up the 2nd week of March so I can be prepared in the event we have an early start to Driving Season.
                        Do you have the DSSR as well?  It is at least as important if not more than the short shifter IMO.  I have that same shifter in my non operational e36 and it is very nice.
                          Yes, as well as a selector rod joint. The UUC stuff is pretty magical
                            Inner Monologue A: “you should spend a few minutes today working on the new shifter install”
                            Inner Monologue B: “Hey, that’s a good idea!”
                            Inner Monologue B: “Before I do that I better take the headlights out and delete the headlight sprayer system and install the new trim pieces I got from my Secret Santa”
                            I removed the headlights and found out the new trim I have is for an early non-M E46 and they are just so subtly different so I cannot use them. Darn
                            While removing one headlight the solder joint on the halo wiring broke. So I mended that...
                            Then I removed the headlight sprayer nozzles, hose, and disconnected the pump for it on the reservoir. No more washer fluid splashed all over the hood!
                            I noticed some less than stellar turn signal wiring.
                            so I fixed it.
                            So I made 0 progress today on the shifter but it was nice to take care of those small items
                              Image result for E46 M3 front endImage result for E46 325i vsd. M3 headlights
                              Its sooo subtle. Ughh WHY, JUST WHY?!?!
                                  Date: 2/29/20
                                  Mileage: 157,429
                                  Fresh oil change for driving season 2020
                                  I went to Pegasus Racing to pick up the Redline oil. The guy at the counter was a bit of a space cadet.
                                  Pegasus: “What can I do for you”
                                  BC: “ I need 6 quarts of Redline 15w-50”
                                  Pegasus: “what is that?”
                                  BC: “That’s motor oil”
                                  Pegasus: *clicking away on the computer for a while*.....”Is that shockproof?”
                                  BC: “IT’S MOTOR OIL.”
                                  I replaced the broken PS hose mount as it had broken and was resting on the belly pan (shown dangling circled in red). RealOEM didn’t show the part separate from the PS hose but it turns out to be the same part as the secondary air pump mount. Dorman makes them and a box of them can be had on the cheap.
                                  I started on the shifter rebuild and tallied a list of other small parts to order. If tomorrow is as warm as it looks like it will be I expect to get some more work on the shifter done.
                                    Re PS fix. Well I'll be. Beats the zip tie fix on mine.  Dorman part#?
                                        Shoutout to my Harbor Freight “ 8” Universal Radiator Hose Pick” for being a bro and removing yet another bitch clip with ease
                                        The UUC components were loaded onto the shift carrier. I still need to determine how to remove the rear rubber mount for the shift carrier from the chassis to install a new one and get the selector rod joint off to install the new one.
                                        After getting the shifter install buttoned up , most likely this next weekend, this is what is left on the list before I drive it:
                                        -Bleed clutch/brakes
                                        -unmount/rotate tires
                                        -Mount electric fan with different mounting brackets to make it more easily removable. (Was mounted with zip strips that were not accessible without removing the radiator or condenser)
                                        -Replace CPV o-ring (oil leak)
                                        -Replace Dipstick tube o-ring (oil leak)
                                        -Replace crankcase vent return line (oil leak) it should be 100% leak free after this???
                                          I remember having to torch my old rubber bushing out of the carrier that bolts to the car
