  3. Cars For Sale & Wanted
  4. 1988 E30 - sold
1988 E30 - sold
24 Posts 12 Posters 401 Views 1 Watching
    Kind of tossing this around lately. My red coupe is just sitting in storage and I think I’d like to sell it. I’ve thought about parting it out, but I don’t have the time/patience to deal with that.
    here’s the details (list is sporadic)
    Mishimoto radiator/silicone hoses
    Condor solid engine mounts
    Garagistic weld in subframe reinforcements (F&R)
    Both subframes stripped and POR-15’d
    Every bushing has been replaced with poly
    New Lemforder control arms
    New rear wheel bearings
    Hawk HT-10 front pads
    Hawk street race rear pads
    Brembo blank rotors
    Porsche 944 brake booster
    E36 rack
    New inner and outer e36 tie rods
    Chase bays ABS delete/proportioning valve
    Chase bays full brakeline kit
    2.93 LSD
    Getrag 260
    Trans brace for g260 when used with 24v swap
    E21 cupped trans mounts
    Zhp shift knob
    UUC DSSR shift linkage
    FX racing lightweight flywheel
    FX racing stage 2 clutch
    Stainless braided clutch master line
    HR race springs
    Bilstein sport shocks
    E90 drop hats (I think? @B C can you confirm)
    S50B30 (1995 m3 donor)
    Random new longtube headers
    E36(ish) exhaust
    Most gaskets replaced
    New knock sensors
    New VANOS feed line
    Beisan VANOS repair/anti rattle
    New crank position sensor
    ARP head studs
    JE cutring headgasket
    Head decked & pressure tested
    Red or silver label 413 ECU w/sssquid tuning chip
    Plastic bumpers
    Red46 skid plate
    ST sway bars front and rear
    Turner motorsports rear sway bar trunk reinforcements
    newish aftermarket black carpet (fit is so-so)
    dash is decent and IIRC only has a few small cracks above the glove box
    momo hub adapter for steering wheel
    shell isn’t super perfect by any means. Typical e30 rust, was a MN car for some of its life. Has 2 new front fenders.
    photos in storage unit are current (Tan seats) - (I’m sorry I know the photos suck) I can get more pics if interested.
    Bring your own wheels. I’ll probably keep the sparco steering wheel. Trans/driveshaft/radiator are in the trunk. Intake manifold side of engine bay is partially disassembled from when I removed the trans.
    if you guys have any questions at all please let me know.
     $old
      Shift linkage should be a UUC DSSR if it came off the black car
      Yes to E90 drop hats.
      I should buy this
        The sale of this should help make room for your Evo purchase for autox next year.  GLWS
        • The Full BananaT
          The Full BananaT
          The Full Banana
          This is really quite tempting.
          What is missing for it to be a driver other than wheels and a steering wheel (plus a healthy amount of reassembly)?
            I should buy this
            Rent a storage unit and I’ll tow it to you
              Clutch slave cylinder (I broke it on accident), definitely should drain the gas (been sitting for A few years now) probably fuel pump/filter at the same time if you wanted. Bleed brakes, add the regular fluids and such. I believe it needs one valve cover stud. I have the stock injectors, but they have been in a plastic baggy for about a year and a half now.When I broke the axle it was running great lol -  it’s only been ran a few times in the last few years, when I stored it I put some marvel mystery oil in it and turned it over.
              if I think of anything else I’ll add it.
                Oh it also has some VDO gauges and an innovate wideband (not sure if I have the sensor portion)
                  Once again not having storage spaces saves me. Sigh.
                    Uhhhh. ummm. Uhhh. fuck.
                      I got garage space @B C...
                        Thanks.
                        Always wanted a 24v swapped E30!
                          • need4speed1299N
                            need4speed1299N
                            need4speed1299
                            I have a set of bottle caps with decent tires. I'll be surprised if this isn't gone this weekend. Best deal I've seen in a long time.
                              Somebody buy it
                                no u
                                  Some additional body pics might help. "Typical e30 rust" can mean some combination of rotted trunk wells, rear apron, rockers, floor pans, frame rails, and door skins and seams as well fender rot (which has been addressed in this case).  Levels of rust tolerance for a project car also vary given the diverse skill set of folks with cutting, welding, and POR-15 slinging. Rear of the car looks pretty clean from the pics in the thread. A little more detail and pics of the typical problem areas might help set a hook in someone.
                                    I made this post before I had more photos. Just got back from storage and took a bunch of pics. Will post soon
                                      Sold
                                        Nice! One gone, one to finish?
                                          That’s the plan
